[petsc-users] PetscSFReduceBegin can not handle MPI_CHAR?
Fande Kong fdkong.jd at gmail.com
Thu Apr 4 10:14:45 CDT 2019
Hi Jed,
One more question. Is it fine to use the same SF to exchange two groups of
data at the same time? What is the better way to do this
Fande Kong,
 ierr =
PetscSFReduceBegin(ptap->sf,MPIU_INT,rmtspace,space,MPIU_REPLACE);CHKERRQ(ierr);
 ierr =
PetscSFReduceBegin(ptap->sf,MPI_CHAR,rmtspace2,space2,MPIU_REPLACE);CHKERRQ(ierr);
 Doing some calculations
 ierr =
PetscSFReduceEnd(ptap->sf,MPIU_INT,rmtspace,space,MPIU_REPLACE);CHKERRQ(ierr);
 ierr =
PetscSFReduceEnd(ptap->sf,MPI_CHAR,rmtspace2,space2,MPIU_REPLACE);CHKERRQ(ierr);
On Wed, Apr 3, 2019 at 9:40 PM Zhang, Junchao <jczhang at mcs.anl.gov> wrote:
> On Wed, Apr 3, 2019, 10:29 PM Fande Kong <fdkong.jd at gmail.com> wrote:
>> Thanks for the reply.  It is not necessary for me to use MPI_SUM.  I
>> think the better choice is MPIU_REPLACE. Doesn’t MPIU_REPLACE work for any
>> mpi_datatype?
> Yes.
>> Fande
>> On Apr 3, 2019, at 9:15 PM, Zhang, Junchao <jczhang at mcs.anl.gov> wrote:
>> On Wed, Apr 3, 2019 at 3:41 AM Lisandro Dalcin via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> IIRC, MPI_CHAR is for ASCII text data. Also, remember that in C the
>>> signedness of plain `char` is implementation (or platform?) dependent.
>>>  I'm not sure MPI_Reduce() is supposed to / should  handle MPI_CHAR, you
>>> should use MPI_{SIGNED|UNSIGNED}_CHAR for that. Note however that
>>> MPI_SIGNED_CHAR is from MPI 2.0.
>> MPI standard chapter 5.9.3, says "MPI_CHAR, MPI_WCHAR, and MPI_CHARACTER
>> (which represent printable characters) cannot be used in reduction
>> operations"
>> So Fande's code and Jed's branch have problems. To fix that, we have to
>> add support for signed char, unsigned char, and char in PetscSF.  The first
>> two types support add, mult, logical and bitwise operations. The last is a
>> dumb type, only supports pack/unpack. With this fix, PetscSF/MPI would
>> raise error on Fande's code. I can come up with a fix tomorrow.
>>> On Wed, 3 Apr 2019 at 07:01, Fande Kong via petsc-users <
>>>> Hi All,
>>>> There were some error messages when using PetscSFReduceBegin with
>>>> MPI_CHAR.
>>>> ierr =
>>>> PetscSFReduceBegin(ptap->sf,MPI_CHAR,rmtspace,space,MPI_SUM);CHKERRQ(ierr);
>>>> My question would be: Does PetscSFReduceBegin suppose work with
>>>> MPI_CHAR? If not, should we document somewhere?
>>>> Thanks
>>>> Fande,
>>>> [*0]PETSC ERROR: --------------------- Error Message
>>>> *[0]PETSC ERROR: No support for this operation for this object type*
>>>> *[0]PETSC ERROR: No support for type size not divisible by 4*
>>>> *[0]PETSC ERROR: See
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html
>>>> <http://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.*
>>>> *[0]PETSC ERROR: Petsc Development GIT revision:
>>>> v3.10.4-1989-gd816d1587e  GIT Date: 2019-04-02 17:37:18 -0600*
>>>> *[0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
>>>> *[1]PETSC ERROR: No support for this operation for this object type*
>>>> *[1]PETSC ERROR: No support for type size not divisible by 4*
>>>> *[1]PETSC ERROR: See
>>>> *[1]PETSC ERROR: Petsc Development GIT revision:
>>>> *[1]PETSC ERROR: ./ex90 on a arch-linux2-c-dbg-feature-ptap-all-at-once
>>>> named fn605731.local by kongf Tue Apr  2 21:48:41 2019*
>>>> *[1]PETSC ERROR: Configure options --download-hypre=1
>>>> --with-debugging=yes --with-shared-libraries=1 --download-fblaslapack=1
>>>> --download-metis=1 --download-parmetis=1 --download-superlu_dist=1
>>>> PETSC_ARCH=arch-linux2-c-dbg-feature-ptap-all-at-once --download-ptscotch
>>>> --download-party --download-chaco --with-cxx-dialect=C++11*
>>>> *[1]PETSC ERROR: #1 PetscSFBasicPackTypeSetup() line 678 in
>>>> /Users/kongf/projects/petsc/src/vec/is/sf/impls/basic/sfbasic.c*
>>>> *[1]PETSC ERROR: #2 PetscSFBasicGetPack() line 804 in
>>>> *[1]PETSC ERROR: #3 PetscSFReduceBegin_Basic() line 1024 in
>>>> *./ex90 on a arch-linux2-c-dbg-feature-ptap-all-at-once named
>>>> *[0]PETSC ERROR: Configure options --download-hypre=1
>>>> *[0]PETSC ERROR: #1 PetscSFBasicPackTypeSetup() line 678 in
>>>> *[0]PETSC ERROR: #2 PetscSFBasicGetPack() line 804 in
>>>> *[0]PETSC ERROR: #3 PetscSFReduceBegin_Basic() line 1024 in
>>>> *[0]PETSC ERROR: #4 PetscSFReduceBegin() line 1208 in
>>>> /Users/kongf/projects/petsc/src/vec/is/sf/interface/sf.c*
>>>> *[0]PETSC ERROR: #5 MatPtAPNumeric_MPIAIJ_MPIAIJ_allatonce() line 850
>>>> in /Users/kongf/projects/petsc/src/mat/impls/aij/mpi/mpiptap.c*
>>>> *[0]PETSC ERROR: #6 MatPtAP_MPIAIJ_MPIAIJ() line 202 in
>>>> *[0]PETSC ERROR: #7 MatPtAP() line 9429 in
>>>> /Users/kongf/projects/petsc/src/mat/interface/matrix.c*
>>>> *[0]PETSC ERROR: #8 main() line 58 in
>>>> /Users/kongf/projects/petsc/src/mat/examples/tests/ex90.c*
>>>> *[0]PETSC ERROR: PETSc Option Table entries:*
>>>> *[0]PETSC ERROR: -matptap_via allatonce*
>>>> *[0]PETSC ERROR: ----------------End of Error Message -------send
>>>> entire error message to petsc-maint at mcs.anl.gov
>>>> <petsc-maint at mcs.anl.gov>----------*
>>>> *[1]PETSC ERROR: #4 PetscSFReduceBegin() line 1208 in
>>>> *[1]PETSC ERROR: #5 MatPtAPNumeric_MPIAIJ_MPIAIJ_allatonce() line 850
>>>> *[1]PETSC ERROR: #6 MatPtAP_MPIAIJ_MPIAIJ() line 202 in
>>>> *[1]PETSC ERROR: #7 MatPtAP() line 9429 in
>>>> *[1]PETSC ERROR: #8 main() line 58 in
>>>> *[1]PETSC ERROR: PETSc Option Table entries:*
>>>> *[1]PETSC ERROR: -matptap_via allatonce*
>>>> *[1]PETSC ERROR: ----------------End of Error Message -------send
>>>> *MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD*
>>>> *with errorcode 56.*
>>>> *NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.*
>>>> *You may or may not see output from other processes, depending on*
>>>> *exactly when Open MPI kills them.*
>>>> *[fn605731.local:78133] 1 more process has sent help message
>>>> help-mpi-api.txt / mpi-abort*
>>>> *[fn605731.local:78133] Set MCA parameter "orte_base_help_aggregate" to
>>>> 0 to see all help / error messages*
>>> Lisandro Dalcin
>>> Research Scientist
>>> Extreme Computing Research Center (ECRC)
>>> King Abdullah University of Science and Technology (KAUST)
>>> http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190404/73fea621/attachment.html>
