[petsc-users] Local and global size of IS
Eda Oktay eda.oktay at metu.edu.tr
Tue Apr 2 05:54:38 CDT 2019
Hi Barry,
I did what you said but now I get the error in ISSetPermutation that index
set is not a permutation. ı think it is because since I selected indices on
each process as you said. I did the following, did I understand you wrong:
  PetscMPIInt rank,size;
  MPI_Comm_rank(PETSC_COMM_WORLD, &rank);
  MPI_Comm_size(PETSC_COMM_WORLD, &size);
  PetscInt *idxx,ss;
  ss = siz/size;
  PetscMalloc1(ss,&idxx);
  if (rank != size-1) {
    j =0;
    for (i=rank*ss; i<(rank+1)*ss; i++) {
      idxx[j] = idx[i];
      j++;
  } else {
    j =0;
    for (i=rank*ss; i<siz; i++) {
      idxx[j] = idx[i];
      j++;
Smith, Barry F. <bsmith at mcs.anl.gov>, 31 Mar 2019 Paz, 01:47 tarihinde şunu
yazdı:
> > On Mar 27, 2019, at 7:33 AM, Eda Oktay via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> > Hello,
> > I am trying to permute a matrix A(of size 2n*2n) according to a sorted
> eigenvector vr (of size 2n) in parallel using 2 processors (processor
> number can change).
>     I don't understand your rational for wanting to permute the matrix
> rows/columns based on a sorted eigenvector?
> > However, I get an error in MatPermute line stating that arguments are
> out of range and a new nonzero caused a malloc even if I used MatSetOption.
> > I discovered that this may be because of the unequality of local sizes
> of is (and newIS) and local size of A.
> > Since I allocate index set idx according to size of the vector vr,
> global size of is becomes 2n and the local size is also 2n (I think it
> should be n since both A and vr has local sizes n because of the number of
> processors). If I change the size of idx, then because of VecGetArrayRead,
> I think is is created wrongly.
> > So, how can I make both global and local sizes of is,newIS and A?
> > Below, you can see the part of my program.
> > Thanks,
> > Eda
> >  ierr = VecGetSize(vr,&siz);CHKERRQ(ierr);
> >   ierr = PetscMalloc1(siz,&idx);CHKERRQ(ierr);
> >   for (i=0; i<siz;i++) idx[i] = i;
>    VecGetArray only gives you access to the local portion of the vector,
> not the entire vector so you cannot do the next two lines of code
> >   ierr = VecGetArrayRead(vr,&avr);CHKERRQ(ierr);
>    The sort routine is sequential; it knows nothing about parallelism so
> each process is just sorting its part. Hence this code won't work as
> expected
> >   ierr = PetscSortRealWithPermutation(siz,avr,idx);CHKERRQ(ierr);
>    If you need to sort the parallel vector and get the entire permutation
> then you need to do the following
> 1)   communicate the entire vector to each process, you can use
> VecScatterCreateToAll() for this
> 2)   call VecGetArray on the new vector (that contains all entries on each
> process)
> 3)   Call PetscSortRealWithPermutation() on the entire vector on each
> process
> 4)   select out a piece of the resulting indices idx on each process; for
> example with two processes I think rank = 0 would get the first half of the
> idx and rank = 1 would get the second half.
> >   ierr =
> ISCreateGeneral(PETSC_COMM_SELF,siz,idx,PETSC_COPY_VALUES,&is);CHKERRQ(ierr);
> >   ierr = ISSetPermutation(is);CHKERRQ(ierr);
>   You don't need to duplicate the is, just pass it in twice.
> >   ierr = ISDuplicate(is,&newIS);CHKERRQ(ierr);
>    You should definitely not need the next line. The A matrix is untouched
> by the subroutine call so you don't need to change its allocation options
> MatSetOption(A,MAT_NEW_NONZERO_ALLOCATION_ERR,PETSC_FALSE);CHKERRQ(ierr);
> >   ierr = MatPermute(A,is,newIS,&PL);CHKERRQ(ierr);
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190402/f246a49b/attachment.html>
