[petsc-users] petsc4py - Convert c example code to Python
Nicola Creati ncreati at inogs.it
Mon Apr 1 08:07:16 CDT 2019
Hello,
thanks Barry. I cannot test both codes, C and Python, since the filling
of the Jacobian matrix  get the following Error:
Traceback (most recent call last):
   File "PETSc/petscts.pxi", line 382, in petsc4py.PETSc.TS_IJacobian
   File "ex13.py", line 61, in Jacobian_func
     B.setValueStencil(row, col, value)
   File "PETSc/Mat.pyx", line 948, in petsc4py.PETSc.Mat.setValueStencil
   File "PETSc/petscmat.pxi", line 1100, in
petsc4py.PETSc.matsetvaluestencil
petsc4py.PETSc.Error: error code 63
[0] TSComputeIJacobian() line 912 in
/home/ncreati/Downloads/petsc-3.10.3/src/ts/interface/ts.c
[0] MatSetValuesStencil() line 1576 in
/home/ncreati/Downloads/petsc-3.10.3/src/mat/interface/matrix.c
[0] MatSetValuesLocal() line 2152 in
[0] MatSetValues() line 1349 in
[0] MatSetValues_SeqAIJ() line 477 in
/home/ncreati/Downloads/petsc-3.10.3/src/mat/impls/aij/seq/aij.c
[0] Argument out of range
[0] Inserting a new nonzero at (9,8) in the matrix
The above exception was the direct cause of the following exception:
SystemError: <built-in method insert of list object at 0x7fa47b53c0c8>
returned a result with an error set
Exception ignored in: 'petsc4py.PETSc.traceback'
   File "ex13.py", line 121, in <module>
     ts.solve(u)
   File "PETSc/TS.pyx", line 657, in petsc4py.PETSc.TS.solve
petsc4py.PETSc.Error: error code 73
[0] TSSolve() line 3775 in
[0] TSStep() line 3592 in
[0] TSStep_Theta() line 216 in
/home/ncreati/Downloads/petsc-3.10.3/src/ts/impls/implicit/theta/theta.c
[0] TSTheta_SNESSolve() line 176 in
[0] SNESSolve() line 4397 in
/home/ncreati/Downloads/petsc-3.10.3/src/snes/interface/snes.c
[0] SNESSolve_NEWTONLS() line 224 in
/home/ncreati/Downloads/petsc-3.10.3/src/snes/impls/ls/ls.c
[0] KSPSolve() line 723 in
/home/ncreati/Downloads/petsc-3.10.3/src/ksp/ksp/interface/itfunc.c
[0] KSPSetUp() line 391 in
[0] PCSetUp() line 932 in
/home/ncreati/Downloads/petsc-3.10.3/src/ksp/pc/interface/precon.c
[0] PCSetUp_ILU() line 134 in
/home/ncreati/Downloads/petsc-3.10.3/src/ksp/pc/impls/factor/ilu/ilu.c
[0] MatGetOrdering() line 180 in
/home/ncreati/Downloads/petsc-3.10.3/src/mat/order/sorder.c
[0] Object is in wrong state
[0] Not for unassembled matrix
I believe that my Python conversion is wrong but I cannot figure it out.
Nicola
Nicola Creati
Istituto Nazionale di Oceanografia e di Geofisica Sperimentale - OGS www.inogs.it
Dipartimento di Geofisica della Litosfera Geophysics of Lithosphere Department
CARS (Cartography and Remote Sensing) Research Group http://www.inogs.it/Cars/
Borgo Grotta Gigante 42/c 34010 Sgonico - Trieste - ITALY ncreati at ogs.trieste.it
off.   +39 040 2140 213
fax.   +39 040 327307
_____________________________________________________________________
This communication, that may contain confidential and/or legally privileged information, is intended solely for the use of the intended addressees. Opinions, conclusions and other information contained in this message, that do not relate to the official business of OGS, shall be considered as not given or endorsed by it. Every opinion or advice contained in this communication is subject to the terms and conditions provided by the agreement governing the engagement with such a client. Any use, disclosure, copying or distribution of the contents of this communication by a not-intended recipient or in violation of the purposes of this communication is strictly prohibited and may be unlawful. For Italy only: Ai sensi del D.Lgs.196/2003 - "T.U. sulla Privacy" si precisa che le informazioni contenute in questo messaggio sono riservate ed a uso esclusivo del destinatario.
