[petsc-users] Implementation of Power Iteration method in PETSc
Yingjie Wu
yjwu16 at gmail.com
Wed Sep 26 11:00:56 CDT 2018
Dear Petsc developer:
Thank you very much for your previous reply, they really helped me a lot.
I've been doing neutron calculations recently, and I want to use the power
Iteration method to calculate the neutron flux, essentially to solve linear
equations, but after each solution is done, a scalar *K* is updated to form
a new right end term *b*, and the next linear equation system is solved
until the convergence criterion is satisfied. The flow of the source
iteration algorithm is as follows:
1: *Φ*(0) = arbitrary nonzero vector 2: K(0) = arbitrary nonzero constant
3: *for* n = 1; 2; 3; ::: do 4: *b *= 1 / K(n-1) *F * Φ(n-1) 5: *Φ*(n) * M
= *b* 6: K(n) = k(n-1)* (F * *Φ*(n) ,F *Φ*(n) ) / (F *Φ*(n-1) ,F *Φ*
(n-1) )
7: check convergence of eigenvalue and eigenvector 8: *end for*
(F , M are the coefficient matrix.)
The difficulty is that I need to set up an extra loop to regulate KSP. Does
PETSc have such an example? How do I implement this algorithm in PETsc?
Please tell me the key functions if possible.
Yingjie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180927/d4e57fc1/attachment.html>
