[petsc-users] Checking if a vector is a localvector of a given DMDA
Tue Sep 25 05:55:07 CDT 2018
On Tue, Sep 25, 2018 at 6:49 AM Phil Tooley <phil.tooley at sheffield.ac.uk>
wrote:
> Hi all,
> Given a vector I know I can get an associated DM (if there is one) by
> calling VecGetDM, but I need to also be able to check that
> a) the vector is the localvector of that DM rather than the global
Get a local vector from the DM and check the sizes.
> b) the DM is a DMDA rather than some other subclass
You can do this (PetscObjectTypeCompare), but it is not recommended. Why
would
you want to do that?
     Matt
> I can't immediately see routines that do what I need, but I am likely
> missing something obvious. Is there a way to achieve the above?
> Thanks
> Phil
> Phil Tooley
> Research Software Engineering
> University of Sheffield
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180925/1e8f5879/attachment.html>
