[petsc-users] error make with cude on IBM
Balay, Satish
balay at mcs.anl.gov
Fri Sep 21 09:26:56 CDT 2018
Can you send the corresponding configure.log?
Satish
On Fri, 21 Sep 2018, Mark Adams wrote:
> Thanks, worked. And I get this message, but I set COPTFLAGS="-O2" ...
> WARNING: Using default optimization C flags -O
> You might
> consider manually setting optimal optimization flags for your system with
> COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for
> examples
> On Thu, Sep 20, 2018 at 3:51 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> > > /autofs/nccs-svm1_home1/adams/petsc/include/petscmath.h(389): error:
> > identifier "PETSC_CXX_INLINE" is undefined
> > Somehow nvcc is setting '__cplusplus' flag - and causing he errors..
> > change --with-cxx=0 to --with-cxx=mpicxx
> > Satish
> > On Thu, 20 Sep 2018, Mark Adams wrote:
> > > I am getting this error on SUMMIT.
