[petsc-users] Problem with MPI_Allreduce
Balay, Satish balay at mcs.anl.gov
Tue Sep 18 09:49:21 CDT 2018
This warning will go away if you change the code to:
ierr = MPI_Allreduce(&lamx, &lambdax, 1, MPI_DOUBLE, MPI_MAX, PETSC_COMM_WORLD);CHKERRQ(ierr);
And its best to run code in gdb or valgrind to track down the crash.
Satish
On Tue, 18 Sep 2018, Jed Brown wrote:
> Which compiler version are you using?  This warning is harmless, but we
> should still clean up these macros to avoid the warning.
> Praveen C <cpraveen at gmail.com> writes:
> > Dear all
> > I use MPI_Allreduce in my petsc code and when compiling I see this type of messages
> > /home/soft/include/petsclog.h:376:57: warning: value computed is not used [-Wunused-value]
> >    ((petsc_allreduce_ct += PetscMPIParallelComm(comm),0) || MPI_Allreduce(sendbuf,recvbuf,count,datatype,op,comm))
> > fdweno.c:564:4: note: in expansion of macro ‘MPI_Allreduce’
> > This is with petsc-3.8.3 on Linux.
> > My code crashes due to this error I think,
> This is certainly not why the code crashes.
> > while I dont get this problem on my macbook which uses petsc-3.9.0
> > Since the error is pointing to petsclog.h I thought I will ask here.
> > Thanks
> > praveen
