[petsc-users] DMCreatMatrix preallocation
Oleksandr Koshkarov
olk548 at mail.usask.ca
Mon Sep 17 15:31:26 CDT 2018
Hello All,
I have a question about preallocation of DMDA matrix. As I understand,
it preallocates the number of nonzeros using the stencil width info.
However, it seems it will not be efficient for me: I have a large dof
(around 2000), where only some of those dof's are coupled, so those
dof*dof blocks inside the DMMatrix would be also sparse. I also use this
DMDA matrix as preconditioner, which has lower coupling than original
DMDA array, so stencil is effectively smaller (I precondition higher
order finite volume method with lower order FV method). Can I manually
specify how many zeros needs to be preallocated for the DMDA matrix?
p.s. I do not want o use normal matrix, as I relay on dmda indexing
(MatSetValuesStencil).
Thank you and best regards,
Oleksandr.
