[petsc-users] Retireve eigenvectors from a paralell job/ Spectrum slicing in order to solve big eigenvalue problem
Jose E. Roman jroman at dsic.upv.es
Mon Sep 17 03:47:25 CDT 2018
You need a parallel direct solver such as MUMPS. This is explained in section 3.4.5.
Jose
> El 17 sept 2018, a las 10:41, Jan Grießer <griesser.jan at googlemail.com> escribió:
> def solve_eigensystem(DynMatrix_nn, Unity_nn, Dimension, LowerLimit, UpperLimit):
> 	# Create the EPS solver
> 	E = SLEPc.EPS().create()
> 	# Create the preconditioner and set it to Cholesky
> 	pc = PETSc.PC().create()
> 	pc.setType(pc.Type.CHOLESKY)
> 	# Create the KSP object
> 	ksp = PETSc.KSP().create()
> 	ksp.setType(ksp.Type.PREONLY)
> 	ksp.setPC(pc)
> 	# Set up the spectral transformations
> 	st = SLEPc.ST().create()
> 	st.setType("sinvert")
> 	st.setKSP(ksp)
> 	# Setup spectral transformation
> 	E.setST(st)
> 	# Eigenvalues should be real, therefore we start to order them from the smallest real value |l.real|
> 	E.setWhichEigenpairs(E.Which.ALL)
> 	# Set the interval of spectrum slicing
> 	E.setInterval(LowerLimit, UpperLimit)
> 	# Since the dynamical matrix is symmetric and real it is hermitian. Use GHEP for the spectrum slicing. Operatormatrix B is just a unit matrix
> 	E.setProblemType(SLEPc.EPS.ProblemType.GHEP)
> 	# Use the Krylov Schur method to solve the eigenvalue problem
> 	E.setType(E.Type.KRYLOVSCHUR)
> 	# Partition the Krylov schnur problem in npart procceses
> 	E.setKrylovSchurPartitions(10)
> 	# Set the convergence criterion to relative to the eigenvalue and the maximal number of iterations
> 	E.setConvergenceTest(E.Conv.REL)
> 	E.setTolerances(tol = 1e-7, max_it = 1000)
> 	# Set the matrix in order to solve
> 	E.setOperators(DynMatrix_nn, Unity_nn)
> 	# Sets EPS options from the options database.
> 	E.setFromOptions()
> 	# Sets up all the internal data structures necessary for the execution of the eigensolver.
> 	E.setUp()
> 	# Solve eigenvalue problem
> 	startClock = time.clock()
> 	startTime = time.time()
> 	E.solve()
> Has maybe one of you any idea why this happens and where the problem is ?
> Am Mo., 17. Sep. 2018 um 10:40 Uhr schrieb Jan Grießer <griesser.jan at googlemail.com>:
> I am aware that SLEPc is not supposed to calculate all eigenvalues and eigenvectors, my problem is simply that i want for a physical large enough system all of them before i can make the transition to go to the smallest ones.
> Competitiveness is of secondary importance at the moment.
> But ihave a problem connected with spectrum slicing. I followed the instructions in the manual of Chap. 3.4.5 Spectrum Slicing and converted them to the python package.
> But now i get the following error. It appears to me that it is not able to find the ksp object, but i actually do not know why this is the case.
> aceback (most recent call last):
>   File "Eigensolver_spectrum_slicing.py", line 216, in <module>
>     solve_eigensystem(DynMatrix_nn, Unity_nn, D_nn.shape, opt_dict.LowLimit, opt_dict.UpperLimit)
>   File "Eigensolver_spectrum_slicing.py", line 121, in solve_eigensystem
>     E.setUp()
>   File "SLEPc/EPS.pyx", line 1099, in slepc4py.SLEPc.EPS.setUp
> petsc4py.PETSc.Error: error code 92
> [14] EPSSetUp() line 165 in /tmp/pip-install-golhudw7/slepc/src/eps/interface/epssetup.c
> [14] EPSSetUp_KrylovSchur() line 146 in /tmp/pip-install-golhudw7/slepc/src/eps/impls/krylov/krylovschur/krylovschur.c
> [14] EPSSetUp_KrylovSchur_Slice() line 410 in /tmp/pip-install-golhudw7/slepc/src/eps/impls/krylov/krylovschur/ks-slice.c
> [14] EPSSliceGetEPS() line 300 in /tmp/pip-install-golhudw7/slepc/src/eps/impls/krylov/krylovschur/ks-slice.c
> [14] EPSSetUp_KrylovSchur_Slice() line 461 in /tmp/pip-install-golhudw7/slepc/src/eps/impls/krylov/krylovschur/ks-slice.c
> [14] EPSSliceGetInertia() line 331 in /tmp/pip-install-golhudw7/slepc/src/eps/impls/krylov/krylovschur/ks-slice.c
> [14] STSetUp() line 271 in /tmp/pip-install-golhudw7/slepc/src/sys/classes/st/interface/stsolve.c
> [14] STSetUp_Sinvert() line 132 in /tmp/pip-install-golhudw7/slepc/src/sys/classes/st/impls/sinvert/sinvert.c
> [14] KSPSetUp() line 381 in /tmp/pip-install-xmiaat2t/petsc/src/ksp/ksp/interface/itfunc.c
> [14] PCSetUp() line 923 in /tmp/pip-install-xmiaat2t/petsc/src/ksp/pc/interface/precon.c
> [14] PCSetUp_Cholesky() line 86 in /tmp/pip-install-xmiaat2t/petsc/src/ksp/pc/impls/factor/cholesky/cholesky.c
> [14] MatGetFactor() line 4318 in /tmp/pip-install-xmiaat2t/petsc/src/mat/interface/matrix.c
> [14] See http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html for possible LU and Cholesky solvers
> [14] Could not locate a solver package. Perhaps you must ./configure with --download-<package>
> The code i used to solve the problem is
> Am Fr., 14. Sep. 2018 um 18:34 Uhr schrieb Matthew Knepley <knepley at gmail.com>:
> On Fri, Sep 14, 2018 at 12:19 PM Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 14 sept 2018, a las 17:45, Jan Grießer <griesser.jan at googlemail.com> escribió:
>> Hey there,
>> first i want to say thanks to Satish and Matt for helping with with my last problem with the mpi compilation. I have two questions related to solving a big, hermitian, standard eigenvalue problem using SLEPc4py., compiled with Intel MKL and Intel MPI.
>> - I am using slepc4py with
>> mpi and run it with around -n 20 cores at the moment and how i wanted to ask if there is an easy way to retrieve the eigenvectors? When i run my code and print  for i in range(nconv):
>> 			val = E.
>> getEigenpair(i, vr
>> , vi)
>> 			Print(
>> vr.getArray())
>>  i get the parts of the eigenvectors according to the partition of the matrix. Is there any easy way to put them together in an array and write them to file ? (I am struggling a little bit with the building them in the correct order)
> You need VecScatterCreateToZero. There must be an equivalent in python.
> An alternative to this which you should consider, because it is simpler, is to write the vector to a file
> using some format that PETSc understands, Then you just need vr.view(viewer) for a viewer like
> the binary viewer or some ASCII format you like.
>   Thanks,
>     Matt
>> - I need to solve eigenvalue problems up to a dimension of 100000 degrees of freedom and i need all eigenvalues and eigenvectors. I think solving all eigenvalues in one process is far too much and i thought about if it is possible to apply the spectrum slicing described in Chap. 3.4.5.  Due to the nature of my problem, i am able to simulate smaller systems of 10000 DOF and extract the biggest eigenvalue, which will be the same for larger systems sizes. Is this in general possible since i have a standard HEP problem or is there a better and faster possibility to do this?
> In general, SLEPc is not intended for computing the whole spectrum. You can try with spectrum slicing but this will be competitive if computing just a percentage of eigenvalues, 50% say.
> Jose
>> Thank you very much!
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
