[petsc-users] KSPsolve performance tuning
Edoardo alinovi
edoardo.alinovi at gmail.com
Thu Sep 13 12:58:14 CDT 2018
Hello PETSc's frieds,
It is a couple of weeks that I am trying to enhance the perforamance of my
code. Actually I am solving NS equation for a 3D problem of 220k cells with
4procs on my laptop (i7-7800k @ 2.3Ghz with dynamic overclocking). I have
installed petsc under linux suse 15 in a virtual machine (I do not know if
this is important or not).
After some profiling, I can see that the bottle neck is inside KSPSolve
while solving pressure equation (solved with cg + hypre pc). For this
reason my code is running twice time slower than openFOAM and the gap is
only due the solution of pressure. Have you got some hints for me? At this
point I am sure I am doing something wrong! I have attached the log of a
test simulation.
Thank you very much!
Edoardo Alinovi, Ph.D.
DICCA, Scuola Politecnica
Universita' di Genova
1, via Montallegro
16145 Genova, Italy
email: edoardo.alinovi at dicca.unige.it
Tel: +39 010 353 2540
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180913/e4053248/attachment.html>
Summary of Stages: ----- Time ------ ----- Flop ----- --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total counts %Total Avg %Total counts %Total
0: Main Stage: 5.6276e+00 100.0% 1.4354e+08 100.0% 3.200e+02 100.0% 6.092e+03 100.0% 9.100e+01 91.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flop: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
Avg. len: average message length (bytes)
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %F - percent flop in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
Event Count Time (sec) Flop --- Global --- --- Stage --- Total
Max Ratio Max Ratio Max Ratio Mess Avg len Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
BuildTwoSidedF 23 1.0 5.5043e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
MatMult 30 1.0 3.8755e-02 1.1 1.38e+07 1.0 3.0e+02 6.4e+03 0.0e+00 1 38 94 98 0 1 38 94 98 0 1415
MatSolve 12 1.0 1.8769e-02 1.5 5.45e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 15 0 0 0 0 15 0 0 0 1158
MatLUFactorNum 3 1.0 2.0071e-02 1.4 2.17e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 6 0 0 0 0 6 0 0 0 430
MatILUFactorSym 1 1.0 2.6951e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatConvert 2 1.0 7.3381e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 8.0e+00 0 0 0 0 8 0 0 0 0 9 0
MatAssemblyBegin 10 1.0 5.3159e-02 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 0
MatAssemblyEnd 10 1.0 1.7582e-02 1.1 0.00e+00 0.0 2.0e+01 1.6e+03 1.6e+01 0 0 6 2 16 0 0 6 2 18 0
MatGetRowIJ 5 1.0 1.8690e-06 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatGetOrdering 1 1.0 3.3339e-04 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
MatZeroEntries 8 1.0 3.5194e-03 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecDot 6 1.0 1.1794e-03 1.7 6.22e+05 1.0 0.0e+00 0.0e+00 6.0e+00 0 2 0 0 6 0 2 0 0 7 2105
VecDotNorm2 3 1.0 3.6940e-04 1.5 6.22e+05 1.0 0.0e+00 0.0e+00 3.0e+00 0 2 0 0 3 0 2 0 0 3 6720
VecTDot 32 1.0 2.6084e-03 1.1 3.32e+06 1.0 0.0e+00 0.0e+00 3.2e+01 0 9 0 0 32 0 9 0 0 35 5075
VecNorm 29 1.0 1.9163e-02 1.4 3.01e+06 1.0 0.0e+00 0.0e+00 2.9e+01 0 8 0 0 29 0 8 0 0 32 626
VecCopy 6 1.0 5.6139e-04 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecSet 48 1.0 9.9189e-04 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 35 1.0 3.0097e-03 1.1 3.63e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 10 0 0 0 0 10 0 0 0 4811
VecAYPX 16 1.0 1.2960e-03 1.1 1.56e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 4 0 0 0 0 4 0 0 0 4788
VecAXPBYCZ 6 1.0 7.7555e-04 1.0 1.24e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 3 0 0 0 0 3 0 0 0 6401
VecWAXPY 6 1.0 6.5693e-04 1.1 6.22e+05 1.0 0.0e+00 0.0e+00 0.0e+00 0 2 0 0 0 0 2 0 0 0 3778
VecAssemblyBegin 13 1.0 2.1899e-03 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAssemblyEnd 13 1.0 2.2537e-05 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecScatterBegin 30 1.0 7.9062e-04 1.3 0.00e+00 0.0 3.0e+02 6.4e+03 0.0e+00 0 0 94 98 0 0 0 94 98 0 0
VecScatterEnd 30 1.0 1.8332e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSetUp 8 1.0 4.3321e-04 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 5 1.0 3.3876e+00 1.0 3.46e+07 1.0 2.7e+02 6.4e+03 7.8e+01 60 96 84 89 78 60 96 84 89 86 41
PCSetUp 8 1.0 1.9194e+00 1.0 2.17e+06 1.0 0.0e+00 0.0e+00 8.0e+00 34 6 0 0 8 34 6 0 0 9 5
PCSetUpOnBlocks 3 1.0 2.3208e-02 1.4 2.17e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 6 0 0 0 0 6 0 0 0 372
PCApply 32 1.0 1.4126e+00 1.0 5.45e+06 1.0 0.0e+00 0.0e+00 0.0e+00 25 15 0 0 0 25 15 0 0 0 15
Memory usage is given in bytes:
Object Type Creations Destructions Memory Descendants' Mem.
Reports information only for process 0.
Matrix 6 6 14642324 0.
Vector 31 23 6261400 0.
Krylov Solver 5 3 3816 0.
Preconditioner 5 3 3424 0.
Index Set 5 5 632560 0.
Vec Scatter 1 1 1272 0.
Viewer 1 0 0 0.
Average time to get PetscTime(): 2.87e-08
Average time for MPI_Barrier(): 9.5102e-06
Average time for zero size MPI_Send(): 1.31203e-05
#PETSc Option Table entries:
-log_view
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: FOPTFLAGS=-O3 COPTFLAGS=-O3 CXXOPTFLAGS=-O3 --prefix=/home/edo/software/petsc-3.9.3/ --with-debugging=no --with-mpi-dir=/home/edo/software/openMPI-3.1.1/ --download-fblaslapack=1 --download-superlu_dist --download-mumps --download-hypre --download-metis --download-parmetis --download-scalapack
Libraries compiled on 2018-08-22 10:01:51 on linux-sypg
Machine characteristics: Linux-4.12.14-lp150.11-default-x86_64-with-glibc2.2.5
Using PETSc directory: /home/edo/software/petsc-3.9.3
Using PETSc arch:
Using C compiler: /home/edo/software/openMPI-3.1.1/bin/mpicc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -O3
Using Fortran compiler: /home/edo/software/openMPI-3.1.1/bin/mpif90 -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -O3
Using include paths: -I/home/edo/software/petsc-3.9.3/include -I/home/edo/software/petsc-3.9.3//include -I/home/edo/software/petsc-3.9.3-3.9.3/include -I/home/edo/software/openMPI-3.1.1/include
Using C linker: /home/edo/software/openMPI-3.1.1/bin/mpicc
Using Fortran linker: /home/edo/software/openMPI-3.1.1/bin/mpif90
Using libraries: -Wl,-rpath,/home/edo/software/petsc-3.9.3/lib -L/home/edo/software/petsc-3.9.3/lib -lpetsc -Wl,-rpath,/home/edo/software/petsc-3.9.3/lib -L/home/edo/software/petsc-3.9.3/lib -Wl,-rpath,/home/edo/software/openMPI-3.1.1/lib -L/home/edo/software/openMPI-3.1.1/lib -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/7 -L/usr/lib64/gcc/x86_64-suse-linux/7 -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord -lscalapack -lsuperlu_dist -lHYPRE -lflapack -lfblas -lparmetis -lmetis -lm -lstdc++ -ldl -lmpi_usempif08 -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lstdc++ -ldl
edo at linux-sypg:~/FLUBIO_INC/exec>
