[petsc-users] SNES with constraint diverges
Smith, Barry F.
bsmith at mcs.anl.gov
Wed Sep 12 16:41:47 CDT 2018
> On Sep 12, 2018, at 4:31 PM, Josh L <ysjosh.lo at gmail.com> wrote:
> Barry,
> 0 represents fully damaged and 1 is intact. if I unload it, the crack shouldn't heal(solution goes back to 1), so I set the constraint as
> 0 <= u^{i+1} <= u^{i}
> i is either load step or time step.
Ok, then how do you know that the entire FormFunction() norm will/should even decrease as SNES converges to the DVI solution?
Barry
> Matt,
> Yes, that is what I am going to do next. a linear penalty gives a quadratic distribution instead of the exponential distribution given by quadratic penalty term.
> Thanks,
> Josh
> 2018-09-12 16:23 GMT-05:00 Matthew Knepley <knepley at gmail.com>:
> On Wed, Sep 12, 2018 at 5:16 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> The function norm given by the -snes_monitor is the function norm for the DVI problem (which depends on where the solution is constrained) while FormFunction() norm you compute is for the original unconstrained problem.
> I am still not sure why you solve this as a DVI. If you solve it without the constraints do you get the "wrong" answer?
> If this is a variational crack problem, you can solve it unconstrained if you use a quadratic penalty term. However,
> that induces spurious long range communication between crack tips. If you bound the phase field between 0 and 1,
> you can use a linear penalty which has physical behavior.
> Matt
> Barry
> > On Sep 12, 2018, at 3:32 PM, Josh L <ysjosh.lo at gmail.com> wrote:
> > Hi,
> > my solution is mostly very close to 1. only for a very small area where solution goes from 0 to 1(a smeared crack).
> > I set -snes_atol 1e-7 and it is converging.
> > I've noticed the following:
> > There is a difference between the function norm.
> > I calculate the function norm in FormFunction, so every time it is called it gives the function norm
> > , and the result is different from the function norm given by -snes_monitor if i set
> > SNESSetType(snes,SNESVINEWTONRSLS,ierr)
> > SNESVISetVariableBounds(snes,xl,xu,ierr)
> > The function norm calculated in FromFunction is NOT reducing, however, the function norm given by -snes_monitor is reducing
> > They are the same if I just use regular SNES without setting variable bounds.
> > Thanks,
> > Josh
> > 2018-09-12 12:02 GMT-05:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
> > You have too tight a convergence tolerance for your problem. You can't expect to get more than 1.e-12 as the minimum residual norm or even less.
> > How close is your solution to 1 and -1?
> > If you really need much higher convergence you can try ./configure --with-precision=__float128
> > Barry
> > > On Sep 11, 2018, at 11:53 PM, Josh L <ysjosh.lo at gmail.com> wrote:
> > > Yes, I initialize all u_i to 1.0
> > > 2018-09-11 23:37 GMT-05:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
> > > Do you start with initial conditions of 0 <= u_i <= 1 ?
> > > Run with -snes_monitor -snes_converged_reason -ksp_monitor_true_residual -info -snes_linesearch_monitor and send all the output
> > > Barry
> > > > On Sep 11, 2018, at 11:33 PM, Josh L <ysjosh.lo at gmail.com> wrote:
> > > > Hi,
> > > > I am using SNES to solve an nonlinear equation f(u), and I know all the u_i should be 0 and 1.
> > > > First, I use SNES without constraint, and it converges.
> > > > But, If I set
> > > > where xl and xu is vector, and xl_i=0 and xu_i=1
> > > > then SNES fails to converge, because linesearch fails(snes reason = -6), and the norm of residual is not reducing(the norm of incremental solution is reducing)
> > > > The reason to add constraint is that I want to implement some irreversibility.
> > > > Thanks,
> > > > Josh
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
