[petsc-users] Requesting multi-GPUs
Wed Sep 12 16:38:36 CDT 2018
On Wed, Sep 12, 2018 at 5:31 PM Manuel Valera <mvalera-w at sdsu.edu> wrote:
> Ok then, how can i try getting more than one GPU with the same number of
> MPI processes?
I do not believe we handle more than one GPU per MPI process. Is that what
you are asking?
    Matt
> Thanks,
> On Wed, Sep 12, 2018 at 2:20 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Sep 12, 2018 at 5:13 PM Manuel Valera <mvalera-w at sdsu.edu> wrote:
>>> Hello guys,
>>> I am working in a multi-gpu cluster and i want to request 2 or more
>>> GPUs, how can i do that from PETSc? evidently mpirun -n # is for requesting
>>> processors, but what if i want to use one mpi processor but several GPUs
>>> instead?
>> We do not do that. You would run the same number of MPI processes as
>> GPUs. Note that
>> you can have more than 1 MPI process on a processor.
>>   Matt
>>> Also, i understand the GPU handles the linear system solver, but what
>>> about the data management? can i do DMs for other than the linear solver
>>> using the GPUs
>>> Thanks once more,
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180912/2a0500c6/attachment-0001.html>
