[petsc-users] SNES with constraint diverges
Smith, Barry F. bsmith at mcs.anl.gov
Wed Sep 12 12:02:39 CDT 2018
     You have too tight a convergence tolerance for your problem.  You can't expect to get more than 1.e-12 as the minimum residual norm or even less.
      How close is your solution to 1 and -1?
      If you really need much higher convergence you can try ./configure --with-precision=__float128
      Barry
> On Sep 11, 2018, at 11:53 PM, Josh L <ysjosh.lo at gmail.com> wrote:
> Yes, I initialize all u_i to 1.0
> 2018-09-11 23:37 GMT-05:00 Smith, Barry F. <bsmith at mcs.anl.gov>:
>    Do you start with initial conditions of  0 <= u_i <= 1 ?
>     Run with -snes_monitor -snes_converged_reason -ksp_monitor_true_residual -info -snes_linesearch_monitor and send all the output
>   Barry
> > On Sep 11, 2018, at 11:33 PM, Josh L <ysjosh.lo at gmail.com> wrote:
> > Hi,
> > I am using SNES to solve an nonlinear equation f(u), and I know all the u_i should be 0 and 1.
> > First, I use SNES without constraint, and it converges.
> > But, If I set
> >      SNESSetType(snes,SNESVINEWTONRSLS,ierr)
> >      SNESVISetVariableBounds(snes,xl,xu,ierr)
> > where xl and xu is vector, and xl_i=0 and xu_i=1
> > then SNES fails to converge, because linesearch fails(snes reason = -6), and the norm of residual is not reducing(the norm of incremental solution is reducing)
> > The reason to add constraint is that I want to implement some irreversibility.
> > Thanks,
> > Josh
