[petsc-users] SNES with constraint diverges
Josh L
ysjosh.lo at gmail.com
Tue Sep 11 23:33:45 CDT 2018
I am using SNES to solve an nonlinear equation f(u), and I know all the u_i
should be 0 and 1.
First, I use SNES without constraint, and it converges.
But, If I set
SNESSetType(snes,SNESVINEWTONRSLS,ierr)
SNESVISetVariableBounds(snes,xl,xu,ierr)
where xl and xu is vector, and xl_i=0 and xu_i=1
then SNES fails to converge, because linesearch fails(snes reason = -6),
and the norm of residual is not reducing(the norm of incremental solution
is reducing)
The reason to add constraint is that I want to implement some
irreversibility.
Josh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180911/fe297bf0/attachment.html>
