[petsc-users] TAO with time dependent problem
Josh L
ysjosh.lo at gmail.com
Tue Sep 11 15:51:46 CDT 2018
I am using PETSc TAO to solve the following equation obtained from
minimizing certain energy and constitutive model:
u_xx - u - u_t =0 (1)
For simplicity, the coefficients are neglected.
In the routine to form function value and gradient, I use (1) to form my
gradient vector, and my energy definition to calculate function value.Is it
correct?
I only found one tao example that solves time dependent problem, but it is
using TS which I am not using.
Josh
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180911/70d92c84/attachment.html>
