[petsc-users] Use block Jacobi preconditioner with SNES
Ali Reza Khaz'ali arkhazali at cc.iut.ac.ir
Fri Sep 7 15:22:50 CDT 2018
Thanks a lot. It is working as expected. However, splitting a block
matrix over MPI processes, sometimes results in splitting one block over
2 (or possibly more) processors. It causes the block Jacobi
preconditioner (+Linear solver) to fail. Is there any way in PETSc to
enforce a pre-specified array/matrix distribution over MPI processes? I
want to distribute the array/matrix entries, so that no block is divided
between two MPI processes.
Many Thanks,
Ali
On 9/7/2018 3:06 AM, Smith, Barry F. wrote:
> It is ready in the branch barry/add-mpivpbjacobi; please let me know if you have any difficulties
>     Barry
>> On Sep 6, 2018, at 4:48 PM, arkhazali at cc.iut.ac.ir wrote:
>> Yes, I'd be grateful if MPI support could be added, please.
>> Many thanks,
>> Ali
>> ------ Original message------
>> From: Smith, Barry F.
>> Date: Fri, Sep 7, 2018 01:45
>> To: Ali Reza Khaz'ali;
>> Cc: PETSc;
>> Subject:Re: [petsc-users] Use block Jacobi preconditioner with SNES
>>    I have not yet added this support, do you need it now?
>>     Barry
>>> On Sep 6, 2018, at 4:12 PM, Ali Reza Khaz'ali
>>   wrote:
>>> I have to apologize for making this topic so lengthy. Is vpbjacobi supposed to work in parallel mode (with MPI)?
>>> On 8/30/2018 1:32 AM, Smith, Barry F. wrote:
>>>>> On Aug 29, 2018, at 3:48 PM, Ali Reza Khaz'ali
>>   wrote:
>>>>>>     Can you confirm if your code ran successfully with vpbjacobi and if the convergence history was very similar to that achieved using
>>>>>> bjacobi ?
>>>>> They have a very very very small difference (which is probably due to round-off errors), they generally behave the same. My code run successfully with both of them with the same convergence history. However, vpbjacobi  seems a little faster.
>>>>     Great, this is exactly what to expect. I will put the branch into next for testing and then it will be in the master branch and in the next release.
>>>>     Barry
>>>>> Many thanks,
>>>>> Ali
>>> Ali Reza Khaz’ali
>>> Assistant Professor of Petroleum Engineering,
>>> Department of Chemical Engineering
>>> Isfahan University of Technology
>>> Isfahan, Iran
Ali Reza Khaz’ali
Isfahan, Iran
