[petsc-users] Slepc solver not converging for generalized eigenproblem
Manav Bhatia
bhatiamanav at gmail.com
Fri Sep 7 01:44:19 CDT 2018
I am attempting to compute the eigenvalues of the generalized nonhermitian eigenproblem
M1 x = lambda M0 x
M1 and M0 are in the attached text files. The solver is unable to converge with 300 iterations. I have played around with the max it (as high as 1500) and it still is unable to converge.
What would be the best way to work around this issue?
I would appreciate your help.
Manav
EPS Object: 1 MPI processes
type: krylovschur
50% of basis vectors kept after restart
using the locking variant
problem type: generalized non-symmetric eigenvalue problem
selected portion of the spectrum: smallest eigenvalues in magnitude
number of eigenvalues (nev): 10
number of column vectors (ncv): 50
maximum dimension of projected problem (mpd): 50
maximum number of iterations: 300
tolerance: 1e-08
convergence test: relative to the eigenvalue
BV Object: 1 MPI processes
type: svec
51 columns of global length 178
vector orthogonalization method: classical Gram-Schmidt
orthogonalization refinement: if needed (eta: 0.7071)
block orthogonalization method: GS
doing matmult as a single matrix-matrix product
DS Object: 1 MPI processes
type: nhep
ST Object: 1 MPI processes
type: shift
shift: 0.
number of matrices: 2
all matrices have different nonzero pattern
KSP Object: (st_) 1 MPI processes
type: preonly
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-08, absolute=1e-50, divergence=10000.
left preconditioning
using NONE norm type for convergence test
PC Object: (st_) 1 MPI processes
type: lu
out-of-place factorization
tolerance for zero pivot 2.22045e-14
matrix ordering: nd
factor fill ratio given 0., needed 0.
Factored matrix follows:
Mat Object: 1 MPI processes
type: seqdense
rows=178, cols=178
package used to perform factorization: petsc
total: nonzeros=31684, allocated nonzeros=31684
total number of mallocs used during MatSetValues calls =0
linear system matrix = precond matrix:
type: seqdense
rows=178, cols=178
Linear eigensolve did not converge due to DIVERGED_ITS; iterations 300
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180907/c3290eb3/attachment-0003.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180907/c3290eb3/attachment-0002.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180907/c3290eb3/attachment-0004.html>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180907/c3290eb3/attachment-0003.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180907/c3290eb3/attachment-0005.html>
