[petsc-users] Unable to read in values thru namelist in Fortran after using PETSc 64bit in linux
TAY wee-beng
zonexo at gmail.com
Fri Sep 7 01:44:00 CDT 2018
I found that I am unable to read in values thru namelist in Fortran
after using PETSc 64bit in linux.
I have a parameter txt file which is read in using namelist in Fortran:
namelist /body_input/ no_body, convex_body, motion_type, hover,
wing_config ...
open (unit = 44 , FILE = "ibm3d_input.txt" , status = "old", iostat =
openstatus(4))
if (openstatus(4) > 0) then
print *, "ibm3d_input file not present or wrong filename."
stop
end if
read (44,nml = solver_input)
read (44,nml = grid_input)
read (44,nml = body_input)...
After using PETSc 64bit, my code aborts and I realise that it is because
the values have became NaN. Strangely, it does not occur in windows with
VS2008.
I wonder if it's a bug with the Intel Fortran compiler 2018.
Anyone has similar experience?
Thank you very much.
Yours sincerely,
TAY Wee-Beng (Zheng Weiming) 郑伟明
Personal research webpage: http://tayweebeng.wixsite.com/website
Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
linkedin: www.linkedin.com/in/tay-weebeng
