[petsc-users] Problem compiling with 64bit PETSc
    Randall Mackie
    rlmackie862 at gmail.com
    Wed Sep  5 23:01:40 CDT 2018
You can use PetscMPIInt for integers in MPI calls.
Check petscsys.h for definitions of all of these.
Randy
> On Sep 5, 2018, at 8:56 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> Hi,
> My code has some problems now after converting to 64bit indices.
> After debugging, I realised that I'm using:
> call MPI_ALLGATHER(counter,1,MPI_INTEGER,counter_global,1,MPI_INTEGER,MPI_COMM_WORLD,ierr)
> but now counter and counter_global are both 64bit integers. So should I change all mpi routine from MPI_INTEGER to MPI_INTEGER8?
> But if I switch back to using the 32bit PETSc, do I have to switch back again? In that case, does it mean I need to have 2 copies of my code - one to compile with PETSc 32, another to compile with PETSc 64?
> Is there an easier way?
> Thank you very much.
> Yours sincerely,
> TAY Wee-Beng (Zheng Weiming) 郑伟明
> Personal research webpage: http://tayweebeng.wixsite.com/website <http://tayweebeng.wixsite.com/website>
> Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA <https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA>
> linkedin: www.linkedin.com/in/tay-weebeng <http://www.linkedin.com/in/tay-weebeng>
> On 5/9/2018 6:25 PM, Matthew Knepley wrote:
>> On Wed, Sep 5, 2018 at 3:27 AM TAY wee-beng <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>> On 31/8/2018 10:43 AM, Smith, Barry F. wrote:
>> >> On Aug 30, 2018, at 9:40 PM, TAY wee-beng <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>> >> On 31/8/2018 10:38 AM, Smith, Barry F. wrote:
>> >>>    PetscReal is by default real(8) you can leave those alone
>> >>>     Any integer you pass to a PETSc routine needs to be declared as PetscInt (not integer) otherwise the 64 bit indices stuff won't work.
>> >>>     Barry
>> >> Hi,
>> >> ok, I got it. Btw, is it advisable to change all integer in my code to PetscInt?
>> >> Will it cause any conflict or waste a lot of memory?
>> >> Or should I only change those related to PETSc?
>> >      That is up to you. Since you probably pass the values between PETSc and non-PETSc part of the code it is probably easier just to make all the integer PetscInt instead. No performance difference that you can measure by keeping a few integer around.
>> >      Barry
>> Hi,
>> For some small parts of the code, it is preferred to use integer
>> instead. Btw, to force variable as integer, I can use int(aa). However,
>> I tried to force variable as PetscInt using PetscInt(aa) but it can't work.
>> Is there any way I can make it work?
>> I think you just define a PetscInt variable and use assignment.
>>    Matt
>> Thanks.
>> >> Thanks!
>> >>>> On Aug 30, 2018, at 9:35 PM, TAY wee-beng <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>> >>>> On 31/8/2018 10:21 AM, Matthew Knepley wrote:
>> >>>>> On Thu, Aug 30, 2018 at 10:17 PM TAY wee-beng <zonexo at gmail.com <mailto:zonexo at gmail.com>> wrote:
>> >>>>> Hi,
>> >>>>> Due to my increase grid size, I have to go 64bit. I compiled the 64bit
>> >>>>> PETSc w/o error. However, when I tried to compile my code using the
>> >>>>> 64bit PETSc, I got the error below. May I know why is this so?
>> >>>>> What changes should I make?
>> >>>>> Is it possible that you did not declare some inputs as PetscInt, so the interface check is failing?
>> >>>>>     Matt
>> >>>> Hi,
>> >>>> I'm using the standard
>> >>>> integer ::
>> >>>> real(8) ::
>> >>>> for some variables. For some others relating to PETSc, I use PetscInt.
>> >>>> Should I change all to PetscInt and PetscReal?
>> >>>> Currently, I use real(8) for all real values. If I change all to PetscReal, will PetscReal be real or real(8) by default?
>> >>>> Thanks!
>> >>>>> [tsltaywb at nus02 ibm3d_IIB_mpi]$ make -f makefile_2018
>> >>>>> /app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/bin/mpif90
>> >>>>> -g -ip -ipo -O3 -c -fPIC  -save kinefunc.F90
>> >>>>> -g -ip -ipo -O3 -c -fPIC  -save  -w
>> >>>>> -I/home/users/nus/tsltaywb/propeller/lib/petsc-3.9.3_intel_2018_64bit_rel/include
>> >>>>> -I/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/include
>> >>>>> global.F90
>> >>>>> global.F90(979): error #6285: There is no matching specific subroutine
>> >>>>> for this generic subroutine call.   [DMDACREATE3D]
>> >>>>> call
>> >>>>> DMDACreate3d(MPI_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,size_x,size_y,&
>> >>>>> global.F90(989): error #6285: There is no matching specific subroutine
>> >>>>>       call
>> >>>>> global.F90(997): error #6285: There is no matching specific subroutine
>> >>>>>       call
>> >>>>> global.F90(1005): error #6285: There is no matching specific subroutine
>> >>>>>       call
>> >>>>> global.F90(1013): error #6285: There is no matching specific subroutine
>> >>>>>       call
>> >>>>> global.F90(1021): error #6285: There is no matching specific subroutine
>> >>>>>       call
>> >>>>> global.F90(1029): error #6285: There is no matching specific subroutine
>> >>>>>       call
>> >>>>> compilation aborted for global.F90 (code 1)
>> >>>>> Yours sincerely,
>> >>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> >>>>> -- Norbert Wiener
>> >>>>> https://www.cse.buffalo.edu/~knepley/ <https://www.cse.buffalo.edu/%7Eknepley/>
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/%7Eknepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180905/5e77d176/attachment-0001.html>
