[petsc-users] FIELDSPLIT fields
Rossi, Simone srossi at email.unc.edu
Wed Sep 5 10:46:18 CDT 2018
I’m trying to setup GASM, but I’m probably misunderstanding something.
If I have this mesh
0 —— 1 —— 2 —— 3 —— 4
subdomain 1  |   subdomain 2
I create an interior (no overlap) and an outer (with overlap) IS for both subdomains.
In my naive understanding
iis1  = {0, 1}
ois1 = {0, 1, 2}
and
iis2  = {3, 4}
ois2 = {2, 3, 4}
but then the node at the interface (node 2) does not belong to any interior IS. Should node 2 belong to both interior IS? Or should it belong only to one of the domains?
Simone
On Aug 15, 2018, at 22:11, Griffith, Boyce Eugene <boyceg at email.unc.edu> wrote:
>> On Aug 15, 2018, at 10:07 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>>  Yes you can have "overlapping fields" with FIELDSPLIT but I don't think you can use FIELDSPLIT for your case. You seem to have a geometric decomposition into regions. ASM and GASM are intended for such decompositions. Fieldsplit is for multiple fields that each live across the entire domain.
> Basically there is one field the lives on the entire domain, and another field that lives only on a subdomain.
> Perhaps we could do GASM for the geometric split and FIELDSPLIT within the subdomain with the two fields.
>>  Barry
>>> On Aug 15, 2018, at 7:42 PM, Griffith, Boyce Eugene <boyceg at email.unc.edu> wrote:
>>> Is it permissible to have overlapping fields in FIELDSPLIT? We are specifically thinking about how to handle DOFs living on the interface between two regions.
>>> Thanks!
>>> — Boyce
