[petsc-users] Back tracking/preconditioning with matrix free solvers
Kenneth Hall, SC.D.
kenneth.c.hall at duke.edu
Tue Sep 4 09:07:53 CDT 2018
Hi All,
I am solving a nonlinear problem using a matrix free approach with Petsc. My code is written in Fortran90.
I have read the documentation, and have had some success, but I am having problems with two features.
1. The code runs fine with no preconditioning. But when I using the -user_precond option, my preconditioner never gets called by Petsc, even though I make the appropriate calls to PCSetType and PCShellSetApply.
2. I am using the GMRES solver, which defaults to the L2-norm minimization line search (SNESLINESEARCHL2). I would like to use backtracking (SNESLINESEARCHBT). I have specified backtracking using SNESLineSearchSetType, but I then get the following error:
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: MatMFFDSetBase() has not been called, this is often caused by forgetting to call
MatAssemblyBegin/End on the first Mat in the SNES compute function
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.9.3, Jul, 02, 2018
[0]PETSC ERROR: mustang on a arch-darwin-c-debug-double-real named Macintosh-11.local by hall Tue Sep 4 07:29:25 2018
[0]PETSC ERROR: Configure options --with-scalar-type=real
[0]PETSC ERROR: #1 MatMult_MFFD() line 314 in /Users/hall/Documents/Fortran_Codes/Packages/petsc-3.9.3/src/mat/impls/mffd/mffd.c
[0]PETSC ERROR: #2 MatMult() line 2311 in /Users/hall/Documents/Fortran_Codes/Packages/petsc-3.9.3/src/mat/interface/matrix.c
[0]PETSC ERROR: #3 SNESLineSearchApply_BT() line 130 in /Users/hall/Documents/Fortran_Codes/Packages/petsc-3.9.3/src/snes/linesearch/impls/bt/linesearchbt.c
[0]PETSC ERROR: #4 SNESLineSearchApply() line 645 in /Users/hall/Documents/Fortran_Codes/Packages/petsc-3.9.3/src/snes/linesearch/interface/linesearch.c
[0]PETSC ERROR: #5 SNESSolve_NGMRES() line 262 in /Users/hall/Documents/Fortran_Codes/Packages/petsc-3.9.3/src/snes/impls/ngmres/snesngmres.c
[0]PETSC ERROR: #6 SNESSolve() line 4314 in /Users/hall/Documents/Fortran_Codes/Packages/petsc-3.9.3/src/snes/interface/snes.c
So it appears that Petsc is trying to do a matrix multiply. But this is a matrix free method. How do I fix this?
The relevant code is attached below. Any help with these two issues is greatly appreciated.
Code follows signature. I have omitted non-relavent portions.
Kenneth Hall
module petsc_krylov
use petsc
use data_module
use solution_module
implicit none
#include <petsc/finclude/petscsys.h>
#include <petsc/finclude/petsc.h>
private
public :: gmres2
SNES :: snes ! nonlinear solver
PC :: pc ! preconditioner context
KSP :: ksp ! Krylov subspace method context
SNESLineSearch :: linesearch
Vec :: x,r ! solution, residual vectors
PetscErrorCode :: ierr
PetscInt :: n
integer :: neq
integer :: icount,level=0
contains
subroutine gmres2
implicit none
!.... declare local variables
PetscInt :: its ! iterations for convergence
PetscMPIInt :: rank
PetscBool :: snes_mf,snes_mf_set,user_precond
!.... set problem size
call get_equation_count
n = neq
!.... initialliize petsc
call PetscInitialize(PETSC_NULL_CHARACTER,ierr) ; if (ierr .ne. 0) then ; print*,'Unable to initialize PETSc' ; endif
!.... Create nonlinear solver context
call SNESCreate(PETSC_COMM_WORLD,snes,ierr); CHKERRA(ierr)
call SNESSetType(snes,SNESNGMRES,ierr); CHKERRA(ierr)
call SNESSetTolerances(snes, 0.0, 0.0, 0.0, 20, 10000,ierr); CHKERRQ(ierr)
!.... Create vectors for solution and nonlinear function
call VecCreateSeq(PETSC_COMM_SELF,n,x,ierr); CHKERRA(ierr)
call VecDuplicate(x,r,ierr); CHKERRA(ierr)
!.... Set function evaluation routine and vector
call SNESSetFunction(snes,r,FormFunction,0,ierr); CHKERRA(ierr)
!.... Customize nonlinear solver; set runtime options
snes_mf = PETSC_FALSE;
call PetscOptionsGetBool(PETSC_NULL_OPTIONS,PETSC_NULL_CHARACTER,"-snes_mf",snes_mf,snes_mf_set,ierr); CHKERRA(ierr)
if (snes_mf .eqv. PETSC_TRUE) then
call SNESGetKSP(snes,ksp,ierr); CHKERRA(ierr)
call KSPGetPC(ksp,pc,ierr); CHKERRA(ierr)
call SNESGetLineSearch(snes,linesearch,ierr); CHKERRA(ierr)
call SNESLineSearchSetType(linesearch,SNESLINESEARCHBT, ierr); CHKERRA(ierr)
user_precond = PETSC_FALSE;
call PetscOptionsHasName(PETSC_NULL_OPTIONS,PETSC_NULL_CHARACTER,"-user_precond",user_precond,ierr); CHKERRA(ierr)
if (user_precond .eqv. PETSC_TRUE) then
call PCSetType(pc,PCSHELL,ierr); CHKERRA(ierr)
call PCShellSetApply(pc,MatrixFreePreconditioner,ierr); CHKERRA(ierr)
else
call PCSetType(pc,PCNONE,ierr); CHKERRA(ierr)
end if
end if
!.... set snes options
call SNESSetFromOptions(snes,ierr); CHKERRA(ierr)
!.... initialize solution
call load_x_from_u(x)
!.... solve
call SNESSolve(snes,PETSC_NULL_VEC,x,ierr)
!.... Free work space. All PETSc objects should be destroyed when they are no longer needed.
call VecDestroy(x,ierr)
call VecDestroy(r,ierr)
call SNESDestroy(snes,ierr)
call PetscFinalize(ierr)
end
subroutine MatrixFreePreconditioner(x1,y1)
implicit none
!.... declare passed variables
Vec :: x1,y1 .
end subroutine
subroutine FormFunction(snes,x1,f1,dummy,ierr)
implicit none
SNES :: snes
Vec :: x1,f1,x2
integer :: dummy(*)
end subroutine FormFunction
end module
