[petsc-users] DIVERGED_NANORING with PC GAMG
Thibaut Appel t.appel17 at imperial.ac.uk
Wed Oct 31 13:13:01 CDT 2018
Hi Mark, Matthew,
Thanks for taking the time.
1) You're not suggesting having -fieldsplit_X_ksp_type *f*gmres for each
field, are you?
2) No, the matrix *has* pressure in one of the fields. Here it's a 2D
problem (but we're also doing 3D), the unknowns are (p,u,v) and those
are my 3 fields. We are dealing with subsonic/transsonic flows so it is
convection dominated indeed.
3) We are in frequency domain with respect to time, i.e.
\partial{phi}/\partial{t} = -i*omega*phi.
4) Hypre is unfortunately not an option since we are in complex arithmetic.
> I'm not sure about "-fieldsplit_pc_type gamg" GAMG should work on one
> block, and hence be a subpc. I'm not up on fieldsplit syntax.
According to the online manual page this syntax applies the suffix to
all the defined fields?
> Mark is correct. I wanted you to change the smoother. He shows how to
> change it to Richardson (make sure you add the self-scale option),
> which is probably the best choice.
>   Thanks,
>      Matt
You did tell me to set it to GMRES if I'm not mistaken, that's why I
tried "-fieldsplit_mg_levels_ksp_type gmres" (mentioned in the email).
Also, it wasn't clear whether these should be applied to each block or
the whole system, as the online manual pages + .pdf manual barely
mention smoothers and how to manipulate MG objects with KSP/PC, this
especially with PCFIELDSPLIT where examples are scarce.
 From what I can gather from your suggestions I tried (lines with X are
repeated for X={0,1,2})
-ksp_view_pre -ksp_monitor -ksp_converged_reason \
-ksp_type fgmres -ksp_rtol 1.0e-8 \
-pc_type fieldsplit \
-pc_fieldsplit_type multiplicative \
-pc_fieldsplit_block_size 3 \
-pc_fieldsplit_0_fields 0 \
-pc_fieldsplit_1_fields 1 \
-pc_fieldsplit_2_fields 2 \
-fieldsplit_X_pc_type gamg \
-fieldsplit_X_ksp_type gmres \
-fieldsplit_X_ksp_rtol 1e-10 \
-fieldsplit_X_mg_levels_ksp_type richardson \
-fieldsplit_X_mg_levels_pc_type sor \
-fieldsplit_X_pc_gamg_agg_nsmooths 0 \
-fieldsplit_X_mg_levels_ksp_richardson_self_scale \
-log_view
which yields
KSP Object: 1 MPI processes
   type: fgmres
     restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
     happy breakdown tolerance 1e-30
   maximum iterations=10000, initial guess is zero
   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
   left preconditioning
   using DEFAULT norm type for convergence test
PC Object: 1 MPI processes
   type: fieldsplit
   PC has not been set up so information may be incomplete
     FieldSplit with MULTIPLICATIVE composition: total splits = 3,
blocksize = 3
     Solver info for each split is in the following KSP objects:
   Split number 0 Fields  0
   KSP Object: (fieldsplit_0_) 1 MPI processes
     type: preonly
     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
   PC Object: (fieldsplit_0_) 1 MPI processes
     type not yet set
   Split number 1 Fields  1
   KSP Object: (fieldsplit_1_) 1 MPI processes
     type: preonly
   PC Object: (fieldsplit_1_) 1 MPI processes
     type not yet set
   Split number 2 Fields  2
   KSP Object: (fieldsplit_2_) 1 MPI processes
     type: preonly
   PC Object: (fieldsplit_2_) 1 MPI processes
     type not yet set
   linear system matrix = precond matrix:
   Mat Object: 1 MPI processes
     type: seqaij
     rows=52500, cols=52500
     total: nonzeros=1127079, allocated nonzeros=1128624
     total number of mallocs used during MatSetValues calls =0
       not using I-node routines
   0 KSP Residual norm 3.583290589961e+00
   1 KSP Residual norm 0.000000000000e+00
Linear solve converged due to CONVERGED_ATOL iterations 1
so something must not be set correctly. The solution is identically zero
everywhere.
Is that option list what you meant? If you could let me know what should
be corrected.
Thanks for your support,
Thibaut
On 31/10/2018 16:43, Mark Adams wrote:
> On Tue, Oct 30, 2018 at 5:23 PM Appel, Thibaut via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>     Dear users,
>     Following a suggestion from Matthew Knepley I’ve been trying to
>     apply fieldsplit/gamg for my set of PDEs but I’m still
>     encountering issues despite various tests. pc_gamg simply won’t start.
>     Note that direct solvers always yield the correct, physical result.
>     Removing the fieldsplit to focus on the gamg bit and trying to
>     solve the linear system on a modest size problem still gives, with
>     '-ksp_monitor -ksp_rtol 1.0e-10 -ksp_gmres_restart 300 -ksp_type
>     gmres -pc_type gamg'
>     [3]PETSC ERROR: --------------------- Error Message
>     [3]PETSC ERROR: Petsc has generated inconsistent data
>     [3]PETSC ERROR: Have un-symmetric graph (apparently). Use
>     '-(null)pc_gamg_sym_graph true' to symetrize the graph or
>     '-(null)pc_gamg_threshold -1' if the matrix is structurally symmetric.
>     And since then, after adding '-pc_gamg_sym_graph true' I have been
>     getting
>     [0]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: Petsc has generated inconsistent data
>     [0]PETSC ERROR: Eigen estimator failed: DIVERGED_NANORINF at iteration
>     -ksp_chebyshev_esteig_noisy 0/1 does not change anything
>     Knowing that Chebyshev eigen estimator needs a positive spectrum I
>     tried ‘-mg_levels_ksp_type gmres’ but iterations would just go on
>     endlessly.
> This is OK, but you need to use '-ksp_type *f*gmres' (this could be
> why it is failing ...).
> It looks like your matrix is 1) just the velocity field and 2) very
> unsymmetric (eg, convection dominated). I would start with
> ‘-mg_levels_ksp_type richardson -mg_levels_pc_type sor’.
> I would also start with unsmoothed aggregation: '-pc_gamg_nsmooths 0'
>     It seems that I have indeed eigenvalues of rather high magnitude
>     in the spectrum of my operator without being able to determine the
>     reason.
>     The eigenvectors look like small artifacts at the wall-inflow or
>     wall-outflow corners with zero anywhere else but I do not know how
>     to interpret this.
>     Equations are time-harmonic linearized Navier-Stokes to which a
>     forcing is applied, there’s no time-marching.
> You mean you are in frequency domain?
>     Matrix is formed with a MPIAIJ type. The formulation is
>     incompressible, in complex arithmetic and the 2D physical domain
>     is mapped to a logically rectangular,
> This kind of messes up the null space that AMG depends on but AMG
> theory is gone for NS anyway.
>     regular collocated grid with a high-order finite difference method.
>     I determine the ownership of the rows/degrees of freedom of the
>     matrix with PetscSplitOwnership and I’m not using DMDA.
> Our iterative solvers are probably not going to work well on this but
> you should test hypre also (-pc_type hypre -pc_hypre_type boomeramg).
> You need to configure PETSc to download hypre.
> Mark
>     The Fortran application code is memory-leak free and has undergone
>     a strict verification/validation procedure for different
>     variations of the PDEs.
>     If there’s any problem with the matrix what could help for the
>     diagnostic? At this point I’m running out of ideas so I would
>     really appreciate additional suggestions and discussions.
>     Thanks for your continued support,
>     Thibaut
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181031/9773939a/attachment-0001.html>
