[petsc-users] DIVERGED_NANORING with PC GAMG
Wed Oct 31 11:57:36 CDT 2018
On Wed, Oct 31, 2018 at 9:14 AM Thibaut Appel <t.appel17 at imperial.ac.uk>
wrote:
> Hi Matthew,
> Which database option are you referring to?
> I tried to add -fieldsplit_mg_levels_ksp_type gmres (and
> -fieldsplit_mg_levels_ksp_max_it 4 for another run) to my options (cf.
> below) which starts the iterations but it takes 1 hour for PETSc to do 13
> of them so it must be wrong.
> Mark is correct. I wanted you to change the smoother. He shows how to
change it to Richardson (make sure you add the self-scale option), which is
probably the best choice.
     Matt
> Reminder: my baseline database options line reads
> -ksp_view_pre -ksp_monitor -ksp_converged_reason \
> -ksp_rtol 1.0e-8 -ksp_gmres_restart 300 \
> -ksp_type fgmres \
> -pc_type fieldsplit \
> -pc_fieldsplit_type multiplicative \
> -pc_fieldsplit_block_size 3 \
> -pc_fieldsplit_0_fields 0   \
> -pc_fieldsplit_1_fields 1   \
> -pc_fieldsplit_2_fields 2   \
> -fieldsplit_pc_type gamg    \
> -fieldsplit_ksp_type gmres  \
> -fieldsplit_ksp_rtol 1.0e-8
> which gives
> KSP Object: 1 MPI processes
>   type: fgmres
>     restart=300, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
>   left preconditioning
>   using DEFAULT norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>   PC has not been set up so information may be incomplete
>     FieldSplit with MULTIPLICATIVE composition: total splits = 3,
> blocksize = 3
>     Solver info for each split is in the following KSP objects:
>   Split number 0 Fields  0
>   KSP Object: (fieldsplit_0_) 1 MPI processes
>     type: preonly
>     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>   PC Object: (fieldsplit_0_) 1 MPI processes
>     type not yet set
>   Split number 1 Fields  1
>   KSP Object: (fieldsplit_1_) 1 MPI processes
>     type: preonly
>   PC Object: (fieldsplit_1_) 1 MPI processes
>     type not yet set
>   Split number 2 Fields  2
>   KSP Object: (fieldsplit_2_) 1 MPI processes
>     type: preonly
>   PC Object: (fieldsplit_2_) 1 MPI processes
>     type not yet set
>   linear system matrix = precond matrix:
>   Mat Object: 1 MPI processes
>     type: seqaij
>     rows=52500, cols=52500
>     total: nonzeros=1127079, allocated nonzeros=1128624
>     total number of mallocs used during MatSetValues calls =0
>       not using I-node routines
>   0 KSP Residual norm 3.583290589961e+00
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: Eigen estimator failed: DIVERGED_NANORINF at iteration
> 0[0]PETSC ERROR: Petsc Release Version 3.10.2, unknown
> [0]PETSC ERROR: Configure options --PETSC_ARCH=msi_cplx_debug
> --with-scalar-type=complex --with-precision=double --with-debugging=1
> --with-valgrind=1 --with-debugger=gdb --with-fortran-kernels=1
> --download-mpich --download-hwloc --download-fblaslapack
> --download-scalapack --download-metis --download-parmetis
> --download-ptscotch --download-mumps --download-slepc
> [0]PETSC ERROR: #1 KSPSolve_Chebyshev() line 381 in
> /home/thibaut/Packages/petsc/src/ksp/ksp/impls/cheby/cheby.c
> [0]PETSC ERROR: #2 KSPSolve() line 780 in
> /home/thibaut/Packages/petsc/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #3 PCMGMCycle_Private() line 20 in
> /home/thibaut/Packages/petsc/src/ksp/pc/impls/mg/mg.c
> [0]PETSC ERROR: #4 PCApply_MG() line 377 in
> [0]PETSC ERROR: #5 PCApply() line 462 in
> /home/thibaut/Packages/petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #6 KSP_PCApply() line 281 in
> /home/thibaut/Packages/petsc/include/petsc/private/kspimpl.h
> [0]PETSC ERROR: #7 KSPInitialResidual() line 67 in
> /home/thibaut/Packages/petsc/src/ksp/ksp/interface/itres.c
> [0]PETSC ERROR: #8 KSPSolve_GMRES() line 233 in
> /home/thibaut/Packages/petsc/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: #9 KSPSolve() line 780 in
> [0]PETSC ERROR: #10 PCApply_FieldSplit() line 1107 in
> /home/thibaut/Packages/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> [0]PETSC ERROR: #11 PCApply() line 462 in
> [0]PETSC ERROR: #12 KSP_PCApply() line 281 in
> [0]PETSC ERROR: #13 KSPFGMRESCycle() line 166 in
> /home/thibaut/Packages/petsc/src/ksp/ksp/impls/gmres/fgmres/fgmres.c
> [0]PETSC ERROR: #14 KSPSolve_FGMRES() line 291 in
> [0]PETSC ERROR: #15 KSPSolve() line 780 in
> Thibaut
> On 30/10/2018 23:12, Matthew Knepley wrote:
> On Tue, Oct 30, 2018 at 5:21 PM Appel, Thibaut via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Dear users,
>> Following a suggestion from Matthew Knepley I’ve been trying to apply
>> fieldsplit/gamg for my set of PDEs but I’m still encountering issues
>> despite various tests. pc_gamg simply won’t start.
>> Note that direct solvers always yield the correct, physical result.
>> Removing the fieldsplit to focus on the gamg bit
> This is a mistake I think because you want a simpler operator to try GAMG
> on.
> Can you go back to splitting the system, and try using GMRES as the
> smoother. Its important to see
> whether the smoother makes no progress, or the coarse correction stinks.
>   Thanks,
>      Matt
>> and trying to solve the linear system on a modest size problem still
>> gives, with
>> '-ksp_monitor -ksp_rtol 1.0e-10 -ksp_gmres_restart 300 -ksp_type gmres
>> -pc_type gamg'
>> [3]PETSC ERROR: --------------------- Error Message
>> [3]PETSC ERROR: Petsc has generated inconsistent data
>> [3]PETSC ERROR: Have un-symmetric graph (apparently). Use
>> '-(null)pc_gamg_sym_graph true' to symetrize the graph or
>> '-(null)pc_gamg_threshold -1' if the matrix is structurally symmetric.
>> And since then, after adding '-pc_gamg_sym_graph true' I have been getting
>> -ksp_chebyshev_esteig_noisy 0/1 does not change anything
>> Knowing that Chebyshev eigen estimator needs a positive spectrum I tried
>> ‘-mg_levels_ksp_type gmres’ but iterations would just go on endlessly.
>> It seems that I have indeed eigenvalues of rather high magnitude in the
>> spectrum of my operator without being able to determine the reason.
>> The eigenvectors look like small artifacts at the wall-inflow or
>> wall-outflow corners with zero anywhere else but I do not know how to
>> interpret this.
>> Equations are time-harmonic linearized Navier-Stokes to which a forcing
>> is applied, there’s no time-marching.
>> Matrix is formed with a MPIAIJ type. The formulation is incompressible,
>> in complex arithmetic and the 2D physical domain is mapped to a logically
>> rectangular, regular collocated grid with a high-order finite difference
>> method.
>> I determine the ownership of the rows/degrees of freedom of the matrix
>> with PetscSplitOwnership and I’m not using DMDA.
>> The Fortran application code is memory-leak free and has undergone a
>> strict verification/validation procedure for different variations of the
>> PDEs.
>> If there’s any problem with the matrix what could help for the
>> diagnostic? At this point I’m running out of ideas so I would really
>> appreciate additional suggestions and discussions.
>> Thanks for your continued support,
>> Thibaut
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181031/dda1fa9b/attachment.html>
