[petsc-users] Convergence of AMG
Mark Adams
mfadams at lbl.gov
Mon Oct 29 08:28:02 CDT 2018
I would recommend using '-mg_levels 2' and check that that gives you two
levels. I would also run this on one processor just to start.
Use -mg_levels_ksp_max_it 4. And '-pc_gamg_threshold 0.04'
These parameters are meant to increase convergence rate at all costs. Once
we our best rate we should be able to back off of some of this without much
degradation or play around with the parameters to optimize run time.
On Sun, Oct 28, 2018 at 5:13 PM Manav Bhatia <bhatiamanav at gmail.com> wrote:
> Var: 0,…,5 are the 6 variables that I am solving for: u, v, w, theta_x,
> theta_y, theta_z.
> The norms identified in my email are the L2 norms of all dofs
> corresponding to each variable in the solution vector. So, var: 0: u: norm
> is the L2 norm of the dofs for u only, and so on.
> I expect u, v, theta_z to be zero for the solution, which ends up being
> the case.
> If I plot the solution, they look sensible, but the reduction of KSP norm
> is slow.
> Thanks,
> Manav
> On Oct 28, 2018, at 3:55 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> On Oct 28, 2018, at 12:16 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> Hi,
> I am attempting to solve a Mindlin plate bending problem with AMG solver
> in petsc. This test case is with a mesh of 300x300 elements and 543,606
> dofs.
> The discretization includes 6 variables (u, v, w, tx, ty, tz), but only
> three are relevant for plate bending (w, tx, ty).
> I am calling the solver with the following options:
> -pc_type gamg -pc_gamg_threshold 0. --node-major-dofs -mat_block_size 6
> -ksp_rtol 1.e-8 -ksp_monitor -ksp_converged_reason -ksp_view
> And the convergence behavior is shown below, along with the ksp_view
> information. Based on notes in the manual, this seems to be subpar
> convergence rate. At the end of the solution the norm of each variable is :
> var: 0: u : norm: 5.505909e-18
> var: 1: v : norm: 7.639640e-18
> var: 2: w : norm: 3.901464e-03
> var: 3: tx : norm: 4.403576e-02
> var: 4: ty : norm: 4.403576e-02
> var: 5: tz : norm: 1.148409e-16
> What do you mean by var: 2: w : norm etc? Is this the norm of the error
> for that variable, the norm of the residual, something else? How exactly
> are you calculating it?
> Thanks
> Barry
> I tried different values of -ksp_rtol from 1e-1 to 1e-8 and this does not
> make a lot of difference in the norms of (w, tx, ty).
> I do provide the solver with 6 rigid-body vectors to approximate the
> null-space of the problem. Without these the solver shows very poor
> convergence.
> I would appreciate advice on possible strategies to improve this behavior.
> Thanks,
> Manav
> 0 KSP Residual norm 1.696304497261e+00
> 1 KSP Residual norm 1.120485505777e+00
> 2 KSP Residual norm 8.324222302402e-01
> 3 KSP Residual norm 6.477349534115e-01
> 4 KSP Residual norm 5.080936471292e-01
> 5 KSP Residual norm 4.051099646638e-01
> 6 KSP Residual norm 3.260432664653e-01
> 7 KSP Residual norm 2.560483838143e-01
> 8 KSP Residual norm 2.029943986124e-01
> 9 KSP Residual norm 1.560985741610e-01
> 10 KSP Residual norm 1.163720702140e-01
> 11 KSP Residual norm 8.488411085459e-02
> 12 KSP Residual norm 5.888041729034e-02
> 13 KSP Residual norm 4.027792209980e-02
> 14 KSP Residual norm 2.819048087304e-02
> 15 KSP Residual norm 1.904674196962e-02
> 16 KSP Residual norm 1.289302447822e-02
> 17 KSP Residual norm 9.162203296376e-03
> 18 KSP Residual norm 7.016781679507e-03
> 19 KSP Residual norm 5.399170865328e-03
> 20 KSP Residual norm 4.254385887482e-03
> 21 KSP Residual norm 3.530831740621e-03
> 22 KSP Residual norm 2.946780747923e-03
> 23 KSP Residual norm 2.339361361128e-03
> 24 KSP Residual norm 1.815072489282e-03
> 25 KSP Residual norm 1.408814185342e-03
> 26 KSP Residual norm 1.063795714320e-03
> 27 KSP Residual norm 7.828540233117e-04
> 28 KSP Residual norm 5.683910750067e-04
> 29 KSP Residual norm 4.131151010250e-04
> 30 KSP Residual norm 3.065608221019e-04
> 31 KSP Residual norm 2.634114273459e-04
> 32 KSP Residual norm 2.198180137626e-04
> 33 KSP Residual norm 1.748956510799e-04
> 34 KSP Residual norm 1.317539710010e-04
> 35 KSP Residual norm 9.790121566055e-05
> 36 KSP Residual norm 7.465935386094e-05
> 37 KSP Residual norm 5.689506626052e-05
> 38 KSP Residual norm 4.413136619126e-05
> 39 KSP Residual norm 3.512194236402e-05
> 40 KSP Residual norm 2.877755408287e-05
> 41 KSP Residual norm 2.340080556431e-05
> 42 KSP Residual norm 1.904544450345e-05
> 43 KSP Residual norm 1.504723478235e-05
> 44 KSP Residual norm 1.141381950576e-05
> 45 KSP Residual norm 8.206151384599e-06
> 46 KSP Residual norm 5.911426091276e-06
> 47 KSP Residual norm 4.233669089283e-06
> 48 KSP Residual norm 2.898052944223e-06
> 49 KSP Residual norm 2.023556779973e-06
> 50 KSP Residual norm 1.459108043935e-06
> 51 KSP Residual norm 1.097335545865e-06
> 52 KSP Residual norm 8.440457332262e-07
> 53 KSP Residual norm 6.705616854004e-07
> 54 KSP Residual norm 5.404888680234e-07
> 55 KSP Residual norm 4.391368084979e-07
> 56 KSP Residual norm 3.697063014621e-07
> 57 KSP Residual norm 3.021772094146e-07
> 58 KSP Residual norm 2.479354520792e-07
> 59 KSP Residual norm 2.013077841968e-07
> 60 KSP Residual norm 1.553159612793e-07
> 61 KSP Residual norm 1.400784224898e-07
> 62 KSP Residual norm 9.707453662195e-08
> 63 KSP Residual norm 7.263173080146e-08
> 64 KSP Residual norm 5.593723572132e-08
> 65 KSP Residual norm 4.448788809586e-08
> 66 KSP Residual norm 3.613992590778e-08
> 67 KSP Residual norm 2.946099051876e-08
> 68 KSP Residual norm 2.408053564170e-08
> 69 KSP Residual norm 1.945257374856e-08
> 70 KSP Residual norm 1.572494535110e-08
> KSP Object: 4 MPI processes
> type: gmres
> restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization
> with no iterative refinement
> happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-08, absolute=1e-50, divergence=10000.
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object: 4 MPI processes
> type: gamg
> type is MULTIPLICATIVE, levels=6 cycles=v
> Cycles per PCApply=1
> Using externally compute Galerkin coarse grid matrices
> GAMG specific options
> Threshold for dropping small values in graph on each level = 0.
> 0. 0. 0.
> Threshold scaling factor for each level not specified = 1.
> AGG specific options
> Symmetric graph false
> Number of levels to square graph 1
> Number smoothing steps 1
> Coarse grid solver -- level -------------------------------
> KSP Object: (mg_coarse_) 4 MPI processes
> type: preonly
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> using NONE norm type for convergence test
> PC Object: (mg_coarse_) 4 MPI processes
> type: bjacobi
> number of blocks = 4
> Local solve is same for all blocks, in the following KSP and PC
> objects:
> KSP Object: (mg_coarse_sub_) 1 MPI processes
> type: preonly
> maximum iterations=1, initial guess is zero
> PC Object: (mg_coarse_sub_) 1 MPI processes
> type: lu
> out-of-place factorization
> tolerance for zero pivot 2.22045e-14
> using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
> matrix ordering: nd
> factor fill ratio given 5., needed 1.
> Factored matrix follows:
> Mat Object: 1 MPI processes
> type: seqaij
> rows=6, cols=6, bs=6
> package used to perform factorization: petsc
> total: nonzeros=36, allocated nonzeros=36
> total number of mallocs used during MatSetValues calls =0
> using I-node routines: found 2 nodes, limit used is 5
> linear system matrix = precond matrix:
> type: seqaij
> Mat Object: 4 MPI processes
> type: mpiaij
> using nonscalable MatPtAP() implementation
> using I-node (on process 0) routines: found 2 nodes, limit used
> is 5
> Down solver (pre-smoother) on level 1 -------------------------------
> KSP Object: (mg_levels_1_) 4 MPI processes
> type: chebyshev
> eigenvalue estimates used: min = 0.099971, max = 1.09968
> eigenvalues estimate via gmres min 0.154032, max 0.99971
> eigenvalues estimated using gmres with translations [0. 0.1; 0.
> 1.1]
> KSP Object: (mg_levels_1_esteig_) 4 MPI processes
> type: gmres
> Orthogonalization with no iterative refinement
> maximum iterations=10, initial guess is zero
> tolerances: relative=1e-12, absolute=1e-50, divergence=10000.
> estimating eigenvalues using noisy right hand side
> maximum iterations=2, nonzero initial guess
> PC Object: (mg_levels_1_) 4 MPI processes
> type: sor
> type = local_symmetric, iterations = 1, local iterations = 1, omega
> = 1.
> type: mpiaij
> rows=54, cols=54, bs=6
> total: nonzeros=2916, allocated nonzeros=2916
> using I-node (on process 0) routines: found 11 nodes, limit used
> is 5
> Up solver (post-smoother) same as down solver (pre-smoother)
> Down solver (pre-smoother) on level 2 -------------------------------
> KSP Object: (mg_levels_2_) 4 MPI processes
> type: chebyshev
> eigenvalue estimates used: min = 0.171388, max = 1.88526
> eigenvalues estimate via gmres min 0.0717873, max 1.71388
> 1.1]
> KSP Object: (mg_levels_2_esteig_) 4 MPI processes
> type: gmres
> PC Object: (mg_levels_2_) 4 MPI processes
> type: sor
> = 1.
> type: mpiaij
> rows=642, cols=642, bs=6
> total: nonzeros=99468, allocated nonzeros=99468
> using I-node (on process 0) routines: found 47 nodes, limit used
> is 5
> Down solver (pre-smoother) on level 3 -------------------------------
> KSP Object: (mg_levels_3_) 4 MPI processes
> type: chebyshev
> eigenvalue estimates used: min = 0.164216, max = 1.80637
> eigenvalues estimate via gmres min 0.0376323, max 1.64216
> 1.1]
> KSP Object: (mg_levels_3_esteig_) 4 MPI processes
> type: gmres
> PC Object: (mg_levels_3_) 4 MPI processes
> type: sor
> = 1.
> type: mpiaij
> rows=6726, cols=6726, bs=6
> total: nonzeros=941796, allocated nonzeros=941796
> using I-node (on process 0) routines: found 552 nodes, limit used
> is 5
> Down solver (pre-smoother) on level 4 -------------------------------
> KSP Object: (mg_levels_4_) 4 MPI processes
> type: chebyshev
> eigenvalue estimates used: min = 0.163283, max = 1.79611
> eigenvalues estimate via gmres min 0.0350306, max 1.63283
> 1.1]
> KSP Object: (mg_levels_4_esteig_) 4 MPI processes
> type: gmres
> PC Object: (mg_levels_4_) 4 MPI processes
> type: sor
> = 1.
> type: mpiaij
> rows=41022, cols=41022, bs=6
> total: nonzeros=2852316, allocated nonzeros=2852316
> using I-node (on process 0) routines: found 3432 nodes, limit
> used is 5
> Down solver (pre-smoother) on level 5 -------------------------------
> KSP Object: (mg_levels_5_) 4 MPI processes
> type: chebyshev
> eigenvalue estimates used: min = 0.157236, max = 1.7296
> eigenvalues estimate via gmres min 0.0317897, max 1.57236
> 1.1]
> KSP Object: (mg_levels_5_esteig_) 4 MPI processes
> type: gmres
> PC Object: (mg_levels_5_) 4 MPI processes
> type: sor
> = 1.
> Mat Object: () 4 MPI processes
> type: mpiaij
> rows=543606, cols=543606, bs=6
> total: nonzeros=29224836, allocated nonzeros=29302596
> has attached near null space
> using I-node (on process 0) routines: found 45644 nodes, limit
> used is 5
> type: mpiaij
> using I-node (on process 0) routines: found 45644 nodes, limit used
> is 5
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181029/c32de421/attachment-0001.html>
