[petsc-users] [petsc-maint] How to impose boundary conditions using DMDA
Smith, Barry F. bsmith at mcs.anl.gov
Sun Oct 28 11:18:21 CDT 2018
    Matt,
       How difficult would it be to impose such boundary conditions with DMPlex? Presumably you just connect the mesh up "properly" and it is straightforward?
   Barry
> On Oct 27, 2018, at 10:23 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Oct 27, 2018 at 2:02 AM Fengwen Wang <fwan at mek.dtu.dk> wrote:
> Dear Colleagues,
> I use the finite element method to solve my problem in Petsc.
> Mesh is defined as a  regular mesh using DMDA.  I have a special boundary condition which I  do not know how to impose it in Petsc.
> In a 2D problem, the domain is unit size, two degrees of freedom per node (u, v). I would like impose the following boundary condition:
> u(x=1) = -v ( y=1) and v(x=1 )= -u (y=1) .
> How can I impose such a boundary condition in Petsc?
> In a serial code, you could do this just by equating those variables, but in parallel we have no support for such a boundary condition.
>   Thanks,
>      Matt
> Thanks a lot.
> Best regards
> Fengwen
> ____________________________________________________
> Senior Researcher
> Department of Mechanical Engineering, DTU
> Nils Koppels Allé
> Building 404
> 2800  Kgs. Lyngby
> fwan at mek.dtu.dk
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
