[petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
Balay, Satish balay at mcs.anl.gov
Thu Oct 25 20:29:23 CDT 2018
Testing Matlab at /Applications/MATLAB_R2018a.app
Executing: /Applications/MATLAB_R2018a.app/bin/matlab -nojvm -nodisplay -r "display(['Version ' version]); exit"
stdout:
< M A T L A B (R) >
                  Copyright 1984-2018 The MathWorks, Inc.
                   R2018a (9.4.0.813654) 64-bit (maci64)
                             February 23, 2018
For online documentation, see http://www.mathworks.com/support
For product information, visit www.mathworks.com.
Version 9.4.0.813654 (R2018a)
WARNING: Found Matlab at /Applications/MATLAB_R2018a.app but unable to run
So configure attempted to run Matlab - and perhaps got an error. What do you get if you run this manually?
echo $?
Satish
On Fri, 26 Oct 2018, avatar wrote:
> Hi Satish,
> The attached is the whole configure.log file. I could not past it here because it is too big and crash my webpage. I could not use the latest version right now, because the project is maintained by other people. If I update petsc, I will break the whole project. But we will use the latest version when the maintenance guys update the dependences.
> Thank you.
> ------------------ Original ------------------
> From:  "Balay, Satish";<balay at mcs.anl.gov>;
> Date:  Oct 26, 2018
> To:  "avatar"<648934229 at qq.com>;
> Cc:  "petsc-users"<petsc-users at mcs.anl.gov>;
> Subject:  Re: [petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
> 1. You need to send us the complete log.
> 2. Also use current release - petsc-3.10 [not 3.8]
> Satish
> > Scott-Grad-MBP:petsc-3.8.3 zhihui$ ./configure --with-matlab-dir=/Applications/MATLAB_R2018a.app/
> >              Configuring PETSc to compile on your system
> > TESTING: configureLibrary from config.packages.Matlab(config/BuildSystem/config/*******************************************************************************
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> > You set a value for --with-matlab-dir, but /Applications/MATLAB_R2018a.app cannot be used
> > Part of the log file as follow
> > #ifndef PETSC_HAVE_MPI_REDUCE_SCATTER
> > #define PETSC_HAVE_MPI_REDUCE_SCATTER 1
> > #endif
> > #ifndef PETSC_HAVE_MPI_COMBINER_DUP
> > #define PETSC_HAVE_MPI_COMBINER_DUP 1
> > #endif
> > #ifndef PETSC_HAVE_MPIIO
> > #define PETSC_HAVE_MPIIO 1
> > #endif
> > #ifndef PETSC_HAVE_MPI_COMM_SPAWN
> > #define PETSC_HAVE_MPI_COMM_SPAWN 1
> > #endif
> > #ifndef PETSC_HAVE_MPI_FINT
> > #define PETSC_HAVE_MPI_FINT 1
> > #endif
> > #ifndef PETSC_HAVE_MPI_IBARRIER
> > #define PETSC_HAVE_MPI_IBARRIER 1
> > #endif
> > #ifndef PETSC_HAVE_MPI_ALLTOALLW
> > #define PETSC_HAVE_MPI_ALLTOALLW 1
> > #endif
> > #ifndef PETSC_HAVE_OMPI_RELEASE_VERSION
> > #define PETSC_HAVE_OMPI_RELEASE_VERSION 2
> > #endif
> > #ifndef PETSC_HAVE_MPI_REDUCE_LOCAL
> > #define PETSC_HAVE_MPI_REDUCE_LOCAL 1
> > #endif
> > #ifndef PETSC_HAVE_MPI_REPLACE
> > #define PETSC_HAVE_MPI_REPLACE 1
> > #endif
> > #ifndef PETSC_HAVE_MPI_EXSCAN
> > #define PETSC_HAVE_MPI_EXSCAN 1
> > #endif
> > #ifndef PETSC_HAVE_MPI_C_DOUBLE_COMPLEX
> > #define PETSC_HAVE_MPI_C_DOUBLE_COMPLEX 1
> > #endif
> > #ifndef PETSC_HAVE_MPI_FINALIZED
> > #define PETSC_HAVE_MPI_FINALIZED 1
> > #endif
> > #ifndef PETSC_USE_INFO
> > #define PETSC_USE_INFO 1
> > #endif
> > #ifndef PETSC_Alignx
> > #define PETSC_Alignx(a,b)
> > #endif
> > #ifndef PETSC_USE_BACKWARD_LOOP
> > #define PETSC_USE_BACKWARD_LOOP 1
> > #endif
> > #ifndef PETSC_USE_DEBUG
> > #define PETSC_USE_DEBUG 1
> > #endif
> > #ifndef PETSC_USE_LOG
> > #define PETSC_USE_LOG 1
> > #endif
> > #ifndef PETSC_IS_COLOR_VALUE_TYPE_F
> > #define PETSC_IS_COLOR_VALUE_TYPE_F integer2
> > #endif
> > #define PETSC_IS_COLOR_VALUE_TYPE short
> > #endif
> > #ifndef PETSC_USE_CTABLE
> > #define PETSC_USE_CTABLE 1
> > #endif
> > #ifndef PETSC_MEMALIGN
> > #define PETSC_MEMALIGN 16
> > #endif
> > #ifndef PETSC_LEVEL1_DCACHE_LINESIZE
> > #define PETSC_LEVEL1_DCACHE_LINESIZE 32
> > #endif
> > #ifndef PETSC_LEVEL1_DCACHE_SIZE
> > #define PETSC_LEVEL1_DCACHE_SIZE 32768
> > #endif
> > #ifndef PETSC_LEVEL1_DCACHE_ASSOC
> > #define PETSC_LEVEL1_DCACHE_ASSOC 2
> > #endif
> > #ifndef PETSC_HAVE_CLOSURE
> > #define PETSC_HAVE_CLOSURE 1
> > #endif
> > #ifndef PETSC__BSD_SOURCE
> > #define PETSC__BSD_SOURCE 1
> > #endif
> > #ifndef PETSC__DEFAULT_SOURCE
> > #define PETSC__DEFAULT_SOURCE 1
> > #endif
> > #ifndef PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT
> > #define PETSC_HAVE_FORTRAN_GET_COMMAND_ARGUMENT 1
> > #endif
> > #ifndef PETSC_HAVE_GFORTRAN_IARGC
> > #define PETSC_HAVE_GFORTRAN_IARGC 1
> > #endif
> > #ifndef PETSC_USE_BYTES_FOR_SIZE
> > #define PETSC_USE_BYTES_FOR_SIZE 1
> > #endif
> > #ifndef PETSC_HAVE_SYS_SYSCTL_H
> > #define PETSC_HAVE_SYS_SYSCTL_H 1
> > #endif
> > #endif
> > **** C specific Configure header /var/folders/z_/2vhmh9zx3kx3h80k5wbkjmtr0000gp/T/petsc-yrHkm7/conffix.h ****
> > #if !defined(INCLUDED_UNKNOWN)
> > #define INCLUDED_UNKNOWN
> > #if defined(__cplusplus)
> > extern "C" {
> > #else
> > #endif
> > #endif
> >   File "./config/configure.py", line 393, in petsc_configure
> >     framework.configure(out = sys.stdout)
> >   File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 1097, in configure
> >     self.processChildren()
> >   File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 1086, in processChildren
> >     self.serialEvaluation(self.childGraph)
> >   File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 1067, in serialEvaluation
> >     child.configure()
> >   File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/package.py", line 857, in configure
> >     self.executeTest(self.configureLibrary)
> >   File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/base.py", line 126, in executeTest
> >     ret = test(*args,**kargs)
> >   File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/packages/Matlab.py", line 40, in configureLibrary
> >     for matlab in self.generateGuesses():
> >   File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/packages/Matlab.py", line 23, in generateGuesses
> >     raise RuntimeError('You set a value for --with-matlab-dir, but '+self.argDB['with-matlab-dir']+' cannot be used\n')
> > Finishing Configure Run at Thu Oct 25 18:48:02 2018
> > Date:  Oct 26, 2018
> > > Scott-Grad-MBP:bin zhihui$ pwd
> > Sorry - you need
> > Satish
