[petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
avatar 648934229 at qq.com
Thu Oct 25 18:43:30 CDT 2018
These are what I got:
Scott-Grad-MacBook-Pro:benchmarks zhihui$ echo $TMPDIR
tmp
Scott-Grad-MacBook-Pro:benchmarks zhihui$ ls -l libconf1.a
-rw-r--r--  1 zhihui  staff  1624 Oct 25 17:36 libconf1.a
Scott-Grad-MacBook-Pro:benchmarks zhihui$ /usr/bin/ar t libconf1.a
__.SYMDEF SORTED
sizeof.o
Scott-Grad-MacBook-Pro:benchmarks zhihui$ TMPDIR=$PWD /usr/bin/ar t libconf1.a
__.SYMDEF SORTED
sizeof.o
------------------ Original ------------------
Date:  Oct 26, 2018
To:  "avatar"<648934229 at qq.com>;
Cc:  "petsc-users"<petsc-users at mcs.anl.gov>;
Subject:  Re: [petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
Looks like it worked.
What do you have for:
echo $TMPDIR
ls -l libconf1.a
Satish
On Fri, 26 Oct 2018, avatar wrote:
> As follow. Then, what I should do next?
> Scott-Grad-MacBook-Pro:benchmarks zhihui$ TMPDIR=$PWD /usr/bin/ar cr libconf1.a sizeof.o
> From:  "Balay, Satish";<balay at mcs.anl.gov>;
> Date:  Oct 26, 2018
> How about:
> Satish
> > Scott-Grad-MacBook-Pro:benchmarks zhihui$ mpicc -c sizeof.c
> > Index.c			PetscGetCPUTime.c	PetscMemcmp.c		PetscTime.c		benchmarkExample.py	sizeof.c
> > Index.c.html		PetscGetCPUTime.c.html	PetscMemcmp.c.html	PetscTime.c.html	daemon.py		sizeof.o
> > MPI_Wtime.c		PetscGetTime.c		PetscMemcpy.c		PetscVecNorm.c		index.html		streams
> > MPI_Wtime.c.html	PetscGetTime.c.html	PetscMemcpy.c.html	PetscVecNorm.c.html	libconf1.a
> > PLogEvent.c		PetscMalloc.c		PetscMemzero.c		benchmarkAssembly.py	makefile
> > PLogEvent.c.html	PetscMalloc.c.html	PetscMemzero.c.html	benchmarkBatch.py	makefile.html
> > Scott-Grad-MacBook-Pro:benchmarks zhihui$ /usr/bin/ar cr libconf1.a sizeof.o
> > ar: temporary file: No such file or directory
> > Date:  Oct 26, 2018
> > What about:
> > mpicc -c sizeof.c
> > Satish
> > > I could not do all things you posted below. I get these:
> > > Scott-Grad-MacBook-Pro:petsc-3.8.3 zhihui$ cd src
> > > Scott-Grad-MacBook-Pro:src zhihui$ cd benchmarks/
> > > Scott-Grad-MacBook-Pro:benchmarks zhihui$ ls -l sizeof.o
> > > -rw-r--r--  1 zhihui  staff  1452 Oct 25 17:00 sizeof.o
> > > Scott-Grad-MacBook-Pro:benchmarks zhihui$ /usr/bin/ar cr /tmp/libconf1.a sizeof.o
> > > Date:  Oct 26, 2018
> > > > Hi Satish,
> > > > Thank you very much for your quick response.
> > > > The log file is as follow:
> > > Executing: /usr/bin/ar cr /tmp/petsc-mjVUVK/config.setCompilers/libconf1.a /tmp/petsc-mjVUVK/config.setCompilers/conf1.o
> > > Possible ERROR while running archiver: exit code 256
> > > stderr:
> > >             Archiver is not functional
> > > This is a strange error.
> > > What do you get when you do the following:
> > > balay at jpro^~/petsc(maint-3.8) $ cd src/benchmarks/
> > > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ mpicc -c sizeof.c
> > > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l sizeof.o
> > > -rw-r--r--  1 balay  staff  3036 Oct 25 17:54 sizeof.o
> > > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ /usr/bin/ar cr /tmp/libconf1.a  sizeof.o
> > > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l /tmp/libconf1.a
> > > -rw-r--r--  1 balay  wheel  3224 Oct 25 17:55 /tmp/libconf1.a
> > > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ar t /tmp/libconf1.a
> > > __.SYMDEF SORTED
> > > sizeof.o
> > > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ cp sizeof.o /tmp/
> > > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l /tmp/sizeof.o
> > > -rw-r--r--  1 balay  wheel  3036 Oct 25 17:55 /tmp/sizeof.o
> > > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ /usr/bin/ar cr /tmp/libconf2.a /tmp/sizeof.o
> > > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l /tmp/libconf2.a
> > > -rw-r--r--  1 balay  wheel  3224 Oct 25 17:55 /tmp/libconf2.a
> > > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ar t /tmp/libconf2.a
> > > __.SYMDEF SORTED
> > > sizeof.o
> > > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181026/080ca755/attachment.html>
