[petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
avatar
648934229 at qq.com
Thu Oct 25 18:37:34 CDT 2018
As follow. Then, what I should do next?
Scott-Grad-MacBook-Pro:benchmarks zhihui$ TMPDIR=$PWD /usr/bin/ar cr libconf1.a sizeof.o
------------------ Original ------------------
Date: Oct 26, 2018
To: "avatar"<648934229 at qq.com>;
Cc: "petsc-users"<petsc-users at mcs.anl.gov>;
Subject: Re: [petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
How about:
Satish
On Fri, 26 Oct 2018, avatar wrote:
> Scott-Grad-MacBook-Pro:benchmarks zhihui$ mpicc -c sizeof.c
> Scott-Grad-MacBook-Pro:benchmarks zhihui$ ls
> Index.c PetscGetCPUTime.c PetscMemcmp.c PetscTime.c benchmarkExample.py sizeof.c
> Index.c.html PetscGetCPUTime.c.html PetscMemcmp.c.html PetscTime.c.html daemon.py sizeof.o
> MPI_Wtime.c PetscGetTime.c PetscMemcpy.c PetscVecNorm.c index.html streams
> MPI_Wtime.c.html PetscGetTime.c.html PetscMemcpy.c.html PetscVecNorm.c.html libconf1.a
> PLogEvent.c PetscMalloc.c PetscMemzero.c benchmarkAssembly.py makefile
> PLogEvent.c.html PetscMalloc.c.html PetscMemzero.c.html benchmarkBatch.py makefile.html
> Scott-Grad-MacBook-Pro:benchmarks zhihui$ /usr/bin/ar cr libconf1.a sizeof.o
> ar: temporary file: No such file or directory
> From: "Balay, Satish";<balay at mcs.anl.gov>;
> Date: Oct 26, 2018
> What about:
> mpicc -c sizeof.c
> Satish
> > I could not do all things you posted below. I get these:
> > Scott-Grad-MacBook-Pro:petsc-3.8.3 zhihui$ cd src
> > Scott-Grad-MacBook-Pro:src zhihui$ cd benchmarks/
> > Scott-Grad-MacBook-Pro:benchmarks zhihui$ ls -l sizeof.o
> > -rw-r--r-- 1 zhihui staff 1452 Oct 25 17:00 sizeof.o
> > Scott-Grad-MacBook-Pro:benchmarks zhihui$ /usr/bin/ar cr /tmp/libconf1.a sizeof.o
> > Date: Oct 26, 2018
> > > Hi Satish,
> > > Thank you very much for your quick response.
> > > The log file is as follow:
> > Executing: /usr/bin/ar cr /tmp/petsc-mjVUVK/config.setCompilers/libconf1.a /tmp/petsc-mjVUVK/config.setCompilers/conf1.o
> > Possible ERROR while running archiver: exit code 256
> > stderr:
> > Archiver is not functional
> > This is a strange error.
> > What do you get when you do the following:
> > balay at jpro^~/petsc(maint-3.8) $ cd src/benchmarks/
> > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ mpicc -c sizeof.c
> > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l sizeof.o
> > -rw-r--r-- 1 balay staff 3036 Oct 25 17:54 sizeof.o
> > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ /usr/bin/ar cr /tmp/libconf1.a sizeof.o
> > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l /tmp/libconf1.a
> > -rw-r--r-- 1 balay wheel 3224 Oct 25 17:55 /tmp/libconf1.a
> > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ar t /tmp/libconf1.a
> > __.SYMDEF SORTED
> > sizeof.o
> > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ cp sizeof.o /tmp/
> > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l /tmp/sizeof.o
> > -rw-r--r-- 1 balay wheel 3036 Oct 25 17:55 /tmp/sizeof.o
> > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ /usr/bin/ar cr /tmp/libconf2.a /tmp/sizeof.o
> > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l /tmp/libconf2.a
> > -rw-r--r-- 1 balay wheel 3224 Oct 25 17:55 /tmp/libconf2.a
> > balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ar t /tmp/libconf2.a
> > __.SYMDEF SORTED
> > sizeof.o
> > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181026/6faeffda/attachment.html>
