[petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
avatar 648934229 at qq.com
Thu Oct 25 18:03:07 CDT 2018
I could not do all things you posted below. I get these:
Scott-Grad-MacBook-Pro:petsc-3.8.3 zhihui$ cd src
Scott-Grad-MacBook-Pro:src zhihui$ cd benchmarks/
Scott-Grad-MacBook-Pro:benchmarks zhihui$ mpicc -c sizeof.c
Scott-Grad-MacBook-Pro:benchmarks zhihui$ ls -l sizeof.o
-rw-r--r--  1 zhihui  staff  1452 Oct 25 17:00 sizeof.o
Scott-Grad-MacBook-Pro:benchmarks zhihui$ /usr/bin/ar cr /tmp/libconf1.a sizeof.o
ar: temporary file: No such file or directory
------------------ Original ------------------
Date:  Oct 26, 2018
To:  "avatar"<648934229 at qq.com>;
Cc:  "petsc-users"<petsc-users at mcs.anl.gov>;
Subject:  Re: [petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
On Fri, 26 Oct 2018, avatar wrote:
> Hi Satish,
> Thank you very much for your quick response.
> The log file is as follow:
Executing: /usr/bin/ar cr /tmp/petsc-mjVUVK/config.setCompilers/libconf1.a /tmp/petsc-mjVUVK/config.setCompilers/conf1.o
Possible ERROR while running archiver: exit code 256
stderr:
            Archiver is not functional
This is a strange error.
What do you get when you do the following:
balay at jpro^~/petsc(maint-3.8) $ cd src/benchmarks/
balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ mpicc -c sizeof.c
balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l sizeof.o
-rw-r--r--  1 balay  staff  3036 Oct 25 17:54 sizeof.o
balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ /usr/bin/ar cr /tmp/libconf1.a  sizeof.o
balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l /tmp/libconf1.a
-rw-r--r--  1 balay  wheel  3224 Oct 25 17:55 /tmp/libconf1.a
balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ar t /tmp/libconf1.a
__.SYMDEF SORTED
sizeof.o
balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ cp sizeof.o /tmp/
balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l /tmp/sizeof.o
-rw-r--r--  1 balay  wheel  3036 Oct 25 17:55 /tmp/sizeof.o
balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ /usr/bin/ar cr /tmp/libconf2.a /tmp/sizeof.o
balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ls -l /tmp/libconf2.a
-rw-r--r--  1 balay  wheel  3224 Oct 25 17:55 /tmp/libconf2.a
balay at jpro^~/petsc/src/benchmarks(maint-3.8) $ ar t /tmp/libconf2.a
__.SYMDEF SORTED
sizeof.o
Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181026/bc07e396/attachment.html>
