[petsc-users] Using BDDC preconditioner for assembled matrices
Stefano Zampini stefano.zampini at gmail.com
Thu Oct 25 08:53:03 CDT 2018
How many processes (subdomains) are you using?
I would not say the number of iterations is bad, and it also seems to
plateau.
The grad-div problem is quite hard to be solved (unless you use
hybridization), you can really benefit from the "Neumann" assembly.
I believe you are using GMRES, as the preconditioned operator (i.e
M_BDDC^-1 A) is not guaranteed to be positive definite when you use the
automatic disassembling.
You may slightly improve the quality of the disassembling by using
-mat_is_disassemble_l2g_type nd -mat_partitioning_type parmetis if you have
PETSc compiled with ParMETIS support.
Il giorno mer 24 ott 2018 alle ore 20:59 Abdullah Ali Sivas <
abdullahasivas at gmail.com> ha scritto:
> Hi Stefano,
> I am trying to solve the div-div problem (or grad-div problem in strong
> form) with a H(div)-conforming FEM. I am getting the matrices from an
> external source (to be clear, from an ngsolve script) and I am not sure if
> it is possible to get a MATIS matrix out of that. So I am just treating it
> as if I am not able to access the assembly code. The results are 2, 31, 26,
> 27, 31 iterations, respectively, for matrix sizes 282, 1095, 4314, 17133,
> 67242, 267549. However, norm of the residual also grows significantly;
> 7.38369e-09 for 1095 and 5.63828e-07 for 267549. I can try larger sizes, or
> maybe this is expected for this case.
> As a side question, if we are dividing the domain into number of MPI
> processes subdomains, does it mean that convergence is affected negatively
> by the increasing number of processes? I know that alternating Schwarz
> method and some other domain decomposition methods sometimes suffer from
> the decreasing radius of the subdomains. It sounds like BDDC is pretty
> similar to those by your description.
> Best wishes,
> Abdullah Ali Sivas
> On Wed, 24 Oct 2018 at 05:28, Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
>> Abdullah,
>> The "Neumann" problems Jed is referring to result from assembling your
>> problem on each subdomain ( = MPI process) separately.
>> Assuming you are using FEM, these problems have been historically  named
>> "Neumann" as they correspond to a problem with natural boundary conditions
>> (Neumann bc for Poisson).
>> Note that in PETSc the subdomain decomposition is associated with the
>> mesh decomposition.
>> When converting from an assembled AIJ matrix to a MATIS format, such
>> "Neumann" information is lost.
>> You can disassemble an AIJ matrix, in the sense that you can find local
>> matrices A_j such that A = \sum_j R^T_j A_j R_j (as it is done in ex72.c),
>> but you cannot guarantee (unless if you solve an optimization problem) that
>> the disassembling will produce subdomain Neumann problems that are
>> consistent with your FEM problem.
>> I have added such disassembling code a few months ago, just to have
>> another alternative for preconditioning AIJ matrices in PETSc; there are
>> few tweaks one can do to improve the quality of the disassembling, but I
>> discourage its usage unless you don't have access to the FEM assembly code.
>> With that said, what problem are you trying to solve? Are you using DMDA
>> or DMPlex? What are the results you obtained with using the automatic
>> disassembling?
>> Il giorno mer 24 ott 2018 alle ore 08:14 Abdullah Ali Sivas <
>>> Hi Jed,
>>> Thanks for your reply. The assembled matrix I have corresponds to the
>>> full problem on the full mesh. There are no "Neumann" problems (or any sort
>>> of domain decomposition) defined in the code generates the matrix. However,
>>> I think assembling the full problem is equivalent to implicitly assembling
>>> the "Neumann" problems, since the system can be partitioned as;
>>> [A_{LL} | A_{LI}]  [u_L]     [F]
>>> [A_{IL}  |A_{II} ]   [u_I]      [G]
>>> and G should correspond to the Neumann problem. I might be thinking
>>> wrong (or maybe I completely misunderstood the idea), if so please correct
>>> me. But I think that the problem is that I am not explicitly telling PCBDDC
>>> which dofs are interface dofs.
>>> Regards,
>>> Abdullah Ali Sivas
>>> On Tue, 23 Oct 2018 at 23:16, Jed Brown <jed at jedbrown.org> wrote:
>>>> Did you assemble "Neumann" problems that are compatible with your
>>>> definition of interior/interface degrees of freedom?
>>>> Abdullah Ali Sivas <abdullahasivas at gmail.com> writes:
>>>> > Dear all,
>>>> > I have a series of linear systems coming from a PDE for which BDDC is
>>>> an
>>>> > optimal preconditioner. These linear systems are assembled and I read
>>>> them
>>>> > from a file, then convert into MATIS as required (as in
>>>> https://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex72.c.html
>>>> > ). I expect each of the systems converge to the solution in almost
>>>> same
>>>> > number of iterations but I don't observe it. I think it is because I
>>>> do not
>>>> > provide enough information to the preconditioner. I can get a list of
>>>> inner
>>>> > dofs and interface dofs. However, I do not know how to use them. Has
>>>> anyone
>>>> > have any insights about it or done something similar?
>>>> > Best wishes,
>>>> > Abdullah Ali Sivas
>> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181025/820fa653/attachment.html>
