[petsc-users] Problems about Compiling Multifile Program
Yingjie Wu yjwu16 at gmail.com
Wed Oct 24 10:30:09 CDT 2018
Thank you very much for your reply.
Because the files I added are written in c++, including definitions of
classes and functions. I encountered a mistake when I used your method.
myprogram: class1.o myprogram.o
       ${CLINKER} -o myprogram class1.o myprogram.o ${PETSC_LIB}
Error information is : unknown type name 'class'
It seems that I did not compile using the c++ compiler.
How should I set it up so that it can compile successfully?
Yingjie
Matthew Knepley <knepley at gmail.com> 于2018年10月24日周三 上午1:46写道:
> On Tue, Oct 23, 2018 at 11:37 AM Yingjie Wu <yjwu16 at gmail.com> wrote:
>> Dear Petsc developer:
>> Hi,
>> Thank you very much for your continuous help, I recently encountered some
>> difficulties in developing programs on Petsc.
>> 1. I want to use my class definition (class1. h) and class functions
>> (class1. cpp) files in my Petsc program (myprogram. c) and compile my
>> program. I have written other program before:
>> g++ -c class1.cpp myprogram.c
>> g++ -o myprogram *.o
>> I also have some knowledge of Makefile, but I don't know how to modify it
>> to achieve compilation. I really want your help.
> With PETSc makefiles, we have automatic rules, so you can use
>> 2.  In my class definition and function implementation program, I want to
>> use Petsc data structures, such as PetscInt, PetscReal. In order to
>> maintain consistency of the main program. What kind of header files should
>> I add to my code, or do I need to add any code?
> The easiest thing to do is just
> #include <petsc.h>
>   Thanks,
>     Matt
>> Thanks,
>> Yingjie
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181024/1f1056f0/attachment.html>
