[petsc-users] PetscInt overflow
Jan Grießer griesser.jan at googlemail.com
Wed Oct 24 08:36:40 CDT 2018
Hey,
i tried to run my program as you said with -bv_type vecs and/or -bv_type
mat, but instead of the PETScInt overflow i now get an MPI Error 9 message,
which i assume (after googling a little bit around) should be a memory
problem. I tried to run it also on slightly bigger compute nodes on our
cluster with 20 cores with each 12 GB and 24 GB but the problem still
remains. The actual limit appears to be a 1.5 Million x 1.5 Million where
i  searched for NEV = 1500 and MPD = 500/ 200 eigenvalues.
Do you have maybe an idea what the error could be? I appended also the
python method i used to solve the problem. I also tried to solve the
problem with spectrum solving but the error message remains the same.
def solve_eigensystem(DynMatrix_nn, NEV, MPD, Dimension):
# Create the solver
# E is used as an acronym for the EPS solver (EPS = Eigenvalue problem
solver)
E = SLEPc.EPS().create()
# Set the preconditioner
pc = PETSc.PC().create()
pc.setType(pc.Type.BJACOBI)
# Set the linear solver
# Create the KSP object
ksp = PETSc.KSP().create()
# Create the solver, in this case GMRES
ksp.setType(ksp.Type.GMRES)
# Set the tolerances of the GMRES solver
        # Link it to the PC
ksp.setPC(pc)
# Set up the spectral transformations
st = SLEPc.ST().create()
st.setType("shift")
st.setKSP(ksp)
# MPD stands for "maximum projected dimension". It has to due with
computational cost, please read Chap. 2.6.5 of SLEPc docu for
# an explanation. At the moment mpd is only a guess
E.setDimensions(nev=NEV, mpd = MPD)
# Eigenvalues should be real, therefore we start to order them from the
smallest real value |l.real|
E.setWhichEigenpairs(E.Which.SMALLEST_REAL)
# Since the dynamical matrix is symmetric and real it is hermitian
E.setProblemType(SLEPc.EPS.ProblemType.HEP)
# Use the Krylov Schur method to solve the eigenvalue problem
E.setType(E.Type.KRYLOVSCHUR)
# Set the convergence criterion to relative to the eigenvalue and the
maximal number of iterations
E.setConvergenceTest(E.Conv.REL)
E.setTolerances(tol = 1e-8, max_it = 5000)
# Set the matrix in order to solve
E.setOperators(DynMatrix_nn, None)
# Sets EPS options from the options database. This routine must be called
before `setUp()` if the user is to be allowed to set dthe solver type.
E.setFromOptions()
# Sets up all the internal data structures necessary for the execution of
the eigensolver.
E.setUp()
# Solve eigenvalue problem
E.solve()
Print = PETSc.Sys.Print
Print()
Print("****************************")
Print("***SLEPc Solution Results***")
its = E.getIterationNumber()
Print("Number of iterations of the method: ", its)
eps_type = E.getType()
Print("Solution method: ", eps_type)
nev, ncv, mpd = E.getDimensions()
Print("Number of requested eigenvalues: ", nev)
Print("Number of computeded eigenvectors: ", ncv)
tol, maxit = E.getTolerances()
Print("Stopping condition: (tol, maxit)", (tol, maxit))
# Get the type of convergence
conv_test = E.getConvergenceTest()
Print("Selected convergence test: ", conv_test)
# Get the used spectral transformation
get_st = E.getST()
Print("Selected spectral transformation: ", get_st)
# Get the applied direct solver
get_ksp = E.getDS()
Print("Selected direct solver: ", get_ksp)
nconv = E.getConverged()
Print("Number of converged eigenpairs: ", nconv)
Am Fr., 19. Okt. 2018 um 21:00 Uhr schrieb Smith, Barry F. <
bsmith at mcs.anl.gov>:
> > On Oct 19, 2018, at 7:56 AM, Zhang, Junchao <jczhang at mcs.anl.gov> wrote:
> > On Fri, Oct 19, 2018 at 4:02 AM Jan Grießer <griesser.jan at googlemail.com>
> wrote:
> > With more than 1 MPI process you mean i should use spectrum slicing in
> divide the full problem in smaller subproblems?
> > The --with-64-bit-indices is not a possibility for me since i configured
> petsc with mumps, which does not allow to use the 64-bit version (At least
> this was the error message when i tried to configure PETSc )
> > MUMPS 5.1.2 manual chapter 2.4.2 says it supports "Selective 64-bit
> integer feature" and "full 64-bit integer version" as well.
>     They use to achieve this by compiling with special Fortran flags to
> promote integers to 64 bit; this is too fragile for our taste so we never
> hooked PETSc up wit it. If they have a dependable way of using 64 bit
> integers we should add that to our mumps.py and test it.
>    Barry
> > Am Mi., 17. Okt. 2018 um 18:24 Uhr schrieb Jose E. Roman <
> jroman at dsic.upv.es>:
> > To use BVVECS just add the command-line option -bv_type vecs
> > This causes to use a separate Vec for each column, instead of a single
> long Vec of size n*m. But it is considerably slower than the default.
> > Anyway, for such large problems you should consider using more than 1
> MPI process. In that case the error may disappear because the local size is
> smaller than 768000.
> > Jose
> > > El 17 oct 2018, a las 17:58, Matthew Knepley <knepley at gmail.com>
> escribió:
> > > On Wed, Oct 17, 2018 at 11:54 AM Jan Grießer <
> griesser.jan at googlemail.com> wrote:
> > > Hi all,
> > > i am using slepc4py and petsc4py to solve for the smallest real
> eigenvalues and eigenvectors. For my test cases with a matrix A of the size
> 30k x 30k solving for the smallest soutions works quite well, but when i
> increase the dimension of my system to around A = 768000 x 768000 or 3
> million x 3 million and ask for the smallest real 3000 (the number is
> increasing with increasing system size) eigenvalues and eigenvectors i get
> the output (for the 768000):
> > >  The product 4001 times 768000 overflows the size of PetscInt;
> consider reducing the number of columns, or use BVVECS instead
> > > i understand that the requested number of eigenvectors and eigenvalues
> is causing an overflow but i do not understand the solution of the problem
> which is stated in the error message. Can someone tell me what exactly
> BVVECS is and how i can use it? Or is there any other solution to my
> problem ?
> > > You can also reconfigure with 64-bit integers: --with-64-bit-indices
> > >   Thanks,
> > >     Matt
> > > Thank you very much in advance,
> > > Jan
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181024/1db75cad/attachment.html>
