[petsc-users] Periodic BC in petsc DMPlex / firedrake
Stefano Zampini stefano.zampini at gmail.com
Wed Oct 24 08:11:53 CDT 2018
To read periodic meshes from GMSH, you need to use the option
-dm_plex_gmsh_periodic and DMPlexCreateFromFile
See  src/dm/impls/plex/examples/tests/ex1.c. An example runs
$ ./ex1 -filename
${PETSC_DIR}/share/petsc/datafiles/meshes/cube_periodic_bin.msh
-dm_plex_gmsh_periodic -dm_view ::ascii_info_detail -interpolate -test_shape
generating periodic meshes in gmsh may be tricky, Lisandro for sure may
advice.
Il giorno mer 24 ott 2018 alle ore 13:51 Matthew Knepley <knepley at gmail.com>
ha scritto:
> On Wed, Oct 24, 2018 at 6:29 AM Lawrence Mitchell <wence at gmx.li> wrote:
>> Hi Max,
>> (I'm cc'ing in the petsc-users mailing list which may have more advice,
>> if you are using PETSc you should definitely subscribe!
>> > On 24 Oct 2018, at 09:27, Maximilian Hartig <imilian.hartig at gmail.com>
>> wrote:
>> > Hello Lawrence,
>> > sorry to message you out of the blue. My name is Max and I found your
>> post on GitHub (https://github.com/firedrakeproject/firedrake/issues/1246
>> ) on DMPlex being able to read periodic gmsh files. I am currently trying
>> to do just that (creating a periodic DMPlex mesh with gmsh) in the context
>> of my PhD work. So far I haven’ t found any documentation on the periodic
>> BC’s with DMPlex and gmsh in the official petsc documentation.
>> > I was wondering whether you’d be so kind as to point me in a general
>> direction concerning how to achieve this. You seem experienced in using
>> petsc and I would greatly appreciate your help.
>> I think the answer is "it depends". If you're just using DMPlex directly
>> and all the of the functionality with PetscDS, then I /think/ that reading
>> periodic meshes via gmsh (assuming you're using the appropriate gmsh mesh
>> format [v2]) "just works".
> There are two phases here: topological and geometric. DMPlex represents
> the periodic topological entity directly. For example,  a circle is just a
> segment with one end hooked to the other. Vertices are not duplicated, or
> mapped to each other. This makes topology simple and easy to implement.
> However, then geometry is more complicated. What Plex does is allow
> coordinates to be represented by a discontinuous field taking values on
> cells, in addition to vertices. In our circle example, each cells near the
> cut will have 2 coordinates, one for each vertex, but they will not agree
> across the cut. If you define a periodic domain, then Plex can construct
> this coordinate field automatically using DMPlexLocalize(). These DG
> coordinates are then used by the integration routines.
>> From my side, the issue is to do with mapping that coordinate field into
>> one that I understand (within Firedrake). You may not have this problem.
> Firedrake uses its own coordinate mapping and integration routines, so
> they must manage the second part independently. I hope to get change this
> slightly soon by making the Firedrake representation a DMField, so that it
> looks the same to Plex.
>   Thanks,
>     Matt
>> Thanks,
>> Lawrence
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181024/13b6aa72/attachment.html>
