[petsc-users] Problems about Compiling Multifile Program
Matthew Overholt overholt at capesim.com
Tue Oct 23 13:29:59 CDT 2018
Here is a sample makefile, like what I use with the Intel MPI compilers
(used during PETSc configuration) and MKL library.
Matt Overholt
# makefile for Linux using the Intel C++ Compiler, MKL & MPI libraries +
OpenMP
#   usage: make
#   or: make clean
# Although explicit paths are used for all libraries and compilers below,
it is
# still necessary to first call the Intel scripts as follows:
#   if [ -z "$I_MPI_ROOT" ]; then
#     source
/opt/intel/compilers_and_libraries/linux/mpi/intel64/bin/mpivars.sh
#   fi
#   if [ -z "$MKLROOT" ]; then
#     source /opt/intel/parallel_studio_xe_2018/bin/psxevars.sh intel64
#   fi
# Use OMP_NUM_THREADS to set # of threads
### MPI Compilers for C++ and C ###
COMPILER_DIR = /opt/intel/compilers_and_libraries/linux/mpi/intel64/bin
COMPILER = $(COMPILER_DIR)/mpiicpc
CCOMPILER = $(COMPILER_DIR)/mpiicc
### Intel MKL & MPI libraries ###
MKL_DIR = /opt/intel/compilers_and_libraries/linux/mkl
MKL_INC = $(MKL_DIR)/include
MKL_LIB = $(MKL_DIR)/lib/intel64
### Compiling Flags (debug and optimized) ###
# CCFLAGS = -c -O0 -g -traceback -heap-arrays -check=stack,uninit
-I$(MKL_INC) -qopenmp
CCFLAGS = -c -I$(MKL_INC) -qopenmp
### Linking Flags (debug and optimized) ###
# CLFLAGS = -g -lstdc++ -qopenmp
CLFLAGS = -lstdc++ -qopenmp
### MKL Libraries ###
# Sequential threading layer
# MKLFLAGS = -Wl,--start-group \
# ${MKLROOT}/lib/intel64/libmkl_intel_lp64.a \
# ${MKLROOT}/lib/intel64/libmkl_sequential.a \
# ${MKLROOT}/lib/intel64/libmkl_core.a \
# -Wl,--end-group -lpthread -lm -ldl
# OpenMP parallel threading layer
$(MKL_LIB)/libmkl_intel_lp64.a \
$(MKL_LIB)/libmkl_intel_thread.a \
$(MKL_LIB)/libmkl_core.a \
$(MKL_LIB)/libmkl_blacs_intelmpi_lp64.a \
-Wl,--end-group -liomp5 -lpthread -lm -ldl
TARGET = myprogram
### Object Files ###
OBJFILES = \
class1.o \
class2.o
all: $(TARGET)
# Build (link) it
$(TARGET) : $(OBJFILES)
$(COMPILER) -o $(TARGET) $(OBJFILES) $(CLFLAGS) $(MKLFLAGS)
echo $(TARGET) BUILT AS A 64-BIT LINUX APPLICATION!
# Compile the source files with C and CPP MPI compilers
# CPP
class1.o : class1.cpp
$(COMPILER) $(CCFLAGS) class1.cpp
# C
class2.o : class2.c
$(CCOMPILER) $(CCFLAGS) class2.c
# main
myprogram.o : myprogram.c
$(CCOMPILER) $(CCFLAGS) myprogram.c
# to clean up
.PHONY : clean
clean:
-rm -f $(OBJFILES)
-rm -f $(TARGET)
echo myprogram cleaned
On Tue, Oct 23, 2018 at 1:46 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Oct 23, 2018 at 11:37 AM Yingjie Wu <yjwu16 at gmail.com> wrote:
>> Dear Petsc developer:
>> Hi,
>> Thank you very much for your continuous help, I recently encountered some
>> difficulties in developing programs on Petsc.
>> 1. I want to use my class definition (class1. h) and class functions
>> (class1. cpp) files in my Petsc program (myprogram. c) and compile my
>> program. I have written other program before:
>> g++ -c class1.cpp myprogram.c
>> g++ -o myprogram *.o
>> I also have some knowledge of Makefile, but I don't know how to modify it
>> to achieve compilation. I really want your help.
> With PETSc makefiles, we have automatic rules, so you can use
> myprogram: class1.o myprogram.o
>        ${CLINKER} -o myprogram class1.o myprogram.o ${PETSC_LIB}
>> 2.  In my class definition and function implementation program, I want to
>> use Petsc data structures, such as PetscInt, PetscReal. In order to
>> maintain consistency of the main program. What kind of header files should
>> I add to my code, or do I need to add any code?
> The easiest thing to do is just
> #include <petsc.h>
>   Thanks,
>     Matt
>> Thanks,
>> Yingjie
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181023/9f088e5d/attachment.html>
