[petsc-users] Increasing norm with finer mesh
Weizhuo Wang
weizhuo2 at illinois.edu
Mon Oct 22 15:05:40 CDT 2018
Amazing, right preconditioning fixes the problem. Thanks a lot!
On Tue, Oct 16, 2018 at 8:31 PM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Wed, 17 Oct 2018 at 03:15, Weizhuo Wang <weizhuo2 at illinois.edu> wrote:
>> I just tried both, neither of them make a difference. I got exactly the
>> same curve with either combination.
> Try using right preconditioning.
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetPCSide.html
> Use the options:
> -ksp_type gmres -ksp_pc_side right -ksp_rtol 1e-12
> Or;
> -ksp_type fgmres -ksp_rtol 1e-12
> Fgmres does right preconditioning my default
>> Thanks!
>> Wang weizhuo
>> On Tue, Oct 16, 2018 at 8:06 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Oct 16, 2018 at 7:26 PM Weizhuo Wang <weizhuo2 at illinois.edu>
>>> wrote:
>>>> Hello again!
>>>> After some tweaking the code is giving right answers now. However it
>>>> start to disagree with MATLAB results ('traditional' way using matrix
>>>> inverse) when the grid is larger than 100*100. My PhD advisor and I
>>>> suspects that the default dimension of the Krylov subspace is 100 in the
>>>> test case we are running. If so, is there a way to increase the size of the
>>>> subspace?
>>> 1) The default subspace size is 30, not 100. You can increase the
>>> subspace size using
>>> -ksp_gmres_restart n
>>> 2) The problem is likely your tolerance. The default solver tolerance is
>>> 1e-5. You can change it using
>>> -ksp_rtol 1e-9
>>> Thanks,
>>> Matt
>>>> [image: Disagrees.png]
>>>> Thanks!
>>>> Wang Weizhuo
>>>> On Tue, Oct 9, 2018 at 2:50 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> To reiterate what Matt is saying, you seem to have the exact solution
>>>>> on a 10x10 grid. That makes no sense unless the solution can be represented
>>>>> exactly by your FE space (eg, u(x,y) = x + y).
>>>>> On Mon, Oct 8, 2018 at 9:33 PM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Mon, Oct 8, 2018 at 9:28 PM Weizhuo Wang <weizhuo2 at illinois.edu>
>>>>>> wrote:
>>>>>>> The code is attached in case anyone wants to take a look, I will try
>>>>>>> the high frequency scenario later.
>>>>>> That is not the error. It is superconvergence at the vertices. The
>>>>>> real solution is trigonometric, so your
>>>>>> linear interpolants or whatever you use is not going to get the right
>>>>>> value in between mesh points. You
>>>>>> need to do a real integral over the whole interval to get the L_2
>>>>>> error.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> On Mon, Oct 8, 2018 at 7:58 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> On Mon, Oct 8, 2018 at 6:58 PM Weizhuo Wang <weizhuo2 at illinois.edu>
>>>>>>>> wrote:
>>>>>>>>> The first plot is the norm with the flag -pc_type lu with respect
>>>>>>>>> to number of grids in one axis (n), and the second plot is the norm without
>>>>>>>>> the flag -pc_type lu.
>>>>>>>> So you are using the default PC w/o LU. The default is ILU. This
>>>>>>>> will reduce high frequency effectively but is not effective on the low
>>>>>>>> frequency error. Don't expect your algebraic error reduction to be at the
>>>>>>>> same scale as the residual reduction (what KSP measures).
>>>>>>> Wang Weizhuo
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.cse.buffalo.edu_-7Eknepley_&d=DwMFaQ&c=OCIEmEwdEq_aNlsP4fF3gFqSN-E3mlr2t9JcDdfOZag&r=hsLktHsuxNfF6zyuWGCN8x-6ghPYxhx4cV62Hya47oo&m=EFM29ATgv4U8PjXEtfgMkuxKr5DGscMlH-j769W5W_4&s=grgSL2LaDCthvYvvFITmeOOWPCwgmNfYRPs94N8kmOs&e=>
>>>> Wang Weizhuo
>>> experiments lead.
>>> -- Norbert Wiener
>>> <http://www.cse.buffalo.edu/~knepley/>
>> Wang Weizhuo
Wang Weizhuo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181022/7f0f655d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181022/7f0f655d/attachment-0001.png>
