[petsc-users] fortran INTENT with petsc object gives segfault after upgrade from 3.8.4 to 3.10.2
Klaij, Christiaan C.Klaij at marin.nl
Fri Oct 19 03:51:30 CDT 2018
I've recently upgraded from petsc-3.8.4 to petsc-3.10.2 and was
surprised to find a number of segmentation faults in my test
cases. These turned out to be related to user-defined MatMult and
PCApply for shell matrices. For example:
SUBROUTINE systemMatMult(aa_system,xx_system,rr_system,ierr)
  Mat, INTENT(in) :: aa_system
  Vec, INTENT(in) :: xx_system
  Vec, INTENT(out) :: rr_system
  PetscErrorCode, INTENT(out) :: ierr
END
where aa_system is the shell matrix. This code works fine with
3.8.4 and older, but fails with 3.10.2 due to invalid
pointers (gdb backtrace shows failure of VecSetValues due to
invalid first argument). After replacing by:
SUBROUTINE mass_momentum_systemMatMult(aa_system,xx_system,rr_system,ierr)
  Mat :: aa_system
  Vec :: xx_system
  Vec :: rr_system
  PetscErrorCode :: ierr
END
everything's fine again. So clearly something has changed since
3.8.4 that now prevents the use of INTENT in Fortran (at least
using intel 17.0.1 compilers). Any reason for this?
Chris
dr. ir. Christiaan Klaij  | Senior Researcher | Research & Development
MARIN | T +31 317 49 33 44 | mailto:C.Klaij at marin.nl | http://www.marin.nl
MARIN news: http://www.marin.nl/web/News/News-items/ReFRESCO-successfully-coupled-to-ParaView-Catalyst-for-insitu-analysis-1.htm
