[petsc-users] PetscInt overflow
Wed Oct 17 10:58:26 CDT 2018
On Wed, Oct 17, 2018 at 11:54 AM Jan Grießer <griesser.jan at googlemail.com>
wrote:
> Hi all,
> i am using slepc4py and petsc4py to solve for the smallest real
> eigenvalues and eigenvectors. For my test cases with a matrix A of the size
> 30k x 30k solving for the smallest soutions works quite well, but when i
> increase the dimension of my system to around A = 768000 x 768000 or 3
> million x 3 million and ask for the smallest real 3000 (the number is
> increasing with increasing system size) eigenvalues and eigenvectors i get
> the output (for the 768000):
>  The product 4001 times 768000 overflows the size of PetscInt; consider
> reducing the number of columns, or use BVVECS instead
> i understand that the requested number of eigenvectors and eigenvalues is
> causing an overflow but i do not understand the solution of the problem
> which is stated in the error message. Can someone tell me what exactly
> BVVECS is and how i can use it? Or is there any other solution to my
> problem ?
You can also reconfigure with 64-bit integers: --with-64-bit-indices
    Matt
> Thank you very much in advance,
> Jan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181017/42441192/attachment.html>
