[petsc-users] Increasing norm with finer mesh
Weizhuo Wang weizhuo2 at illinois.edu
Tue Oct 16 20:14:15 CDT 2018
I just tried both, neither of them make a difference. I got exactly the
same curve with either combination.
Thanks!
Wang weizhuo
On Tue, Oct 16, 2018 at 8:06 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Oct 16, 2018 at 7:26 PM Weizhuo Wang <weizhuo2 at illinois.edu>
> wrote:
>> Hello again!
>> After some tweaking the code is giving right answers now. However it
>> start to disagree with MATLAB results ('traditional' way using matrix
>> inverse) when the grid is larger than 100*100. My PhD advisor and I
>> suspects that the default dimension of the Krylov subspace is 100 in the
>> test case we are running. If so, is there a way to increase the size of the
>> subspace?
> 1) The default subspace size is 30, not 100. You can increase the subspace
> size using
>        -ksp_gmres_restart n
> 2) The problem is likely your tolerance. The default solver tolerance is
> 1e-5. You can change it using
>        -ksp_rtol 1e-9
>   Thanks,
>      Matt
>> [image: Disagrees.png]
>> Thanks!
>> Wang Weizhuo
>> On Tue, Oct 9, 2018 at 2:50 AM Mark Adams <mfadams at lbl.gov> wrote:
>>> To reiterate what Matt is saying, you seem to have the exact solution on
>>> a 10x10 grid. That makes no sense unless the solution can be represented
>>> exactly by your FE space (eg, u(x,y) = x + y).
>>> On Mon, Oct 8, 2018 at 9:33 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Oct 8, 2018 at 9:28 PM Weizhuo Wang <weizhuo2 at illinois.edu>
>>>> wrote:
>>>>> The code is attached in case anyone wants to take a look, I will try
>>>>> the high frequency scenario later.
>>>> That is not the error. It is superconvergence at the vertices. The real
>>>> solution is trigonometric, so your
>>>> linear interpolants or whatever you use is not going to get the right
>>>> value in between mesh points. You
>>>> need to do a real integral over the whole interval to get the L_2 error.
>>>>   Thanks,
>>>>      Matt
>>>>> On Mon, Oct 8, 2018 at 7:58 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> On Mon, Oct 8, 2018 at 6:58 PM Weizhuo Wang <weizhuo2 at illinois.edu>
>>>>>> wrote:
>>>>>>> The first plot is the norm with the flag -pc_type lu with respect to
>>>>>>> number of grids in one axis (n), and the second plot is the norm without
>>>>>>> the flag -pc_type lu.
>>>>>> So you are using the default PC w/o LU. The default is ILU. This will
>>>>>> reduce high frequency effectively but is not effective on the low frequency
>>>>>> error. Don't expect your algebraic error reduction to be at the same scale
>>>>>> as the residual reduction (what KSP measures).
>>>>> Wang Weizhuo
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.cse.buffalo.edu_-7Eknepley_&d=DwMFaQ&c=OCIEmEwdEq_aNlsP4fF3gFqSN-E3mlr2t9JcDdfOZag&r=hsLktHsuxNfF6zyuWGCN8x-6ghPYxhx4cV62Hya47oo&m=EFM29ATgv4U8PjXEtfgMkuxKr5DGscMlH-j769W5W_4&s=grgSL2LaDCthvYvvFITmeOOWPCwgmNfYRPs94N8kmOs&e=>
>> Wang Weizhuo
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Wang Weizhuo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181016/47918bc9/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181016/47918bc9/attachment-0001.png>
