[petsc-users] Fwd: Interpolation in staggered grid
Anton Popov
popov at uni-mainz.de
Tue Oct 16 02:56:47 CDT 2018
Hi Manuel,
you might consider useful taking a look at this code
https://bitbucket.org/bkaus/lamem, which is a multi-DMDA staggered grid
implementation.
Also, as Matt pointed out, there is a direct PETSc support for staggered
grids (DMSTAG), recently contributed by Patrick Sanan.
Anton
On 15.10.2018 23:22, Manuel Valera wrote:
> Thanks Matthew, i have made some progress but i am still unsure on how
> to proceed to make the DMDAs work as intended, i will try to lay out
> what i am trying now:
> I was able to port the interpolation into the DMDA model but it works
> only in serial runs, and it becomes unstable for more than one
> processor running,
> What i do is roughly this:
> * Calculate density at a cell-centered DMDA object, using a local
> vector so i can access the ghost rows (indices -1 and max+1)
> * Interpolate into a face-centered DMDA object for velocities, using
> also a local vector.
> Doing this i get the right results using the same interpolation i used
> for my non-petsc implementation of the model, as long as i use only
> one processor but the doubts i have are:
> * How to use the local vectors properly: Is operating on them the
> recommended course in this case?
> * How can i access the ghost indices in the global vector so i can
> then communicate GlobalToLocal? would this be a better strategy?
> * I feel is wrong to interpolate a cell-centered based vector into a
> face-centered based vector, using the indices of the latter, what
> strategy would work best in this case?
> I also tried opening a global vector with a different DA layout than
> the one created (opening global density on the velocities DMDA layout)
> and this introduced an error in the GlobalToLocal, LocalToLocal,
> LocalToGlobal communication, something didn't happen if i used the
> local versions of these vectors instead,
> Thanks for your help,
> Manuel
> On Sat, Oct 6, 2018 at 4:45 AM Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
> On Fri, Oct 5, 2018 at 6:49 PM Manuel Valera <mvalera-w at sdsu.edu
> <mailto:mvalera-w at sdsu.edu>> wrote:
> Hello,
> I'm trying to do a simple variable interpolation, from a cell
> center to a face in a staggered grid, my model data management
> is done with DMDAs, with two different DMs one for each cell
> position,
> I already did this task on a fortran only version of the model
> using the 4 closest neighbors of the scalars (cell center) to
> be interpolated at the velocity site (cell face), i did it
> using a loop over the domain, somehow this easy task is not
> translating into the DMDA framework,
> Its not clear to me what problem you are having. We have done this
> before. For example,
> https://www.mcs.anl.gov/petsc/petsc-current/src/snes/examples/tutorials/ex30.c.html
> I would note that the development version of PETSc now has DMStag
> which supports staggered grid discretizations directly.
> Thanks,
> Matt
> I'm not sure what I'm doing wrong or not aware of a easier way
> Petsc may have for this task, if you could point out an easier
> strategy or an example I would be grateful,
> Thanks,
> experiments is infinitely more interesting than any results to
> which their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/%7Eknepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181016/05562079/attachment.html>
