[petsc-users] DMPLEX project function error
yann JOBIC yann.jobic at univ-amu.fr
Sun Oct 14 02:07:51 CDT 2018
Hi Ellen,
I've made an old code (i forgot in which version it's working) that
gives local coordinates and connectivity of a distributed DM.
I didn't check that it's working again. I'll also work on that on the
future.
If it can help, i send you my ugly code (i didn't clean it).
Yann
On 14/10/2018 06:36, Ellen M. Price wrote:
> Hi Matt,
> I ran into a problem implementing this. My integration code relies on
> knowing the points of each tetrahedron in the domain so I can turn an
> integral over all space into a sum of integrals over cells. I can't find
> an example of getting vertices for a given cell (I think TS ex11 comes
> closest, looks like it gets faces?). Is there an elegant way to do this,
> or an example I can follow?
> Ellen
> On 10/13/2018 04:26 AM, Matthew Knepley wrote:
>> On Fri, Oct 12, 2018 at 6:00 PM Ellen M. Price
>> <ellen.price at cfa.harvard.edu <mailto:ellen.price at cfa.harvard.edu>> wrote:
>>      Hi Matt,
>>      Thanks for the feedback! I'm always open to editorial comments. Do you
>>      have a suggestion for a better way? I'm basically just trying to do an
>>      integral over all space to get my boundary values for the FEM solve. I
>>      don't know if PETSc has a way to do something like this?
>> So you are defining your BC by a boundary integral. I would just stick
>> that integration code
>> into a function and let that be called as your BC function. It will not
>> be called "extra" times,
>> just once for each dual vector, which in the case of P1 is every vertex.
>> This way it will work
>> for any element.
>>    Thanks,
>>       Matt
>>      Ellen
>>      On 10/12/2018 04:36 PM, Matthew Knepley wrote:
>>      > On Fri, Oct 12, 2018 at 3:51 PM Ellen M. Price
>>      <mailto:ellen.price at cfa.harvard.edu>>> wrote:
>>      >     Hi Matt,
>>      >     Basically, I have a simple meshing script that generates a set
>>      of points
>>      >     for my FEM mesh and outputs a C file that compiles into my
>>      program.
>>      >     Along with those points is a static data field that I need to be
>>      >     associated with the correct data point. I don't have a
>>      function that
>>      >     evaluates at each point, it's just pre-generated data.
>>      > I cannot help but make editorial comments. Do not do this. It is
>>      > incredibly fragile, since
>>      > it depends on both a mesh and a discretization.
>>      >     Since I called DMPlexDistribute() early on, I think my mesh
>>      points get
>>      >     re-ordered, right? So I need a way to re-order my data field
>>      to match
>>      >     that ordering. Is there a good way to do this?
>>      > However, if you want to do this, it is not hard. You do use
>>      > DMPlexDistributeField
>>      (https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexDistributeField.html),
>>      > but you need
>>      > to be careful about the arguments. You want
>>      >    DMPlexDistribute(dmOriginal, 0, &migrationSF, &dmNew);
>>      >    DMPlexDistributeField(dmOriginal, migrationSF, originalSection,
>>      > originalVec, newSection, newVec);
>>      > Your Sections are easy to make, just put 1 dof on every vertex. The
>>      > originalVec is just a Vec of your values
>>      > (you can use VecCreateSeqWithArray() to wrap one around it), and the
>>      > newVec you can get with
>>      > DMCreateLocalVector(dmNew, &newVec) if you do DMSetSection(dmNew,
>>      > newSection).
>>      > Does this make sense?
>>      >   Thanks,
>>      >      Matt
>>      >     I tried using DMPlexDistributeField as a first attempt, but I
>>      get some
>>      >     kind of error no matter what I do (presumably I'm not giving
>>      the right
>>      >     input), and there aren't any examples in the docs.
>>      >     Ellen
>>      >     On 10/12/2018 11:31 AM, Matthew Knepley wrote:
>>      >     > On Fri, Oct 12, 2018 at 11:12 AM Ellen M. Price
>>      >     > <ellen.price at cfa.harvard.edu
>>      <mailto:ellen.price at cfa.harvard.edu>>>> wrote:
>>      >     >     So I found *that* problem -- turns out that using
>>      >     DMPlexCreateSection
>>      >     >     was messing things up, and it seems PETSc is handling
>>      that part
>>      >     >     internally?
>>      >     > DMPlexSection creates the Section based on the discretization
>>      >     > information in the DM (stored in a PetscDS).
>>      >     > If no discretization info is available, then it defaults to P0 I
>>      >     think,
>>      >     > which is what you got.
>>      >     > After discretization info is put into the DM, if I ask for the
>>      >     Section,
>>      >     > the DM will create it automatically if it is missing.
>>      >     >     However, I've run into a related problem now. I need to
>>      >     >     project some field data onto the mesh; it's a static
>>      array of
>>      >     >     integration weights, and each one corresponds to a single
>>      >     point in the
>>      >     >     mesh. Based on this answer:
>>        https://lists.mcs.anl.gov/pipermail/petsc-users/2015-December/027964.html
>>      >     >     I think I need DMPlexDistributeField.
>>      >     > I don't think that is what you want.  That is just sending data
>>      >     around.
>>      >     > You want to define an FEM field. We use DMProject*() for
>>      this. These
>>      >     > take as input either
>>      >     > a function of the coordinates (regular function) or another
>>      FEM field.
>>      >     > Can you tell me how your function is defined? I mean apart
>>      from the
>>      >     > particular data you
>>      >     > have at points.
>>      >     >   Thanks,
>>      >     >      Matt
>>      >     >     However, *that* function takes a
>>      >     >     section as an argument, and I had to take out the part
>>      where I
>>      >     create a
>>      >     >     section to get things working!  Calling
>>      DMGetDefaultSection or
>>      >     >     DMGetDefaultGlobalSection doesn't seem to help matters,
>>      >     either, because
>>      >     >     then I seem to get a null section?
>>      >     >     So I either need to figure out how to set the section
>>      properly
>>      >     or how to
>>      >     >     get the section properly. As always, any help is
>>      appreciated.
>>      >     >     Ellen
>>      >     >     On 10/11/2018 05:41 PM, Matthew Knepley wrote:
>>      >     >     > On Thu, Oct 11, 2018 at 4:39 PM Ellen M. Price
>>      >     >     > <ellen.price at cfa.harvard.edu
>>      >     >     <mailto:ellen.price at cfa.harvard.edu
>>      <mailto:ellen.price at cfa.harvard.edu>>>>> wrote:
>>      >     >     >     I was working with a DMPLEX and FEM, following
>>      SNES example
>>      >     >     12. I get
>>      >     >     >     the following error when I call DMProjectFunction,
>>      but I
>>      >     don't
>>      >     >     know what
>>      >     >     >     it means. Can anyone explain where I might have gone
>>      >     wrong, or
>>      >     >     at least
>>      >     >     >     what this error is telling me? I think the point
>>      closure
>>      >     size is
>>      >     >     >     correct, since my mesh is 3d simplex,
>>      >     >     > Yes, if you have 3D SIMPLEX mesh and are using P1
>>      elements,
>>      >     then you
>>      >     >     > would have
>>      >     >     > 4 dofs in the closure of a cell. The dual space
>>      dimension is the
>>      >     >     number
>>      >     >     > of dual space
>>      >     >     > basis vectors assigned to points in the closure. Since
>>      it is
>>      >     1, it
>>      >     >     looks
>>      >     >     > like you have a P0
>>      >     >     > dual space. I assume you changed something in ex12?
>>      >     >     >   Thanks,
>>      >     >     >      Matt
>>      >     >     >     but what is the dual space
>>      >     >     >     dimension, and where might I have set it incorrectly?
>>      >     >     >     [0]PETSC ERROR: Nonconforming object sizes
>>      >     >     >     [0]PETSC ERROR: The section point closure size 4
>>      != dual
>>      >     space
>>      >     >     >     dimension 1
>>      >     >     >     [0]PETSC ERROR: See
>>      >     >     http://www.mcs.anl.gov/petsc/documentation/faq.html
>>      >     >     >     for trouble shooting.
>>      >     >     >     [0]PETSC ERROR: Petsc Release Version 3.9.2, May,
>>      20, 2018
>>      >     >     >     [0]PETSC ERROR: Configure options
>>      >     >     >     --prefix=/home/eprice/software/petsc-opt --with-hdf5=1
>>      >     >     >     --with-hdf5-dir=/home/eprice/software/hdf5-parallel
>>      >     --with-mpe=1
>>      >     >     >     --with-mpe-dir=/home/eprice/software/mpe
>>      --with-debugging=0
>>      >     >     >     LDFLAGS="-pthread -lz" COPTFLAGS="-O3 -march=native
>>      >     -mtune=native"
>>      >     >     >     CXXOPTFLAGS="-O3 -march=native -mtune=native"
>>      FOPTFLAGS="-O3
>>      >     >     >     -march=native -mtune=native" --with-mpi=1
>>      >     >     >     --with-mpi-dir=/home/eprice/software/mpich
>>      --with-mumps=1
>>      >     >     >     --with-mumps-dir=/home/eprice/software/mumps
>>      >     --with-parmetis=1
>>      >     >     >     --with-parmetis-dir=/home/eprice/software/parmetis
>>      >     --with-metis=1
>>      >     >     >     --with-metis-dir=/home/eprice/software/parmetis
>>      >     --with-ptscotch=1
>>      >     >     >     --with-ptscotch-dir=/home/eprice/software/scotch
>>      >     >     --with-scalapack=1
>>      >     >     >     --with-scalapack-dir=/home/eprice/software/scalapack
>>      >     >     >     [0]PETSC ERROR: #1 DMProjectLocal_Generic_Plex()
>>      line 347 in
>>       /h/sabriel0/src/petsc-3.9.2/src/dm/impls/plex/plexproject.c
>>      >     >     >     [0]PETSC ERROR: #2 DMProjectFunctionLocal_Plex()
>>      line 428 in
>>      >     >     >     [0]PETSC ERROR: #3 DMProjectFunctionLocal() line
>>      6265 in
>>      >     >     >     /h/sabriel0/src/petsc-3.9.2/src/dm/interface/dm.c
>>      >     >     >     [0]PETSC ERROR: #4 DMProjectFunction() line 6250 in
>>      >     >     >     (I know this is an optimized PETSc build, but I
>>      get the same
>>      >     >     error from
>>      >     >     >     my debug build, it's just much slower.)
>>      >     >     >     Ellen
>>      >     >     > What most experimenters take for granted before they
>>      begin their
>>      >     >     > experiments is infinitely more interesting than any
>>      results
>>      >     to which
>>      >     >     > their experiments lead.
>>      >     >     > -- Norbert Wiener
>>      >     >     > https://www.cse.buffalo.edu/~knepley/
>>      <https://www.cse.buffalo.edu/%7Eknepley/>
>>      >     >     <https://www.cse.buffalo.edu/%7Eknepley/>
>>      >     >     > <http://www.cse.buffalo.edu/%7Eknepley/>
>>      >     > What most experimenters take for granted before they begin their
>>      >     > experiments is infinitely more interesting than any results
>>      to which
>>      >     > -- Norbert Wiener
>>      > experiments is infinitely more interesting than any results to which
>>      > -- Norbert Wiener
>> -- Norbert Wiener
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181014/684c0179/attachment-0001.bin>
