[petsc-users] Order Adapting BDF timestepping
Constantinescu, Emil M.
emconsta at anl.gov
Fri Oct 12 09:14:28 CDT 2018
No, the current implementation does not seem to adapt the order, only
the time step. With increasing order, you typically get less and less
stability. There is no method of order 7 or higher. Order 6 is barely
stable. So it's not a lot of wiggle room to adapt the order in there.
Emil
On 10/12/18 7:38 AM, Moritz.Huck at isea.rwth-aachen.de wrote:
> Hi,
> does the BDF alogrithm adapt the order?
> If not are there method to get error estimates for orders higher and
> lower than the current one?
> (or adaption strategies which dont need these estimates)?
> Thanks,
> Moritz
