[petsc-users] How to get nodes list refer to unstructure mesh element
陳宗興 barrydog505 at gmail.com
Fri Oct 12 06:09:41 CDT 2018
Thanks for the tip!
Matthew Knepley <knepley at gmail.com> 於 2018年10月12日 週五 下午7:05寫道:
> If you only have cell-vertex meshes, then using the single-layer version
> DMPlexGetCone() is faster.
>   Thanks,
>      Matt
> On Fri, Oct 12, 2018 at 5:56 AM 陳宗興 <barrydog505 at gmail.com> wrote:
>> Thanks, I'll check them out.
>> Mark Adams <mfadams at lbl.gov> 於 2018年10月12日 週五 下午5:22寫道:
>>> You want to use DMPlexVecGetClosure:
>>> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMPLEX/DMPlexVecGetClosure.html
>>> The examples shown here don't close cells. What you
>>> want. src/dm/impls/plex/examples/tutorials/ex6.c does iterate over cells,
>>> and get the closure (vertices), which is what you want.
>>> Mark
>>> On Fri, Oct 12, 2018 at 4:58 AM 陳宗興 <barrydog505 at gmail.com> wrote:
>>>> Hi all,
>>>> I have import a .msh file from DMPlexCreateFromFile.
>>>> I have found DMDAGetElements in DMDA's ex5 having this function,
>>>> how can i do this from DMPlex or unstructure grid.
>>>> Are there any methods that can get nodes list refer to unstructure mesh
>>>> element?
>>>> for example :
>>>>        4
>>>>    /    1   \
>>>>  2 - - - - - 3           element [1]  >> nodes list [2 3 4]
>>>> Thanks a lot.
>>>> Best regards,
>>>> Barry
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181012/15e22252/attachment-0001.html>
