[petsc-users] DMPLEX project function error
Thu Oct 11 16:41:51 CDT 2018
On Thu, Oct 11, 2018 at 4:39 PM Ellen M. Price <ellen.price at cfa.harvard.edu>
wrote:
> I was working with a DMPLEX and FEM, following SNES example 12. I get
> the following error when I call DMProjectFunction, but I don't know what
> it means. Can anyone explain where I might have gone wrong, or at least
> what this error is telling me? I think the point closure size is
> correct, since my mesh is 3d simplex,
Yes, if you have 3D SIMPLEX mesh and are using P1 elements, then you would
have
4 dofs in the closure of a cell. The dual space dimension is the number of
dual space
basis vectors assigned to points in the closure. Since it is 1, it looks
like you have a P0
dual space. I assume you changed something in ex12?
     Matt
> but what is the dual space
> dimension, and where might I have set it incorrectly?
> [0]PETSC ERROR: Nonconforming object sizes
> [0]PETSC ERROR: The section point closure size 4 != dual space dimension 1
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.9.2, May, 20, 2018
> [0]PETSC ERROR: Configure options
> --prefix=/home/eprice/software/petsc-opt --with-hdf5=1
> --with-hdf5-dir=/home/eprice/software/hdf5-parallel --with-mpe=1
> --with-mpe-dir=/home/eprice/software/mpe --with-debugging=0
> LDFLAGS="-pthread -lz" COPTFLAGS="-O3 -march=native -mtune=native"
> CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
> -march=native -mtune=native" --with-mpi=1
> --with-mpi-dir=/home/eprice/software/mpich --with-mumps=1
> --with-mumps-dir=/home/eprice/software/mumps --with-parmetis=1
> --with-parmetis-dir=/home/eprice/software/parmetis --with-metis=1
> --with-metis-dir=/home/eprice/software/parmetis --with-ptscotch=1
> --with-ptscotch-dir=/home/eprice/software/scotch --with-scalapack=1
> --with-scalapack-dir=/home/eprice/software/scalapack
> [0]PETSC ERROR: #1 DMProjectLocal_Generic_Plex() line 347 in
> /h/sabriel0/src/petsc-3.9.2/src/dm/impls/plex/plexproject.c
> [0]PETSC ERROR: #2 DMProjectFunctionLocal_Plex() line 428 in
> [0]PETSC ERROR: #3 DMProjectFunctionLocal() line 6265 in
> /h/sabriel0/src/petsc-3.9.2/src/dm/interface/dm.c
> [0]PETSC ERROR: #4 DMProjectFunction() line 6250 in
> (I know this is an optimized PETSc build, but I get the same error from
> my debug build, it's just much slower.)
> Ellen
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181011/c3e36257/attachment.html>
