[petsc-users] Increasing norm with finer mesh
Weizhuo Wang
weizhuo2 at illinois.edu
Mon Oct 8 17:57:55 CDT 2018
The first plot is the norm with the flag -pc_type lu with respect to number
of grids in one axis (n), and the second plot is the norm without the flag
-pc_type lu.
Specifically, the norm is calculated by
norm = norm_2(numerical - analytic)/(n*n)
On Mon, Oct 8, 2018 at 5:47 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Oct 8, 2018 at 6:13 PM Weizhuo Wang <weizhuo2 at illinois.edu> wrote:
>> Sorry I was caught up with midterms for the last few days. I tried the lu
>> decomposition today and the 2-norm is pretty stable at ~ 10^-15, which is
>> expected for double precision. Since the discretization error is so small,
>> it would be reasonable to assume the rest is majority the algebraic error.
> What are you plotting? It looks like only the algebraic error or residual.
> There is absolutely no way your discretization error is 1e-14.
> Thanks,
> Matt
>> Then looking at the result without the -pc_type lu flag(second graph),
>> the error is asymptoting to a constant several magnitudes larger than the
>> tolerance set for the solver. (atol=1e-12, rtol=1e-9) Is this the expected
>> behavior? Shouldn't it decrease with finer grid?
>> [image: LU.png]
>> [image: Total.png]
>> On Tue, Oct 2, 2018 at 6:52 PM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Tue, Oct 2, 2018 at 5:26 PM Weizhuo Wang <weizhuo2 at illinois.edu>
>>> wrote:
>>>> I didn't specify a tolerance, it was using the default tolerance.
>>>> Doesn't the asymptoting norm implies finer grid won't help to get finer
>>>> solution?
>>> There are two things going on in your test, discretization error
>>> controlled by the grid, and algebraic error controlled by the solver. This
>>> makes it difficult to isolate what is happening. However, it seems clear
>>> that your plot is looking at algebraic error. You can confirm this by using
>>> -pc_type lu
>>> for the solve. Then all you have is discretization error.
>>> Thanks,
>>> Matt
>>>> Mark Adams <mfadams at lbl.gov> :
>>>>> On Tue, Oct 2, 2018 at 5:04 PM Weizhuo Wang <weizhuo2 at illinois.edu>
>>>>> wrote:
>>>>>> Yes I was using one norm in my Helmholtz code, the example code used
>>>>>> 2 norm. But now I am using 2 norm in both code.
>>>>>> Check the error
>>>>>> ierr = VecAXPY(x,-1.0,u); CHKERRQ(ierr);
>>>>>> ierr = VecNorm(x,NORM_1,&norm); CHKERRQ(ierr);
>>>>>> ierr = KSPGetIterationNumber(ksp,&its); CHKERRQ(ierr);
>>>>>> ierr = PetscPrintf(PETSC_COMM_WORLD,"Norm of error %g iterations
>>>>>> %D\n",(double)norm/(m*n),its); CHKERRQ(ierr);
>>>>>> I made a plot to show the increase:
>>>>> FYI, this is asymptoting to a constant. What solver tolerance are
>>>>> you using?
>>>>>> [image: Norm comparison.png]
>>>>>> Mark Adams <mfadams at lbl.gov>:
>>>>>>> On Tue, Oct 2, 2018 at 2:24 PM Weizhuo Wang <weizhuo2 at illinois.edu>
>>>>>>> wrote:
>>>>>>>> The example code and makefile are attached below. The whole thing
>>>>>>>> started as I tried to build a Helmholtz solver, and the mean error
>>>>>>>> (calculated by: sum( | numerical_sol - analytical_sol | / analytical_sol )
>>>>>>> This is a one norm. If you use max (instead of sum) then you don't
>>>>>>> need to scale. You do have to be careful about dividing by (near) zero.
>>>>>>>> increases as I use finer and finer grids.
>>>>>>> What was the rate of increase?
>>>>>>>> Then I looked at the example 12 (Laplacian solver) which is similar
>>>>>>>> to what I did to see if I have missed something. The example is using
>>>>>>>> 2_norm. I have made some minor modifications (3 places) on the code, you
>>>>>>>> can search 'Modified' in the code to see them.
>>>>>>>> If this helps: I configured the PETSc to use real and double
>>>>>>>> precision. Changed the name of the example code from ex12.c to ex12c.c
>>>>>>>> Thanks for all your reply!
>>>>>>>> Weizhuo
>>>>>>>> Smith, Barry F. <bsmith at mcs.anl.gov>
>>>>>>>>> Please send your version of the example that computes the mean
>>>>>>>>> norm of the grid; I suspect we are talking apples and oranges
>>>>>>>>> Barry
>>>>>>>>> > On Oct 1, 2018, at 7:51 PM, Weizhuo Wang <weizhuo2 at illinois.edu>
>>>>>>>>> wrote:
>>>>>>>>> > I also tried to divide the norm by m*n , which is the number of
>>>>>>>>> grids, the trend of norm still increases.
>>>>>>>>> > Thanks!
>>>>>>>>> > Weizhuo
>>>>>>>>> > On Mon, Oct 1, 2018 at 6:31 PM Weizhuo Wang <
>>>>>>>>> > Hi!
>>>>>>>>> > I'm recently trying out the example code provided with the KSP
>>>>>>>>> solver (ex12.c). I noticed that the mean norm of the grid increases as I
>>>>>>>>> use finer meshes. For example, the mean norm is 5.72e-8 at m=10 n=10.
>>>>>>>>> However at m=100, n=100, mean norm increases to 9.55e-6. This seems counter
>>>>>>>>> intuitive, since most of the time error should decreases when using finer
>>>>>>>>> grid. Am I doing this wrong?
>>>>>>>>> > The norm is misleading in that it is the l_2 norm, meaning just
>>>>>>>>> the sqrt of the sum of the squares of
>>>>>>>>> > the vector entries. It should be scaled by the volume element to
>>>>>>>>> approximate a scale-independent
>>>>>>>>> > norm (like the L_2 norm).
>>>>>>>>> > Thanks,
>>>>>>>>> > Matt
>>>>>>>>> > Thanks!
>>>>>>>>> > Wang Weizhuo
>>>>>>>>> > What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> > -- Norbert Wiener
>>>>>>>>> > https://www.cse.buffalo.edu/~knepley/
>>>>>>>>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__www.cse.buffalo.edu_-7Eknepley_&d=DwMFaQ&c=OCIEmEwdEq_aNlsP4fF3gFqSN-E3mlr2t9JcDdfOZag&r=hsLktHsuxNfF6zyuWGCN8x-6ghPYxhx4cV62Hya47oo&m=KjmDEsZ6w8LEry7nlv3Bw7-pczqWbKGueFU59VoIWZg&s=tEv9-AHhL2CIlmmVos0gFa5PAY9oMG3aTQlnfi62ivA&e=>
>>>>>>>>> > Wang Weizhuo
>>>>>>>> Wang Weizhuo
>>>>>> Wang Weizhuo
>>>> Wang Weizhuo
>>> experiments lead.
>>> -- Norbert Wiener
>>> <http://www.cse.buffalo.edu/~knepley/>
>> Wang Weizhuo
> experiments lead.
> -- Norbert Wiener
Wang Weizhuo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181008/889fbaa1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181008/889fbaa1/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181008/889fbaa1/attachment-0004.png>
Name: Norm comparison.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181008/889fbaa1/attachment-0005.png>
