[petsc-users] Increasing norm with finer mesh
Mon Oct 1 19:56:46 CDT 2018
On Mon, Oct 1, 2018 at 8:51 PM Weizhuo Wang <weizhuo2 at illinois.edu> wrote:
> I also tried to divide the norm by m*n , which is the number of grids, the
> trend of norm still increases.
We need to be precise. First, look at the initial residual, because that is
what you control with the initial
guess. You are saying that the initial residual does not asymptote? I would
be reluctant to believe that.
     Matt
> Thanks!
> Weizhuo
> Matthew Knepley <knepley at gmail.com> 于2018年10月1日周一 下午7:45写道:
>> On Mon, Oct 1, 2018 at 6:31 PM Weizhuo Wang <weizhuo2 at illinois.edu>
>> wrote:
>>> Hi!
>>> I'm recently trying out the example code provided with the KSP solver
>>> (ex12.c). I noticed that the mean norm of the grid increases as I use finer
>>> meshes. For example, the mean norm is 5.72e-8 at m=10 n=10. However at
>>> m=100, n=100, mean norm increases to 9.55e-6. This seems counter intuitive,
>>> since most of the time error should decreases when using finer grid. Am I
>>> doing this wrong?
>> The norm is misleading in that it is the l_2 norm, meaning just the sqrt
>> of the sum of the squares of
>> the vector entries. It should be scaled by the volume element to
>> approximate a scale-independent
>> norm (like the L_2 norm).
>>   Thanks,
>>      Matt
>>> Thanks!
>>> Wang Weizhuo
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> Wang Weizhuo
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181001/63fdba10/attachment-0001.html>
