[petsc-users] PETSC address vector c++ access
Matthew Knepley
knepley at gmail.com
Fri Nov 30 10:53:57 CST 2018
On Fri, Nov 30, 2018 at 9:50 AM RAELI ALICE via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi All,
> My team is working on a PETSC version of an existent code.
> In order to convert the main part of this work retaining the c++ levels of
> abstraction,
> we would access to c++ vector data structures easily.
> We would like to use the memory area allocated using c++ as a Petsc Vector
> a supposed pseudocode could be:
> *int data[] = { 1,2,3,4,5,6,7,8,9 };unsigned int sizeVectorPetsC =
> data.size();Vec v(data, sizeVectorPetsC); (Can it exists with easy access
> petsc routines?)*
> *cout<< "The mapped vector v is: [";*
> * PetscScalar *vecArray;*
> *PetscGetArray(v, &array);for (unsigned int i = 0; i < sizeVectorPetsC;
> i++){Informations of v are the informations of data.(same memory read by
> both data structures)}PetscRestoreArray(v,&array);*
> * cout<< "]"<< endl;*
> Is it provided this kind of duality between c++ and Petsc objects without
> a re-copy of the concerned informations?
Yes, I think you want
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecCreateSeqWithArray.html
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecCreateMPIWithArray.html#VecCreateMPIWithArray
and you can even do advanced things with the storage
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecPlaceArray.html#VecPlaceArray
but you need to be more careful.
Let me know if this does not do what you wanted.
Matt
> Thank you,
> Alice
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181130/fc4e922c/attachment.html>
