[petsc-users] How to get cell number from node number?
barry
barrydog505 at gmail.com
Fri Nov 30 08:43:19 CST 2018
Thanks!
On 11/30/18 9:28 PM, Matthew Knepley wrote:
> On Fri, Nov 30, 2018 at 8:19 AM barry via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> Sorry for the imprecisely description.
> I have an unstructured grid (DMPLEX) with triangle mesh.
> cell number (2 dim)={0}; line number (1 dim)={1, 2, 3}; node
> number (0 dim)={4, 5, 6}
> So, you have a 2D interpolated simplex mesh in DMPlex, which means it
> has vertices, edges, and cells.
> If you want the vertices on a given cell, you would get the closure
> and then filter out any points which are
> not vertices. For example,
> PetscInt *closure = NULL;
> PetscInt clSize, cl;
> ierr = DMPlexGetDepthStratum(dm, 0, &vStart, &vEnd);CHKERRQ(ierr);
> ierr = DMPlexGetTransitiveClosure(dm, cell, PETSC_TRUE, &clSize,
> &closure);CHKERRQ(ierr);
> for (cl = 0; cl < clSize*2; cl += 2) {
> const PetscInt point = closure[cl];
> if (point >= vStart && point < vEnd) {
> <this is a vertex>
> ierr = DMPlexRestoreTransitiveClosure(dm, cell, PETSC_TRUE, &clSize,
> If you do not use edges, then its much easier. Just call
> DMPlexGetCone(). If you do use edges, but also
> get the vertices all the time, you can make an index for this query,
> which will speed it up greatly at the
> cost of some memory.
> Thanks,
> Matt
> Thank you,
> Barry
> On 11/30/18 8:33 PM, Stefano Zampini wrote:
>> Il giorno Ven 30 Nov 2018, 15:05 Tsung-Hsing Chen via petsc-users
>> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> ha
>> scritto:
>> Hi,
>> Is there any function that can get cell number from the given
>> node number exist already?
>> Cell number of what? DMPLEX? And what is "node number"?
>> Thank you,
>> Barry
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181130/ed1aca99/attachment.html>
