[petsc-users] Some clarifications about TS ex3.c
Sajid Ali
sajidsyed2021 at u.northwestern.edu
Thu Nov 29 16:50:34 CST 2018
Another question I want to ask is about dttol that is used in the Monitor
function as follows :
417: dttol = .0001;
418: PetscOptionsGetReal(NULL,NULL,"-dttol",&dttol,NULL);
419: if (dt < dttol) {
420: dt *= .999;
421: TSSetTimeStep(ts,dt);
422: }
Is this decreasing dt if it's less than tolerance ?
I commented out the norm calculation (lines 404-415) the time is stuck at 0
( as per the output of -ts_monitor). But if I comment out the above lines
(417-422) as well, everything works fine. What explains this behaviour ?
Thank You!
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181129/0b95c7cc/attachment-0001.html>
