[petsc-users] Error: DM global to natural SF was not created when DMSetUseNatural has already been called
Danyang Su
danyang.su at gmail.com
Thu Nov 29 12:14:37 CST 2018
Hi Josh,
Sorry to bother you again.
I followed your suggestion but still cannot figure out what is wrong in
the following code. The global vector vec_global is non-zero. The
migration SF looks fine. But the vector after calling
DMPlexGlobalToNaturalEnd is always zero. Attached is the mesh I use and
screen output for the following code section.
!c check vec_global, all vec_global is non-zero
if (rank == 0) then
write(*,*) "vector view - petsc order"
end if
CALL VecView(vec_global,PETSC_VIEWER_STDOUT_WORLD,ierr)
CHKERRQ(ierr)
!c check migration sf, looks correct.
if (rank == 0) then
write(*,*) "check migration SF"
end if
call DMPlexGetMigrationSF(dmda_flow%da,sf,ierr)
CHKERRQ(ierr)
call PetscSFView(sf,PETSC_VIEWER_STDOUT_WORLD,ierr)
CHKERRQ(ierr)
!c global to natural ordering
call DMPlexGlobalToNaturalBegin(dmda_flow%da,vec_global, &
vec_natural,ierr)
CHKERRQ(ierr)
call DMPlexGlobalToNaturalEnd(dmda_flow%da,vec_global, &
vec_natural,ierr)
CHKERRQ(ierr)
!c check vec_global, vec_natural is always zero
if (rank == 0) then
write(*,*) "vector view - natural order"
end if
CALL VecView(vec_natural,PETSC_VIEWER_STDOUT_WORLD,ierr)
CHKERRQ(ierr)
Danyang
On 2018-11-28 9:58 p.m., Josh L wrote:
> you don't have to call DMPlexGetGlobalToNaturalSF
> DMPlexDistribute gives you one petscSF, and you will just use this
> petscSF in DMPlexSetMigrationSF
> it will look like this
> If (nsize /= 1) then
> CALL DMSetUseNatural(dm,PETSC_TRUE,ierr)
> CALL DMPlexDistribute(dm,0,pointSF,dmmpi,ierr);CHKERRQ(ierr)
> CALL DMPlexSetMigrationSF(dmmpi,pointSF,ierr)
> CALL DMDestroy(dm,ierr)
> dm=dmmpi
> If (rank == 0) write(*,'(///,A)') "Distributed mesh"
> CALL DMView(dm,PETSC_VIEWER_STDOUT_WORLD,ierr)
> Endif
> then you use DMPlexGlobalToNatural or NaturalToGlobal
> Danyang Su <danyang.su at gmail.com <mailto:danyang.su at gmail.com>> 於
> 2018年11月28日 週三 下午11:11寫道:
> Hi Josh,
> Thanks. DMPlexSetMigrationSF requires naturalSF as the input
> parameters. Is there any easy way to get naturalSF after
> DMPlexDistribute?
> I tried to use
> call DMPlexGetGlobalToNaturalSF(dmda_flow%da,naturalSF,ierr)
> CHKERRQ(ierr)
> call DMPlexSetMigrationSF(dmda_flow%da,naturalSF,ierr)
> CHKERRQ(ierr)
> after DMPlexDistribute but this does not solve the problem.
> I am not familar with graph theory that I am a little lost here.
> Would you please give me a little more detail.
> Thanks,
> Danyang
> On 18-11-28 07:52 PM, Josh L wrote:
>> Hi Danyang,
>> You have to call DMPlexSetMigrationSF after DMPlexDistribute.
>> Moreover , If you only run the code with 1 processor, then
>> natural ordering is global ordering and the pointSF is not created.
>> Thanks,
>> Josh
>> <petsc-users-request at mcs.anl.gov
>> <mailto:petsc-users-request at mcs.anl.gov>> 於 2018年11月28日 週三
>> 下午9:17寫道:
>> Send petsc-users mailing list submissions to
>> petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
>> To subscribe or unsubscribe via the World Wide Web, visit
>> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
>> or, via email, send a message with subject or body 'help' to
>> You can reach the person managing the list at
>> petsc-users-owner at mcs.anl.gov
>> <mailto:petsc-users-owner at mcs.anl.gov>
>> When replying, please edit your Subject line so it is more
>> specific
>> than "Re: Contents of petsc-users digest..."
>> Today's Topics:
>> 1. Re: Do we support to use NORM_X instead of NORM_2 to check
>> the convergence of KSP and SNES? (Smith, Barry F.)
>> 2. Re: A question regarding a potential use case for
>> DMNetwork
>> (Matthew Knepley)
>> 3. Error: DM global to natural SF was not created when
>> DMSetUseNatural has already been called (Danyang Su)
>> 4. I miss you. (chantalle at miroirdelame.com
>> <mailto:chantalle at miroirdelame.com>)
>> Message: 1
>> Date: Wed, 28 Nov 2018 22:03:26 +0000
>> From: "Smith, Barry F." <bsmith at mcs.anl.gov
>> <mailto:bsmith at mcs.anl.gov>>
>> To: Fande Kong <fdkong.jd at gmail.com <mailto:fdkong.jd at gmail.com>>
>> Cc: PETSc users list <petsc-users at mcs.anl.gov
>> <mailto:petsc-users at mcs.anl.gov>>
>> Subject: Re: [petsc-users] Do we support to use NORM_X instead of
>> NORM_2 to check the convergence of KSP and SNES?
>> Message-ID: <9A9B128F-AA95-40C7-BB28-31F687E9E65A at anl.gov
>> <mailto:9A9B128F-AA95-40C7-BB28-31F687E9E65A at anl.gov>>
>> Content-Type: text/plain; charset="us-ascii"
>> > On Nov 28, 2018, at 3:20 PM, Fande Kong via petsc-users
>> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>> > Hi Developers,
>> > I just checked into the SNES and KSP code. We always hard
>> code the Vec Norm as NORM_2 when computing the linear and
>> nonlinear residuals.
>> > Does this mean we have to use norm_2 to check the
>> convergence for both SNES and KSP?
>> No, you can in theory use some other norm in a custom
>> convergence test. BUT you get the NORM_2 essentially "for
>> free" while using some other norm requires you to compute
>> that norm; for SNES it is no big deal, just the cost of a
>> VecNorm(NORM_INFINITY) for example. But for GMRES it is very
>> expensive (one must compute the current solution then compute
>> the residual then compute the residual's norm; because GMRES
>> uses a recursive formula for the NORM_2 and does not actually
>> compute the solution or the residual at each iteration only
>> at the end).
>> Barry
>> > Fande,
>> Message: 2
>> Date: Wed, 28 Nov 2018 18:06:45 -0500
>> From: Matthew Knepley <knepley at gmail.com
>> <mailto:knepley at gmail.com>>
>> To: markus.lohmayer at fau.de <mailto:markus.lohmayer at fau.de>
>> Cc: PETSc <petsc-users at mcs.anl.gov
>> Subject: Re: [petsc-users] A question regarding a potential
>> use case
>> for DMNetwork
>> Message-ID:
>> <CAMYG4G=nCMa6qS2oO4EnA0s4Cq+4ykQWFKQtxh8ZwqYGgnvKdw at mail.gmail.com
>> <mailto:nCMa6qS2oO4EnA0s4Cq%2B4ykQWFKQtxh8ZwqYGgnvKdw at mail.gmail.com>>
>> Content-Type: text/plain; charset="utf-8"
>> On Wed, Nov 28, 2018 at 3:51 PM Markus Lohmayer via petsc-users <
>> > Dear PETSc users and developers,
>> > in particular those experienced with the relatively new
>> DMNetwork object,
>> > I would like to get some advice on wether it makes sense for my
>> > application to be built using this PETSc feature
>> > or if I am equally well served if I use plain Vec and Mat
>> objects.
>> > In the latter case, you might nevertheless have some good
>> advice for a
>> > novice PETSc user
>> > or you might know about something that helps me to come up
>> with a well
>> > architected solution.
>> > So the application context is closely linked to LTI
>> state-space models
>> > (and in particular two-port / n-port network models and their
>> > interconnections):
>> > x,t = A x + B u
>> > y = C x + D u
>> > More specifically, input ?u' and output ?y' are vectors (of
>> same length
>> > for all components).
>> > Different components will have different dimension of state
>> ?x' (and hence
>> > also ?A', ?B', ?C').
>> > These component models then have to be interconnected
>> according to a given
>> > topology:
>> If the interconnection topology is 1D, then yes DMNetwork is
>> designed to do
>> this. At the simplest level, you
>> could just use a 1D DMPlex, which is inside DMNetwork, and
>> hand code the
>> Section (data layout) and residual/Jacobian
>> assembly. DMNetwork is a higher level around this that lets
>> you put
>> "components" down on vertices and edges
>> that translate to data layout and residual evaluation. I
>> confess to not
>> understanding the residual part all the way.
>> If you start trying to modify an example, we can help you I
>> think.
>> Thanks,
>> Matt
>> > Some pair of outputs of model 1 feeds into the
>> corresponding pair of
>> > inputs of model 2 (and also the other way round by
>> symmetry), etc.
>> > After most (or even all) of the original inputs 'u_i' /
>> outputs 'y_i' have
>> > been eliminated (based on the given interconnection
>> structure amongst
>> > components),
>> > it will be necessary to use an iterative eigenvalue solver
>> to obtain
>> > eigenvectors for some interesting part of the spectrum.
>> > The models will probably not be "very large" in the
>> foreseeable future but
>> > this still doesn?t make e.g. MATLAB?s control toolbox an
>> option.
>> > I have seen the presentation by Hong Zhang (1) at this
>> year?s user meeting
>> > and I have looked at the paper ?Scalable Multiphysics
>> Network Simulation
>> > Using PETSc DMNetwork?.
>> > The use cases and concept of network presented therein were
>> slightly
>> > different from this one of interconnected multi-ports in
>> state-space
>> > formulation.
>> > Thanks you very much for your advice and reading this post.
>> > Best,
>> > Markus
>> experiments is infinitely more interesting than any results
>> to which their
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <https://www.cse.buffalo.edu/%7Eknepley/>
>> <http://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/%7Eknepley/>>
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL:
>> <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181128/82d57c0e/attachment-0001.html>
>> Message: 3
>> Date: Wed, 28 Nov 2018 17:56:56 -0800
>> From: Danyang Su <danyang.su at gmail.com
>> To: PETSc <petsc-users at mcs.anl.gov
>> Subject: [petsc-users] Error: DM global to natural SF was not
>> created
>> Message-ID: <d207da61-fe63-85b7-d85e-b961f69e3b1f at gmail.com
>> <mailto:d207da61-fe63-85b7-d85e-b961f69e3b1f at gmail.com>>
>> Content-Type: text/plain; charset=utf-8; format=flowed
>> Dear All,
>> I got the following error when using DMPlexGlobalToNatural
>> function
>> using 1 processor.
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Object is in wrong state
>> [0]PETSC ERROR: DM global to natural SF was not created.
>> You must call DMSetUseNatural() before DMPlexDistribute().
>> [0]PETSC ERROR: See
>> http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.10.2, Oct, 09, 2018
>> The same code does not return error when using more than 2
>> processors,
>> however, the vec_natural is always zero after calling
>> DMPlexGlobalToNaturalEnd.
>> DMSetUseNatural() has already been used before calling
>> DMPlexDistribute.
>> The code section looks like below
>> ???? if (rank == 0) then
>> ??????? call
>> DMPlexCreateFromCellList(Petsc_Comm_World,ndim,0,0,?????? &
>> num_nodes_per_cell,??????????????????????????????????????? &
>> Petsc_False,dmplex_cells,ndim,??????????????????????? &? !use
>> Petsc_True
>> to create intermediate mesh entities (faces, edges),
>> dmplex_verts,dmda_flow%da,ierr)
>> ??????? CHKERRQ(ierr)
>> ???? end if
>> ????? !c Set the flag for creating a mapping to the natural
>> order on
>> distribution
>> ????? call DMSetUseNatural(dmda_flow%da,PETSC_TRUE,ierr)
>> ????? CHKERRQ(ierr)
>> ????? !c distribute mesh over processes
>> ????? call
>> DMPlexDistribute(dmda_flow%da,stencil_width,??????????????? &
>> ??????????????????????????? PETSC_NULL_SF, distributedMesh,ierr)
>> ????? CHKERRQ(ierr)
>> ????? !c destroy original global mesh after distribution
>> ????? if (distributedMesh /= PETSC_NULL_DM) then
>> ??????? call DMDestroy(dmda_flow%da,ierr)
>> ??????? !c set the global mesh as distributed mesh
>> ??????? dmda_flow%da = distributedMesh
>> ????? end if
>> ??????? call
>> DMPlexCreateSection(dmda_flow%da,dmda_flow%dim,?????????? &
>> numFields,pNumComp,pNumDof,?????????? &
>> numBC,pBcField,?????????????????????? &
>> pBcCompIS,pBcPointIS,???????????????? &
>> PETSC_NULL_IS,??????????????????????? &
>> ???????????????????????????????? section,ierr)
>> ??????? call PetscSectionSetFieldName(section,0,'flow',ierr)
>> ??????? call DMSetSection(dmda_flow%da,section,ierr)
>> ??????? call PetscSectionDestroy(section,ierr)
>> ??????? call DMSetUp(dmda_flow%da,ierr)
>> ????? !c global - natural order
>> ????? call DMCreateLocalVector(dmda_flow%da,vec_loc,ierr)
>> ????? CHKERRQ(ierr)
>> ????? call DMCreateGlobalVector(dmda_flow%da,vec_global,ierr)
>> ????? CHKERRQ(ierr)
>> ????? call DMCreateGlobalVector(dmda_flow%da,vec_natural,ierr)
>> ????? CHKERRQ(ierr)
>> ????? !c zero entries
>> ????? call VecZeroEntries(vec_loc,ierr)
>> ????? CHKERRQ(ierr)
>> ????? !Get a pointer to vector data when you need access to
>> the array
>> ????? call VecGetArrayF90(vec_loc,vecpointer,ierr)
>> ????? CHKERRQ(ierr)
>> ????? do inode = 1, num_nodes
>> ??????? vecpointer(inode) = node_idx_lg2pg(inode) !vector
>> value using
>> PETSc global order, negative ghost index has been reversed
>> ????? end do
>> ????? !Restore the vector when you no longer need access to
>> the array
>> ????? call VecRestoreArrayF90(vec_loc,vecpointer,ierr)
>> ????? CHKERRQ(ierr)
>> ????? !Insert values into global vector
>> ????? call
>> DMLocalToGlobalBegin(dmda_flow%da,vec_loc,INSERT_VALUES,??? &
>> ??????????????????????????????? vec_global,ierr)
>> ????? CHKERRQ(ierr)
>> ????? call
>> DMLocalToGlobalEnd(dmda_flow%da,vec_loc,INSERT_VALUES,????? &
>> ????? CHKERRQ(ierr)
>> ????? !c global to natural ordering
>> ????? call
>> DMPlexGlobalToNaturalBegin(dmda_flow%da,vec_global,???????? &
>> ????????????????????????????????????? vec_natural,ierr)
>> ????? CHKERRQ(ierr)
>> ????? call
>> DMPlexGlobalToNaturalEnd(dmda_flow%da,vec_global,?????????? &
>> ????? CHKERRQ(ierr)
>> Is there anything missing in the code that
>> DMPlexGlobalToNatural... does
>> not work properly?
>> Thanks,
>> Danyang
>> Message: 4
>> Date: Wed, 28 Nov 2018 19:17:12 -0800 (MSK)
>> From: chantalle at miroirdelame.com
>> To: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
>> Subject: [petsc-users] I miss you.
>> Message-ID:
>> <9Fjct2o-RpyVfYXQLI2r_q at ismtpd0742h6ebv4.miroirdelame.com
>> <mailto:9Fjct2o-RpyVfYXQLI2r_q at ismtpd0742h6ebv4.miroirdelame.com>>
>> http://adehinxy.ru/?adehinxy adehinxy
>> http://ahmnwy.biz/?ahmnwy ahmnwy http://morst.ru/?morst morst
>> http://bfils.ua/?bfils bfils http://abcmnvw.biz/?abcmnvw
>> abcmnvw https://bchlqsux.net/?bchlqsux bchlqsux
>> http://fhikpqvy.net/?fhikpqvy fhikpqvy
>> https://bejkqu.info/?bejkqu bejkqu
>> https://cdehnsxy.ru/?cdehnsxy cdehnsxy
>> http://bcdhnopx.info/?bcdhnopx bcdhnopx
>> https://elpuz.ua/?elpuz elpuz https://bdeftvw.info/?bdeftvw
>> bdeftvw http://dgmnou.ru/?dgmnou dgmnou
>> https://aiklnvx.com/?aiklnvx aiklnvx
>> http://ijoqrsvw.com/?ijoqrsvw ijoqrsvw
>> http://cdehmquy.biz/?cdehmquy cdehmquy
>> https://gjoqx.net/?gjoqx gjoqx https://bhlnpqvw.net/?bhlnpqvw
>> bhlnpqvw http://bdfiuwyz.net/?bdfiuwyz bdfiuwyz
>> https://abesty.info/?abesty abesty
>> https://gjlmtuv.net/?gjlmtuv gjlmtuv http://ivxyz.info/?ivxyz
>> ivxyz http://aeops.info/?aeops aeops http://acdlv.ru/?acdlv
>> acdlv http://fgimqw.net/?fgimqw fgimqw
>> https://fgkrxz.info/?fgkrxz fgkrxz
>> http://abfhnvxy.ua/?abfhnvxy abfhnvxy
>> https://bcdeipsy.ru/?bcdeipsy bcdeipsy
>> http://bdimvwy.ru/?bdimvwy bdimvwy http://fnpqry.info/?fnpqry
>> fnpqry https://aklstwx.ru/?aklstwx aklstwx
>> http://bjloq.com/?bjloq bjloq http://dkmsuv.info/?dkmsuv
>> dkmsuv http://afinptuw.ru/?afinptuw afinptuw
>> https://bijnqvx.biz/?bijnqvx bijnqvx
>> https://behlxz.info/?behlxz behlxz
>> http://bgjkquyz.biz/?bgjkquyz bgjkquyz
>> http://aehnpqw.net/?aehnpqw aehnpqw
>> http://cghjmpqu.com/?cghjmpqu cghjmpqu
>> http://aboruy.com/?aboruy aboruy http://fjryz.ru/?fjryz fjryz
>> https://cdnqy.info/?cdnqy cdnqy http://bfgjmost.net/?bfgjmost
>> bfgjmost https://bhnou.ua/?bhnou bhnou
>> https://dhilm.com/?dhilm dhilm http://abijmrtx.net/?abijmrtx
>> abijmrtx http://acefnv.com/?acefnv acefnv
>> http://gilmtu.com/?gilmtu gilmtu https://egjltuz.biz/?egjltuz
>> egjltuz http://afghpsv.net/?afghpsv afghpsv
>> http://chkltvx.ua/?chkltvx chkltvx http://befkyz.com/?befkyz
>> befkyz https://bcfhmprw.com/?bcfhmprw bcfhmprw
>> https://bjklpqs.info/?bjklpqs bjklpqs http://cegpt.ua/?cegpt
>> cegpt https://klntvw.biz/?klntvw klntvw https://ejkmq.
>> ua/?ejkmq ejkmq https://bgqvx.info/?bgqvx bgqvx
>> https://dqrsuvw.com/?dqrsuvw dqrsuvw
>> http://bcekrsu.net/?bcekrsu bcekrsu
>> https://dlmqwy.com/?dlmqwy dlmqwy http://abhnsvz.ru/?abhnsvz
>> abhnsvz https://bdfhjoqr.info/?bdfhjoqr bdfhjoqr
>> http://ceijlprw.net/?ceijlprw ceijlprw
>> https://ijlqsw.net/?ijlqsw ijlqsw
>> https://einrvxz.net/?einrvxz einrvxz
>> https://ikmtxz.net/?ikmtxz ikmtxz http://adkmqsz.biz/?adkmqsz
>> adkmqsz http://bchnox.com/?bchnox bchnox
>> https://ckptvw.com/?ckptvw ckptvw http://dgops.com/?dgops
>> dgops https://bfnrtxy.info/?bfnrtxy bfnrtxy
>> http://bdnpstu.info/?bdnpstu bdnpstu
>> http://dlnprsx.ua/?dlnprsx dlnprsx https://gjnrx.com/?gjnrx
>> gjnrx http://abcsvz.com/?abcsvz abcsvz
>> http://gknrsv.ru/?gknrsv gknrsv https://fkmouxz.com/?fkmouxz
>> fkmouxz http://bcpsx.com/?bcpsx bcpsx
>> http://bckoqx.info/?bckoqx bckoqx https://bcdepq.ru/?bcdepq
>> bcdepq http://kqswy.net/?kqswy kqswy
>> https://bdgjnuy.ru/?bdgjnuy bdgjnuy
>> https://cgiklsvz.info/?cgiklsvz cgiklsvz
>> https://bfgnprwy.net/?bfgnprwy bfg
>> nprwy https://bejmnqrw.com/?bejmnqrw bejmnqrw
>> http://gilopqwy.ua/?gilopqwy gilopqwy
>> https://fjopry.ru/?fjopry fjopry http://kmrvwy.biz/?kmrvwy
>> kmrvwy https://eglotuv.net/?eglotuv eglotuv
>> http://cdhnsvwx.com/?cdhnsvwx cdhnsvwx
>> http://ahmqv.com/?ahmqv ahmqv https://fkqxy.ua/?fkqxy fkqxy
>> https://gjoquvwx.net/?gjoquvwx gjoquvwx
>> https://abcfouw.biz/?abcfouw abcfouw
>> https://abcekn.ru/?abcekn abcekn http://ijnruvz.com/?ijnruvz
>> ijnruvz http://mqruv.ua/?mqruv mqruv
>> https://afklmu.biz/?afklmu afklmu
>> https://abcgptyz.biz/?abcgptyz abcgptyz
>> https://bfjsuz.ua/?bfjsuz bfjsuz http://ahmpsx.ua/?ahmpsx
>> ahmpsx https://iklns.com/?iklns iklns https://hlnvx.ua/?hlnvx
>> hlnvx http://adiklmp.com/?adiklmp adiklmp
>> https://fghprs.biz/?fghprs fghprs http://acmopvw.ru/?acmopvw
>> acmopvw http://cdmuw.ua/?cdmuw cdmuw
>> http://bfkpwxz.biz/?bfkpwxz bfkpwxz http://lqrtwy.ru/?lqrtwy
>> lqrtwy https://aclmruvw.biz/?aclmruvw aclmruvw
>> http://bcfhmsz.net/?bcfhmsz bcfhmsz
>> http://bcgknpry.biz/?bcgknpry bcgknpry https://bfl
>> mnoq.info/?bflmnoq <http://mnoq.info/?bflmnoq> bflmnoq
>> https://bepsy.info/?bepsy bepsy http://gknosuw.net/?gknosuw
>> gknosuw http://ajoruvz.com/?ajoruvz ajoruvz
>> http://cotxz.ru/?cotxz cotxz https://deintwx.net/?deintwx
>> deintwx https://eghijkuy.com/?eghijkuy eghijkuy
>> http://dginwx.ua/?dginwx dginwx http://aenoxy.net/?aenoxy
>> aenoxy https://dghlpuvx.ru/?dghlpuvx dghlpuvx
>> http://cefor.info/?cefor cefor https://afioz.biz/?afioz afioz
>> https://deklmuvw.com/?deklmuvw deklmuvw
>> http://cfgimox.biz/?cfgimox cfgimox
>> http://cinquvz.ua/?cinquvz cinquvz https://acilsy.ua/?acilsy
>> acilsy http://bfhlnop.net/?bfhlnop bfhlnop
>> https://fijluz.net/?fijluz fijluz
>> https://dfjnostv.ua/?dfjnostv dfjnostv
>> https://aginsty.net/?aginsty aginsty
>> http://iknxyz.biz/?iknxyz iknxyz http://agopu.net/?agopu
>> agopu http://bdkopst.ua/?bdkopst bdkopst
>> https://aghlox.net/?aghlox aghlox https://cdgpu.com/?cdgpu
>> cdgpu https://jkmpuwyz.net/?jkmpuwyz jkmpuwyz
>> http://ijlmuvw.com/?ijlmuvw ijlmuvw
>> https://gkmrtvwy.biz/?gkmrtvwy gkmrtvwy http://aefhty.inf
>> o/?aefhty aefhty http://afjklsux.net/?afjklsux afjklsux
>> http://mprvyz.biz/?mprvyz mprvyz https://bdjkpx.ua/?bdjkpx
>> bdjkpx http://aciknovw.net/?aciknovw aciknovw
>> https://aftuxy.ua/?aftuxy aftuxy
>> https://ajnpvxyz.ua/?ajnpvxyz ajnpvxyz
>> http://fijqrv.com/?fijqrv fijqrv
>> https://ahmquvw.info/?ahmquvw ahmquvw
>> https://ghklmqvy.com/?ghklmqvy ghklmqvy
>> http://aehkty.com/?aehkty aehkty https://aclpsuz.ru/?aclpsuz
>> aclpsuz https://ghoqstvy.com/?ghoqstvy ghoqstvy
>> https://dghnqrty.ru/?dghnqrty dghnqrty
>> https://agorx.com/?agorx agorx https://adejrv.ru/?adejrv
>> adejrv http://hkopuvwz.net/?hkopuvwz hkopuvwz
>> http://bcdeghvx.ru/?bcdeghvx bcdeghvx
>> http://bdfgruvy.com/?bdfgruvy bdfgruvy
>> https://cmuvy.biz/?cmuvy cmuvy https://abjkmp.ua/?abjkmp
>> abjkmp http://abcfirvz.ru/?abcfirvz abcfirvz
>> http://clqruwxy.com/?clqruwxy clqruwxy
>> https://fhikoq.net/?fhikoq fhikoq
>> https://bfgnsvwz.biz/?bfgnsvwz bfgnsvwz
>> http://fhjkor.biz/?fhjkor fhjkor
>> https://dfgkouyz.com/?dfgkouyz dfgkouyz
>> https://acfhmqtz.info/?acfhmq
>> tz acfhmqtz https://ejmnpt.biz/?ejmnpt ejmnpt
>> http://dfgnrtu.ru/?dfgnrtu dfgnrtu
>> https://diknswx.biz/?diknswx diknswx
>> https://hjnsz.info/?hjnsz hjnsz https://cdjlq.ua/?cdjlq cdjlq
>> https://iowxy.ru/?iowxy iowxy https://fhjltux.net/?fhjltux
>> fhjltux http://ablmv.com/?ablmv ablmv
>> http://bdiorswz.ru/?bdiorswz bdiorswz http://cnopr.ru/?cnopr
>> cnopr http://adgopz.ru/?adgopz adgopz
>> http://bdefimsu.ru/?bdefimsu bdefimsu http://ghmqr.net/?ghmqr
>> ghmqr https://cdetv.ru/?cdetv cdetv
>> https://bdkortu.biz/?bdkortu bdkortu http://djopv.biz/?djopv
>> djopv http://aiknorw.biz/?aiknorw aiknorw
>> https://bfmqr.net/?bfmqr bfmqr http://klmox.com/?klmox klmox
>> https://fimqsv.biz/?fimqsv fimqsv https://fkopq.ru/?fkopq
>> fkopq http://aglpx.com/?aglpx aglpx http://dfhquv.biz/?dfhquv
>> dfhquv https://bfgjoq.com/?bfgjoq bfgjoq
>> https://cklnz.ru/?cklnz cklnz http://cfijqrv.net/?cfijqrv
>> cfijqrv https://aekuvxz.net/?aekuvxz aekuvxz
>> https://ghijkstx.info/?ghijkstx ghijkstx
>> http://abilmsz.info/?abilmsz abilmsz https://b
>> fhsvyz.ru/?bfhsvyz <http://fhsvyz.ru/?bfhsvyz> bfhsvyz
>> http://eqsuv.ua/?eqsuv eqsuv http://ghinqsx.biz/?ghinqsx
>> ghinqsx https://acgkmnpu.com/?acgkmnpu acgkmnpu
>> http://elrty.ru/?elrty elrty https://cdgkoz.net/?cdgkoz
>> cdgkoz http://dimnosw.info/?dimnosw dimnosw
>> http://abegnwx.biz/?abegnwx abegnwx
>> http://abejnsx.net/?abejnsx abejnsx
>> https://emnorxz.ru/?emnorxz emnorxz http://abfsz.ua/?abfsz
>> abfsz https://imqrvy.net/?imqrvy imqrvy
>> https://cdgjmqrv.com/?cdgjmqrv cdgjmqrv
>> http://bdfostyz.net/?bdfostyz bdfostyz
>> https://lnorxz.biz/?lnorxz lnorxz http://afgruvw.ru/?afgruvw
>> afgruvw https://cefivyz.com/?cefivyz cefivyz
>> https://gmqrt.com/?gmqrt gmqrt
>> https://acdimqrw.info/?acdimqrw acdimqrw
>> http://abchjm.ru/?abchjm abchjm http://alnqs.biz/?alnqs alnqs
>> https://ijqwz.ua/?ijqwz ijqwz https://adfjstx.biz/?adfjstx
>> adfjstx https://cghlqt.net/?cghlqt cghlqt
>> http://ijrvyz.ua/?ijrvyz ijrvyz https://ahluv.net/?ahluv
>> ahluv http://acdfgn.net/?acdfgn acdfgn
>> https://hijnru.ua/?hijnru hijnru https://ghnuvy.ru/?ghnuvy
>> ghnuvy http
>> ://aeiky.com/?aeiky <http://aeiky.com/?aeiky> aeiky
>> https://bdilnov.info/?bdilnov bdilnov
>> https://cjlnpqru.biz/?cjlnpqru cjlnpqru
>> https://cgjqtv.biz/?cgjqtv cgjqtv
>> https://abcnsvz.biz/?abcnsvz abcnsvz
>> http://abegopsu.biz/?abegopsu abegopsu
>> https://bcmstuvy.net/?bcmstuvy bcmstuvy
>> https://bhjknsuz.net/?bhjknsuz bhjknsuz
>> http://aceklno.info/?aceklno aceklno
>> http://diotvyz.ru/?diotvyz diotvyz
>> https://aefkmruw.info/?aefkmruw aefkmruw
>> https://cdghlmnz.info/?cdghlmnz cdghlmnz
>> https://bcgijmow.net/?bcgijmow bcgijmow
>> http://moruwx.ua/?moruwx moruwx https://bhjnrt.ru/?bhjnrt
>> bhjnrt https://eimoptu.ua/?eimoptu eimoptu
>> https://achptv.info/?achptv achptv https://boptux.biz/?boptux
>> boptux http://acmovz.ua/?acmovz acmovz
>> https://abfmnpw.info/?abfmnpw abfmnpw
>> https://afiknvz.biz/?afiknvz afiknvz http://ehnps.ua/?ehnps
>> ehnps https://dnpuw.biz/?dnpuw dnpuw
>> https://abflmns.biz/?abflmns abflmns https://fmuyz.biz/?fmuyz
>> fmuyz http://bejkvz.info/?bejkvz bejkvz
>> https://dfkmnyz.ua/?dfkmnyz dfkmnyz http://cfgnsvx.biz/?cfgnsv
>> x cfgnsvx http://abdjsw.ru/?abdjsw abdjsw
>> https://abelrvx.biz/?abelrvx abelrvx
>> https://abjmoy.ru/?abjmoy abjmoy http://hmnqz.net/?hmnqz
>> hmnqz https://dhkntv.ru/?dhkntv dhkntv
>> http://bgqsyz.biz/?bgqsyz bgqsyz
>> http://eghkmsux.net/?eghkmsux eghkmsux
>> https://acehlrsv.info/?acehlrsv acehlrsv
>> https://lnpruvy.com/?lnpruvy lnpruvy http://cefmtu.ua/?cefmtu
>> cefmtu https://hjnqrt.net/?hjnqrt hjnqrt
>> http://ceiktvw.ru/?ceiktvw ceiktvw http://cfjmu.info/?cfjmu
>> cfjmu https://cfhmn.com/?cfhmn cfhmn http://cdfqr.net/?cdfqr
>> cdfqr http://adelmvz.ru/?adelmvz adelmvz
>> http://abflnsvx.com/?abflnsvx abflnsvx
>> http://bjpqv.biz/?bjpqv bjpqv https://fjpqux.biz/?fjpqux
>> fjpqux http://fpqtvyz.net/?fpqtvyz fpqtvyz
>> http://cdflstwz.net/?cdflstwz cdflstwz
>> https://egjostux.ua/?egjostux egjostux
>> https://cjlnpy.ua/?cjlnpy cjlnpy https://bcfgmz.com/?bcfgmz
>> bcfgmz http://dfnouz.ua/?dfnouz dfnouz
>> http://cfikqv.net/?cfikqv cfikqv https://dehkqw.net/?dehkqw
>> dehkqw http://fhkqs.com/?fhkqs fhkqs http://dijkl.com/?dijkl
>> dijkl http://aeglu.com/?aeglu aeglu
>> http://dgikmpy.info/?dgikmpy dgikmpy
>> https://brsuz.info/?brsuz brsuz http://acfglopu.ru/?acfglopu
>> acfglopu https://cdjqx.net/?cdjqx cdjqx
>> https://aefimst.biz/?aefimst aefimst
>> http://bfikmuw.net/?bfikmuw bfikmuw
>> http://abhioqvw.ua/?abhioqvw abhioqvw
>> http://abdilmo.net/?abdilmo abdilmo
>> https://bhlovx.info/?bhlovx bhlovx
>> https://fgvwxz.info/?fgvwxz fgvwxz
>> http://afhjpqsv.biz/?afhjpqsv afhjpqsv
>> http://deilrsv.com/?deilrsv deilrsv
>> http://cijlmnt.ru/?cijlmnt cijlmnt https://bfkmtw.ua/?bfkmtw
>> bfkmtw https://adkxy.ru/?adkxy adkxy
>> https://blpqxy.com/?blpqxy blpqxy
>> https://efgilor.net/?efgilor efgilor
>> https://abcdky.info/?abcdky abcdky
>> https://befgikqu.ru/?befgikqu befgikqu
>> https://ipsuvwy.com/?ipsuvwy ipsuvwy https://fjlsu.biz/?fjlsu
>> fjlsu https://kpquw.com/?kpquw kpquw
>> https://bfjkoqvy.net/?bfjkoqvy bfjkoqvy
>> http://dijopsz.biz/?dijopsz dijopsz
>> http://acfhrsz.ua/?acfhrsz acfhrsz
>> https://bfhrstvy.ua/?bfhrstvy bfhrstvy
>> http://afglw.info/?afglw afglw
>> https://bcjqrvw.net/?bcjqrvw bcjqrvw https://hiotz.ru/?hiotz
>> hiotz https://abefmswx.biz/?abefmswx abefmswx
>> http://acgkopyz.ua/?acgkopyz acgkopyz
>> https://fijln.com/?fijln fijln http://befmquwz.info/?befmquwz
>> befmquwz https://hijory.ua/?hijory hijory
>> http://cdfhr.info/?cdfhr cdfhr https://ahiksx.ua/?ahiksx
>> ahiksx https://aghmxy.ru/?aghmxy aghmxy
>> https://hnopqt.net/?hnopqt hnopqt
>> https://fiklnrsw.ru/?fiklnrsw fiklnrsw http://hknpv.ru/?hknpv
>> hknpv https://abdfmotw.net/?abdfmotw abdfmotw
>> http://bcfhpvx.biz/?bcfhpvx bcfhpvx
>> http://beimrty.net/?beimrty beimrty
>> http://dgnsvwy.ua/?dgnsvwy dgnsvwy
>> https://aghjstvw.com/?aghjstvw aghjstvw
>> http://gpqsuxy.ru/?gpqsuxy gpqsuxy https://finop.info/?finop
>> finop http://bcdhsy.biz/?bcdhsy bcdhsy
>> http://cfhmnvy.net/?cfhmnvy cfhmnvy
>> https://hjopuw.net/?hjopuw hjopuw https://akmou.biz/?akmou
>> akmou https://fgkntuw.biz/?fgkntuw fgkntuw
>> https://adfjsw.com/?adfjsw adfjsw
>> https://bdjmrsty.biz/?bdjmrsty bdjmrsty
>> http://grtuz.ru/?grtuz grtuz https://cgiq
>> w.info/?cgiqw <http://w.info/?cgiqw> cgiqw
>> http://acenpvw.ru/?acenpvw acenpvw https://dmnrz.ru/?dmnrz
>> dmnrz http://deglqtu.com/?deglqtu deglqtu
>> http://ilpqrtuw.com/?ilpqrtuw ilpqrtuw
>> https://gnoqvxz.com/?gnoqvxz gnoqvxz
>> https://hijkmsu.ru/?hijkmsu hijkmsu
>> http://cistxyz.biz/?cistxyz cistxyz
>> https://adklmns.ru/?adklmns adklmns https://hmqrwy.ua/?hmqrwy
>> hmqrwy https://crsuv.ru/?crsuv crsuv
>> http://abejkmoz.ua/?abejkmoz abejkmoz
>> http://abjpqu.ua/?abjpqu abjpqu
>> https://ehjkopuz.info/?ehjkopuz ehjkopuz
>> http://iovwz.ua/?iovwz iovwz https://emntvwx.net/?emntvwx
>> emntvwx http://eghksx.info/?eghksx eghksx
>> https://bmnps.com/?bmnps bmnps https://cinopuv.net/?cinopuv
>> cinopuv http://efijnptz.biz/?efijnptz efijnptz
>> http://cehilnp.net/?cehilnp cehilnp http://denprw.ru/?denprw
>> denprw http://adglpwz.net/?adglpwz adglpwz
>> http://dehimosu.biz/?dehimosu dehimosu
>> https://abchprwy.com/?abchprwy abchprwy
>> http://dlnory.info/?dlnory dlnory http://cehnwyz.com/?cehnwyz
>> cehnwyz http://aghlopy.ua/?aghlopy aghlopy http://fhjksuvz
>> .com/?fhjksuvz fhjksuvz http://bijmy.com/?bijmy bijmy
>> https://adhjw.com/?adhjw adhjw
>> https://emnprwyz.info/?emnprwyz emnprwyz
>> http://dgmnw.ru/?dgmnw dgmnw https://cdgimruv.com/?cdgimruv
>> cdgimruv http://bcdjqst.biz/?bcdjqst bcdjqst
>> https://lmquv.ru/?lmquv lmquv http://degiptv.info/?degiptv
>> degiptv http://hlnvy.ru/?hlnvy hlnvy
>> http://gklmvx.info/?gklmvx gklmvx
>> http://behlpstz.com/?behlpstz behlpstz
>> https://efginz.com/?efginz efginz
>> https://deilmnru.biz/?deilmnru deilmnru
>> http://bdehoqux.ru/?bdehoqux bdehoqux
>> http://doqvy.info/?doqvy doqvy http://jlorw.info/?jlorw jlorw
>> https://cfmtvy.net/?cfmtvy cfmtvy
>> http://agkmqvxy.biz/?agkmqvxy agkmqvxy
>> https://ehnrux.ru/?ehnrux ehnrux https://ahlmpyz.biz/?ahlmpyz
>> ahlmpyz https://dhilqxyz.com/?dhilqxyz dhilqxyz
>> http://beosz.biz/?beosz beosz http://jkmtvx.ru/?jkmtvx jkmtvx
>> http://aefiuw.ua/?aefiuw aefiuw http://bgimy.info/?bgimy
>> bgimy https://acdfhimy.info/?acdfhimy acdfhimy
>> http://bdfpv.info/?bdfpv bdfpv https://lnopux.info/?lnopux
>> lnopux
>> https://iknqstux.ua/?iknqstux iknqstux
>> https://binxy.ru/?binxy binxy http://abflsv.net/?abflsv
>> abflsv http://cghkmtvz.info/?cghkmtvz cghkmtvz
>> http://flpqrxz.biz/?flpqrxz flpqrxz https://cfgnvz.ua/?cfgnvz
>> cfgnvz https://jtuvx.com/?jtuvx jtuvx https://fgikl.ru/?fgikl
>> fgikl http://ehikrs.ru/?ehikrs ehikrs
>> http://beghqx.ru/?beghqx beghqx http://dhijlrsw.com/?dhijlrsw
>> dhijlrsw http://elqst.ru/?elqst elqst
>> https://abfklmns.biz/?abfklmns abfklmns
>> https://cilnorw.ua/?cilnorw cilnorw https://anoqu.ua/?anoqu
>> anoqu http://adikquz.com/?adikquz adikquz
>> http://abcpwyz.ua/?abcpwyz abcpwyz https://fiqwxz.ru/?fiqwxz
>> fiqwxz http://bcivw.ru/?bcivw bcivw
>> https://acdfnrz.ua/?acdfnrz acdfnrz
>> https://jmopqtw.info/?jmopqtw jmopqtw
>> https://abdeghtv.biz/?abdeghtv abdeghtv
>> http://aceoprw.net/?aceoprw aceoprw http://forvy.ua/?forvy
>> forvy https://abgjknpv.com/?abgjknpv abgjknpv
>> http://bcdgimr.info/?bcdgimr bcdgimr
>> https://flntvw.biz/?flntvw flntvw http://bcdnqvx.net/?bcdnqvx
>> bcdnqvx http://defjnqvw.com/
>> ?defjnqvw defjnqvw http://ekmouvwy.biz/?ekmouvwy ekmouvwy
>> http://cijpqsxz.biz/?cijpqsxz cijpqsxz
>> http://dopstyz.ua/?dopstyz dopstyz http://cinow.com/?cinow
>> cinow http://cdejmrs.info/?cdejmrs cdejmrs
>> http://fgknprwz.info/?fgknprwz fgknprwz
>> https://binpquxy.com/?binpquxy binpquxy
>> https://afhqrtu.biz/?afhqrtu afhqrtu http://cemqtv.ru/?cemqtv
>> cemqtv http://bgnqsz.info/?bgnqsz bgnqsz
>> http://cdfjprsv.ua/?cdfjprsv cdfjprsv
>> https://jmqstz.biz/?jmqstz jmqstz http://adhuw.info/?adhuw
>> adhuw http://deswz.ua/?deswz deswz https://ehkmnw.com/?ehkmnw
>> ehkmnw http://kmsxy.ua/?kmsxy kmsxy
>> http://benotvw.info/?benotvw benotvw
>> https://dhinops.biz/?dhinops dhinops
>> https://hklnpqtv.ru/?hklnpqtv hklnpqtv
>> https://gjnqrtwx.info/?gjnqrtwx gjnqrtwx
>> https://dortvw.biz/?dortvw dortvw http://cdghjp.com/?cdghjp
>> cdghjp http://abchnoqx.com/?abchnoqx abchnoqx
>> http://abnsz.biz/?abnsz abnsz https://acdnqwy.info/?acdnqwy
>> acdnqwy http://befilpv.com/?befilpv befilpv
>> http://fijrux.biz/?fijrux fijrux https://aknqrtu
>> z.ru/?aknqrtuz <http://z.ru/?aknqrtuz> aknqrtuz
>> http://abfoqwz.ru/?abfoqwz abfoqwz
>> https://defikv.info/?defikv defikv
>> http://abcoqtz.com/?abcoqtz abcoqtz
>> https://dfirxz.net/?dfirxz dfirxz
>> http://bdfipqux.net/?bdfipqux bdfipqux
>> http://bcgqx.net/?bcgqx bcgqx https://bdfhl.ua/?bdfhl bdfhl
>> http://ahikmpqt.info/?ahikmpqt ahikmpqt
>> https://aghqrt.com/?aghqrt aghqrt https://afhosxz.ru/?afhosxz
>> afhosxz https://ehsvx.ru/?ehsvx ehsvx
>> http://gknquvw.info/?gknquvw gknquvw
>> https://gilmpqw.ru/?gilmpqw gilmpqw http://fhopy.biz/?fhopy
>> fhopy https://bcmpux.net/?bcmpux bcmpux
>> https://adfmrsuy.info/?adfmrsuy adfmrsuy
>> https://fmtuvx.net/?fmtuvx fmtuvx
>> https://defjmswy.net/?defjmswy defjmswy
>> https://ahijmrsz.info/?ahijmrsz ahijmrsz
>> https://cerwx.biz/?cerwx cerwx https://behqz.biz/?behqz behqz
>> https://behioqyz.ru/?behioqyz behioqyz
>> https://admrsvxz.com/?admrsvxz admrsvxz
>> https://cefhipqw.com/?cefhipqw cefhipqw
>> http://deopsx.ru/?deopsx deopsx http://acfgksz.info/?acfgksz
>> acfgksz http://hjlmqst.info/?hjlmqst hjlmqst http:/
>> /efgnrsux.net/?efgnrsux <http://efgnrsux.net/?efgnrsux>
>> efgnrsux http://adflovz.info/?adflovz adflovz
>> http://acopu.ua/?acopu acopu https://chilnqrs.ru/?chilnqrs
>> chilnqrs https://blosy.net/?blosy blosy
>> https://gijnpuxy.com/?gijnpuxy gijnpuxy
>> https://bcemuvwz.ua/?bcemuvwz bcemuvwz
>> http://bdfqwx.net/?bdfqwx bdfqwx http://dfghilr.net/?dfghilr
>> dfghilr http://bdlqstv.com/?bdlqstv bdlqstv
>> http://adhjnrsz.com/?adhjnrsz adhjnrsz
>> http://adiopqx.com/?adiopqx adiopqx
>> http://ehnoqw.info/?ehnoqw ehnoqw https://dgpsx.net/?dgpsx
>> dgpsx http://afgrt.ru/?afgrt afgrt
>> http://bghipuvz.ua/?bghipuvz bghipuvz
>> http://egjmvw.com/?egjmvw egjmvw
>> https://eginoswz.com/?eginoswz eginoswz
>> http://bekuv.info/?bekuv bekuv http://bglno.info/?bglno bglno
>> http://hkoptxz.com/?hkoptxz hkoptxz https://aikqz.biz/?aikqz
>> aikqz https://oqvxy.net/?oqvxy oqvxy http://kruwy.net/?kruwy
>> kruwy http://fhlqty.net/?fhlqty fhlqty
>> http://chpuvyz.ru/?chpuvyz chpuvyz
>> https://aciloqt.ua/?aciloqt aciloqt http://cklsw.info/?cklsw
>> cklsw https://fghkmvy.info/?fghkmvy f
>> ghkmvy http://belmpvz.biz/?belmpvz belmpvz
>> http://eimpxz.ru/?eimpxz eimpxz http://cdjstuz.info/?cdjstuz
>> cdjstuz https://adivy.com/?adivy adivy
>> https://alnrty.ru/?alnrty alnrty https://hkmntz.info/?hkmntz
>> hkmntz https://dkpqr.com/?dkpqr dkpqr https://bfntv.ru/?bfntv
>> bfntv https://inuvwyz.ru/?inuvwyz inuvwyz
>> https://jkmrvyz.ua/?jkmrvyz jkmrvyz
>> http://bfipruw.biz/?bfipruw bfipruw http://cjklos.ua/?cjklos
>> cjklos http://afglru.ru/?afglru afglru http://defrt.ua/?defrt
>> defrt https://afghsvy.ua/?afghsvy afghsvy
>> http://cehiou.info/?cehiou cehiou https://mnrvz.com/?mnrvz
>> mnrvz http://fgtuxz.biz/?fgtuxz fgtuxz
>> http://egiqtuy.ua/?egiqtuy egiqtuy https://dilnv.ru/?dilnv
>> dilnv http://abeny.biz/?abeny abeny http://aijvxz.biz/?aijvxz
>> aijvxz https://abdhrsx.net/?abdhrsx abdhrsx
>> http://bfgmrxy.ru/?bfgmrxy bfgmrxy https://fjkow.info/?fjkow
>> fjkow https://fkruvx.biz/?fkruvx fkruvx
>> http://efhjsw.biz/?efhjsw efhjsw http://djkmops.info/?djkmops
>> djkmops https://cequyz.ru/?cequyz cequyz https://hmswz
>> .com/?hmswz hmswz http://lnotu.info/?lnotu lnotu
>> http://bdjqu.info/?bdjqu bdjqu http://adejrxy.ua/?adejrxy
>> adejrxy http://cdgikmps.ru/?cdgikmps cdgikmps
>> http://dhmostwy.net/?dhmostwy dhmostwy
>> https://cdhlquz.ua/?cdhlquz cdhlquz https://bilnor.ua/?bilnor
>> bilnor https://fnqxz.com/?fnqxz fnqxz
>> https://bijnuwz.com/?bijnuwz bijnuwz
>> http://abcgikwy.ua/?abcgikwy abcgikwy
>> https://begimrv.ua/?begimrv begimrv https://jlprv.net/?jlprv
>> jlprv http://efhsz.ua/?efhsz efhsz https://dgiqs.ua/?dgiqs
>> dgiqs http://bgiprx.net/?bgiprx bgiprx
>> https://cdklmqv.biz/?cdklmqv cdklmqv
>> https://adgnowz.ua/?adgnowz adgnowz
>> http://cfjnorty.ru/?cfjnorty cfjnorty
>> https://bcfhpqvy.ru/?bcfhpqvy bcfhpqvy
>> http://beiqv.biz/?beiqv beiqv https://bjmnu.com/?bjmnu bjmnu
>> https://fgjoquvz.ru/?fgjoquvz fgjoquvz
>> http://fkpwx.info/?fkpwx fkpwx http://dfghty.com/?dfghty
>> dfghty https://dhlmtvxy.biz/?dhlmtvxy dhlmtvxy
>> https://bejuy.com/?bejuy bejuy http://cdikry.com/?cdikry
>> cdikry https://bfhkrty.info/?bfhkrty bfhkrty https:/
>> /cekpst.com/?cekpst <http://cekpst.com/?cekpst> cekpst
>> https://ceknpx.ru/?ceknpx ceknpx https://gjpwy.com/?gjpwy
>> gjpwy https://ceouwxyz.ru/?ceouwxyz ceouwxyz
>> https://ijkopstu.ua/?ijkopstu ijkopstu
>> https://acegjlmo.net/?acegjlmo acegjlmo
>> http://bflnpv.info/?bflnpv bflnpv http://fijkotz.ua/?fijkotz
>> fijkotz http://ajkptwyz.com/?ajkptwyz ajkptwyz
>> http://adjpvw.net/?adjpvw adjpvw https://dpqrsv.biz/?dpqrsv
>> dpqrsv https://acehklps.ua/?acehklps acehklps
>> http://aghsuvyz.biz/?aghsuvyz aghsuvyz
>> https://akotu.ru/?akotu akotu https://dkqrt.biz/?dkqrt dkqrt
>> http://dlrtuxz.info/?dlrtuxz dlrtuxz http://fstvx.ua/?fstvx
>> fstvx http://ejmsv.ua/?ejmsv ejmsv http://abfmyz.com/?abfmyz
>> abfmyz http://cdiqrsvx.info/?cdiqrsvx cdiqrsvx
>> https://fqsuz.info/?fqsuz fqsuz https://cilsu.info/?cilsu
>> cilsu https://bjklnsxz.net/?bjklnsxz bjklnsxz
>> https://demnpst.biz/?demnpst demnpst
>> https://bghikms.biz/?bghikms bghikms
>> http://achjtu.biz/?achjtu achjtu http://npqrwz.net/?npqrwz
>> npqrwz http://adehilpq.net/?adehilpq adehilpq http://bnortwy.
>> com/?bnortwy bnortwy http://cegpsuz.ru/?cegpsuz cegpsuz
>> http://aksyz.ua/?aksyz aksyz http://egkmosux.biz/?egkmosux
>> egkmosux https://dimoruy.com/?dimoruy dimoruy
>> https://ehopyz.net/?ehopyz ehopyz
>> https://ehijptuy.com/?ehijptuy ehijptuy
>> http://jklmprtv.ua/?jklmprtv jklmprtv
>> http://abmnrw.ru/?abmnrw abmnrw http://abcfqu.ru/?abcfqu
>> abcfqu https://degijyz.ru/?degijyz degijyz
>> https://cikortuy.net/?cikortuy cikortuy
>> http://abgnrw.ua/?abgnrw abgnrw http://bfgknpqt.com/?bfgknpqt
>> bfgknpqt https://afmqtv.ru/?afmqtv afmqtv
>> https://bertuvwz.info/?bertuvwz bertuvwz
>> https://eipuvwxy.com/?eipuvwxy eipuvwxy
>> http://ahjory.info/?ahjory ahjory http://acefvx.com/?acefvx
>> acefvx http://acdlo.com/?acdlo acdlo http://cdjqs.biz/?cdjqs
>> cdjqs http://bdexy.net/?bdexy bdexy http://bktxz.info/?bktxz
>> bktxz http://adegmovy.biz/?adegmovy adegmovy
>> http://fkxyz.ua/?fkxyz fkxyz http://bdikny.biz/?bdikny bdikny
>> https://cistv.biz/?cistv cistv https://behknqtz.biz/?behknqtz
>> behknqtz http://efhjquwx.biz/?efhjquwx e
>> fhjquwx https://djmnosz.com/?djmnosz djmnosz
>> http://adino.com/?adino adino http://djlmouv.ua/?djlmouv
>> djlmouv http://dehrvy.biz/?dehrvy dehrvy
>> http://cefijlu.com/?cefijlu cefijlu http://bfgitz.ua/?bfgitz
>> bfgitz http://ilmqsz.ua/?ilmqsz ilmqsz
>> http://aejnrwy.ru/?aejnrwy aejnrwy https://lnuwz.ru/?lnuwz
>> lnuwz http://jlnrv.com/?jlnrv jlnrv https://bjstxz.ru/?bjstxz
>> bjstxz https://fhjnw.com/?fhjnw fhjnw
>> https://ajmnuz.com/?ajmnuz ajmnuz https://ghptxy.net/?ghptxy
>> ghptxy https://aceirsxy.ua/?aceirsxy aceirsxy
>> http://bcemosuw.info/?bcemosuw bcemosuw
>> https://cgklpxy.ua/?cgklpxy cgklpxy
>> https://deghijrs.net/?deghijrs deghijrs
>> http://cgjknvz.ru/?cgjknvz cgjknvz
>> https://bcikmswz.net/?bcikmswz bcikmswz
>> https://cginosuy.com/?cginosuy cginosuy
>> http://bestz.ua/?bestz bestz https://dkmpry.net/?dkmpry
>> dkmpry https://bfmpyz.ru/?bfmpyz bfmpyz
>> https://dfglmp.ru/?dfglmp dfglmp
>> https://cfgmnpru.ua/?cfgmnpru cfgmnpru
>> https://cefhlns.ru/?cefhlns cefhlns
>> http://bcelnosz.ua/?bcelnosz bcelnosz https:/
>> /cehnsy.net/?cehnsy <http://cehnsy.net/?cehnsy> cehnsy
>> https://ipuxyz.info/?ipuxyz ipuxyz
>> https://dfghintv.net/?dfghintv dfghintv
>> https://abdhkuxy.com/?abdhkuxy abdhkuxy
>> https://abrsu.ua/?abrsu abrsu http://fimrstw.ru/?fimrstw
>> fimrstw https://bhkmpvz.ua/?bhkmpvz bhkmpvz
>> http://cefkqrx.info/?cefkqrx cefkqrx
>> http://bdjkstvz.biz/?bdjkstvz bdjkstvz
>> https://abegks.ua/?abegks abegks https://cfhostz.ru/?cfhostz
>> cfhostz http://jnqsv.ua/?jnqsv jnqsv
>> http://abcfjmps.net/?abcfjmps abcfjmps
>> https://jlnptu.com/?jlnptu jlnptu
>> https://bdghklns.ua/?bdghklns bdghklns
>> https://bdikpu.ua/?bdikpu bdikpu http://hklpqs.ru/?hklpqs
>> hklpqs https://bgjmpsy.ua/?bgjmpsy bgjmpsy
>> http://cemnsvz.net/?cemnsvz cemnsvz
>> http://cfhknu.info/?cfhknu cfhknu
>> http://bcjmqsuz.ru/?bcjmqsuz bcjmqsuz
>> http://fghjloqu.com/?fghjloqu fghjloqu
>> https://lmryz.net/?lmryz lmryz http://imvwyz.net/?imvwyz
>> imvwyz http://dhklntw.com/?dhklntw dhklntw
>> http://adijnouy.info/?adijnouy adijnouy
>> https://cdervx.info/?cdervx cdervx
>> https://ajkqrtuw.ru/?ajkqrtuw ajkqrtu
>> w http://diknqtu.biz/?diknqtu diknqtu
>> http://hjnrux.ru/?hjnrux hjnrux https://ilmouxy.info/?ilmouxy
>> ilmouxy http://adfijm.ua/?adfijm adfijm
>> http://efgptx.ru/?efgptx efgptx
>> https://dmprtvwy.com/?dmprtvwy dmprtvwy
>> http://bgksuv.ua/?bgksuv bgksuv https://cfhsv.com/?cfhsv
>> cfhsv http://adgoqr.biz/?adgoqr adgoqr
>> http://efilmx.net/?efilmx efilmx http://eglpqrx.ua/?eglpqrx
>> eglpqrx http://acequxz.com/?acequxz acequxz
>> http://lmsvz.ua/?lmsvz lmsvz http://aefhprtw.com/?aefhprtw
>> aefhprtw https://bglnq.info/?bglnq bglnq
>> http://befhirv.ua/?befhirv befhirv
>> https://achkryz.com/?achkryz achkryz
>> https://bmpsvy.info/?bmpsvy bmpsvy http://ejloqy.net/?ejloqy
>> ejloqy https://biopqz.net/?biopqz biopqz
>> https://bfhklotx.biz/?bfhklotx bfhklotx
>> https://dgjkqwy.ua/?dgjkqwy dgjkqwy
>> https://afnpqrxz.net/?afnpqrxz afnpqrxz
>> https://hjnpqrxz.com/?hjnpqrxz hjnpqrxz
>> https://cimpuyz.net/?cimpuyz cimpuyz http://cruwz.biz/?cruwz
>> cruwz https://bknovz.net/?bknovz bknovz
>> http://dhilrtv.ua/?dhilrtv dhilrtv http://chjp
>> qvyz.info/?chjpqvyz <http://qvyz.info/?chjpqvyz> chjpqvyz
>> https://achijmr.com/?achijmr achijmr
>> https://chknosty.ru/?chknosty chknosty
>> https://acgqv.com/?acgqv acgqv http://defklosy.info/?defklosy
>> defklosy http://kmqrw.com/?kmqrw kmqrw
>> https://npqtvz.ru/?npqtvz npqtvz http://cefkrux.ua/?cefkrux
>> cefkrux https://aefhivx.ua/?aefhivx aefhivx
>> https://dijlrtuy.ua/?dijlrtuy dijlrtuy
>> https://aoqtw.com/?aoqtw aoqtw https://cehisuwz.net/?cehisuwz
>> cehisuwz http://bfghijmr.biz/?bfghijmr bfghijmr
>> http://beimquxy.ua/?beimquxy beimquxy
>> http://dmsuw.info/?dmsuw dmsuw http://imnty.net/?imnty imnty
>> https://detwz.net/?detwz detwz http://glnvx.net/?glnvx glnvx
>> https://himnopw.ru/?himnopw himnopw https://aklnw.com/?aklnw
>> aklnw http://bjnrwx.net/?bjnrwx bjnrwx
>> http://defjlqvy.com/?defjlqvy defjlqvy
>> http://dfimopvz.ua/?dfimopvz dfimopvz
>> http://hmoquv.ru/?hmoquv hmoquv http://afkmq.net/?afkmq afkmq
>> https://blnrwyz.info/?blnrwyz blnrwyz
>> http://fklnrtvx.info/?fklnrtvx fklnrtvx
>> https://fghnruz.biz/?fghnruz fghnruz https://bijqsu.r
>> u/?bijqsu bijqsu http://ghoruxyz.ru/?ghoruxyz ghoruxyz
>> http://acejknry.ru/?acejknry acejknry
>> http://cehquvxy.net/?cehquvxy cehquvxy
>> https://bfgkmoqs.com/?bfgkmoqs bfgkmoqs
>> https://bchjqx.net/?bchjqx bchjqx http://bmoqux.biz/?bmoqux
>> bmoqux https://aijklm.com/?aijklm aijklm
>> https://clmptx.info/?clmptx clmptx
>> https://dghmpqtz.net/?dghmpqtz dghmpqtz
>> https://bfkrt.net/?bfkrt bfkrt http://egkqrtuw.biz/?egkqrtuw
>> egkqrtuw http://hjlstvx.com/?hjlstvx hjlstvx
>> http://jkoprv.com/?jkoprv jkoprv https://chnpstv.com/?chnpstv
>> chnpstv https://eknptuw.ru/?eknptuw eknptuw
>> https://jkmrst.net/?jkmrst jkmrst
>> http://bfmnqrvz.net/?bfmnqrvz bfmnqrvz
>> http://bcdhnrwy.ua/?bcdhnrwy bcdhnrwy
>> https://bcdfgkty.ru/?bcdfgkty bcdfgkty
>> http://cmpqv.info/?cmpqv cmpqv https://dhilsz.ua/?dhilsz
>> dhilsz https://acekpsy.ru/?acekpsy acekpsy
>> http://gmnpswx.biz/?gmnpswx gmnpswx https://cdinpr.ua/?cdinpr
>> cdinpr http://cdhjnorz.info/?cdhjnorz cdhjnorz
>> https://behjk.com/?behjk behjk https://lmpstv.com/?lmpstv
>> lmpstv https
>> ://ilmory.ua/?ilmory <http://ilmory.ua/?ilmory> ilmory
>> https://abiortz.ua/?abiortz abiortz http://bceotz.biz/?bceotz
>> bceotz https://ghjlqt.info/?ghjlqt ghjlqt
>> https://hmosyz.ua/?hmosyz hmosyz
>> https://behmoqru.net/?behmoqru behmoqru
>> https://chinpx.info/?chinpx chinpx
>> https://fkntuvyz.info/?fkntuvyz fkntuvyz
>> http://cfghimtw.ua/?cfghimtw cfghimtw
>> https://fqstwz.com/?fqstwz fqstwz http://gimvw.biz/?gimvw
>> gimvw https://degixy.ua/?degixy degixy
>> http://fnvwy.com/?fnvwy fnvwy https://fikmstyz.ru/?fikmstyz
>> fikmstyz http://chmopuwy.info/?chmopuwy chmopuwy
>> http://cdfovy.ua/?cdfovy cdfovy http://acdfhjkr.ua/?acdfhjkr
>> acdfhjkr https://bcfktw.biz/?bcfktw bcfktw
>> https://fkmoqux.biz/?fkmoqux fkmoqux
>> http://adghjox.ru/?adghjox adghjox
>> https://dlnortv.info/?dlnortv dlnortv
>> http://ijlpsuw.ru/?ijlpsuw ijlpsuw
>> https://cgijqruw.info/?cgijqruw cgijqruw
>> https://eisxy.ru/?eisxy eisxy http://dhjkmqvw.net/?dhjkmqvw
>> dhjkmqvw https://bfgklnu.info/?bfgklnu bfgklnu
>> http://bcfil.info/?bcfil bcfil https://degitv.com/?degitv
>> degitv ht
>> tps://ghjlmr.net/?ghjlmr <http://ghjlmr.net/?ghjlmr> ghjlmr
>> https://ceilv.ru/?ceilv ceilv http://gjknrtw.ua/?gjknrtw
>> gjknrtw http://fotvwyz.net/?fotvwyz fotvwyz
>> http://dgklquv.ua/?dgklquv dgklquv
>> http://cghijnv.info/?cghijnv cghijnv
>> https://aelmoy.com/?aelmoy aelmoy
>> http://begilmnx.com/?begilmnx begilmnx
>> http://bcegrtxz.ua/?bcegrtxz bcegrtxz
>> https://bhkqs.com/?bhkqs bhkqs https://cefgpstu.ua/?cefgpstu
>> cefgpstu http://gmntv.com/?gmntv gmntv
>> http://afjnstuy.ua/?afjnstuy afjnstuy
>> https://aegqwy.biz/?aegqwy aegqwy http://ioswz.biz/?ioswz
>> ioswz https://gorvw.info/?gorvw gorvw
>> http://cgnouwy.ua/?cgnouwy cgnouwy
>> http://bchkpvy.info/?bchkpvy bchkpvy http://egijl.ua/?egijl
>> egijl https://gorstuxz.net/?gorstuxz gorstuxz
>> https://cdhjnopu.biz/?cdhjnopu cdhjnopu
>> http://bceijoy.ru/?bceijoy bceijoy
>> https://abfgjqw.ua/?abfgjqw abfgjqw http://bdeltw.net/?bdeltw
>> bdeltw http://jktwz.net/?jktwz jktwz
>> https://bgikloqy.info/?bgikloqy bgikloqy
>> https://eimqrsuw.biz/?eimqrsuw eimqrsuw
>> http://cfgkpu.net/?cfgkpu cfgkpu http://efm
>> qrtv.com/?efmqrtv <http://qrtv.com/?efmqrtv> efmqrtv
>> http://cegikmru.info/?cegikmru cegikmru
>> http://hiprsv.ua/?hiprsv hiprsv https://efiorw.com/?efiorw
>> efiorw https://ehkpy.ru/?ehkpy ehkpy
>> http://acdjps.biz/?acdjps acdjps
>> http://lmnopvxy.net/?lmnopvxy lmnopvxy
>> http://abeptuy.net/?abeptuy abeptuy http://fimnoq.ua/?fimnoq
>> fimnoq http://adefky.com/?adefky adefky
>> https://cdfijlrz.ru/?cdfijlrz cdfijlrz
>> https://dimnv.ru/?dimnv dimnv http://bcehz.com/?bcehz bcehz
>> http://ahkpruvw.ru/?ahkpruvw ahkpruvw
>> https://afnrw.com/?afnrw afnrw https://bclnpqtv.biz/?bclnpqtv
>> bclnpqtv https://hmptuy.ua/?hmptuy hmptuy
>> https://adfkx.com/?adfkx adfkx https://cdfgikp.com/?cdfgikp
>> cdfgikp https://hjovwxz.net/?hjovwxz hjovwxz
>> http://enoprsxz.ru/?enoprsxz enoprsxz
>> https://dmryz.info/?dmryz dmryz http://ijopuwx.info/?ijopuwx
>> ijopuwx https://dghoryz.ua/?dghoryz dghoryz
>> https://gnpqsvy.biz/?gnpqsvy gnpqsvy
>> https://jlmtwxy.ua/?jlmtwxy jlmtwxy
>> http://clmpuvz.com/?clmpuvz clmpuvz https://gprtvx.ua/?gprtvx
>> gprtvx http://bklptuxz.net/?bk
>> lptuxz bklptuxz https://bfknrvz.com/?bfknrvz bfknrvz
>> http://dgkqrv.ua/?dgkqrv dgkqrv
>> https://adkprstv.net/?adkprstv adkprstv
>> https://afiqx.com/?afiqx afiqx https://bchiknpt.com/?bchiknpt
>> bchiknpt http://hjklprx.biz/?hjklprx hjklprx
>> http://bejoruw.net/?bejoruw bejoruw
>> http://cegmnvz.biz/?cegmnvz cegmnvz
>> http://gmnotyz.ua/?gmnotyz gmnotyz
>> https://dfhikntw.net/?dfhikntw dfhikntw
>> https://dfouv.biz/?dfouv dfouv https://cjlnotz.info/?cjlnotz
>> cjlnotz https://denqtvwz.ua/?denqtvwz denqtvwz
>> http://behlrwy.com/?behlrwy behlrwy
>> http://drsuvxz.biz/?drsuvxz drsuvxz
>> https://esuwyz.biz/?esuwyz esuwyz http://fhjntu.biz/?fhjntu
>> fhjntu https://gqrswyz.biz/?gqrswyz gqrswyz
>> https://mpswxz.biz/?mpswxz mpswxz http://dhjpsuv.net/?dhjpsuv
>> dhjpsuv http://dfopruy.ru/?dfopruy dfopruy
>> https://ehkloqsz.info/?ehkloqsz ehkloqsz
>> https://adgjqru.biz/?adgjqru adgjqru
>> https://ejmtvwz.biz/?ejmtvwz ejmtvwz
>> http://fgoquw.net/?fgoquw fgoquw https://fhikqry.com/?fhikqry
>> fhikqry https://cemqy.com/?cemqy cemqy http:
>> //otuxz.com/?otuxz <http://otuxz.com/?otuxz> otuxz
>> http://fijlmnoq.info/?fijlmnoq fijlmnoq
>> http://cgiouw.ru/?cgiouw cgiouw
>> https://cdgijlnw.biz/?cdgijlnw cdgijlnw
>> https://gmuvw.biz/?gmuvw gmuvw
>> https://abdefgiu.info/?abdefgiu abdefgiu
>> https://gkmqwy.info/?gkmqwy gkmqwy
>> http://bfgkqstw.com/?bfgkqstw bfgkqstw
>> https://bfgmnovx.net/?bfgmnovx bfgmnovx
>> https://bkmnrsy.com/?bkmnrsy bkmnrsy http://chiuwx.ua/?chiuwx
>> chiuwx http://chlvw.ua/?chlvw chlvw
>> https://acfgilp.ru/?acfgilp acfgilp http://bghosv.com/?bghosv
>> bghosv https://befgkpst.net/?befgkpst befgkpst
>> http://jklmnwz.net/?jklmnwz jklmnwz https://dktxz.com/?dktxz
>> dktxz http://aeknuwyz.ru/?aeknuwyz aeknuwyz
>> https://aqtuv.ua/?aqtuv aqtuv http://bfjorw.info/?bfjorw
>> bfjorw http://cfijuz.biz/?cfijuz cfijuz
>> https://efjlnuv.net/?efjlnuv efjlnuv
>> https://hkruvy.net/?hkruvy hkruvy
>> http://defnswxy.biz/?defnswxy defnswxy
>> https://fgjmqxy.biz/?fgjmqxy fgjmqxy
>> https://deflmtu.ru/?deflmtu deflmtu https://cgmnr.info/?cgmnr
>> cgmnr https://dgilnsvy.ua/?dgilnsvy dgilnsvy htt
>> ps://chjmosxy.biz/?chjmosxy <http://chjmosxy.biz/?chjmosxy>
>> chjmosxy https://abcdhln.net/?abcdhln abcdhln
>> https://elstuyz.biz/?elstuyz elstuyz
>> https://bjoptw.com/?bjoptw bjoptw https://bcdgquv.ru/?bcdgquv
>> bcdgquv http://afiklst.com/?afiklst afiklst
>> https://agnvwz.info/?agnvwz agnvwz
>> http://bcfgkrvx.biz/?bcfgkrvx bcfgkrvx
>> https://bdjmnuz.biz/?bdjmnuz bdjmnuz
>> https://emqrwz.com/?emqrwz emqrwz https://egklqt.biz/?egklqt
>> egklqt http://bimqr.com/?bimqr bimqr
>> https://dhklnsv.net/?dhklnsv dhklnsv https://dvwxz.com/?dvwxz
>> dvwxz https://dfghimu.com/?dfghimu dfghimu
>> https://fostx.ru/?fostx fostx https://fjklnqux.ua/?fjklnqux
>> fjklnqux https://cfhijnqu.info/?cfhijnqu cfhijnqu
>> http://nptvy.ua/?nptvy nptvy http://bclnu.com/?bclnu bclnu
>> http://eflntvyz.ru/?eflntvyz eflntvyz
>> https://abcdpsx.ru/?abcdpsx abcdpsx
>> https://cfipqx.info/?cfipqx cfipqx
>> http://adforst.biz/?adforst adforst
>> https://bfgmpqtv.biz/?bfgmpqtv bfgmpqtv
>> http://cfkmnorv.ua/?cfkmnorv cfkmnorv
>> http://dhjkuv.info/?dhjkuv dhjkuv
>> https://bcejlsyz.info/?bcejlsyz
>> bcejlsyz https://efinrsy.ua/?efinrsy efinrsy
>> https://kmosw.net/?kmosw kmosw http://jmoxy.net/?jmoxy jmoxy
>> http://agjloqy.biz/?agjloqy agjloqy
>> https://dglmnpqy.com/?dglmnpqy dglmnpqy
>> https://dijnqrsw.ua/?dijnqrsw dijnqrsw
>> http://ijmnr.biz/?ijmnr ijmnr https://gjouwxy.ru/?gjouwxy
>> gjouwxy https://klpuz.biz/?klpuz klpuz
>> http://hijoux.net/?hijoux hijoux http://bikmn.net/?bikmn
>> bikmn http://abcovwy.ua/?abcovwy abcovwy
>> https://adfgioqx.ua/?adfgioqx adfgioqx
>> http://beijknpq.info/?beijknpq beijknpq
>> https://equvx.com/?equvx equvx https://cgmpr.net/?cgmpr cgmpr
>> http://dfknor.com/?dfknor dfknor https://gopsvyz.ru/?gopsvyz
>> gopsvyz http://chijkqsu.net/?chijkqsu chijkqsu
>> https://bfmtx.biz/?bfmtx bfmtx http://cgijqrux.ua/?cgijqrux
>> cgijqrux https://fklnovy.biz/?fklnovy fklnovy
>> http://chkmosux.net/?chkmosux chkmosux
>> https://cenprvw.info/?cenprvw cenprvw
>> https://cfuxyz.ua/?cfuxyz cfuxyz https://bdgopy.ua/?bdgopy
>> bdgopy https://ampwx.info/?ampwx ampwx
>> http://cefmoqtx.info/?cefmoqtx cefmoqtx htt
>> ps://bcdflny.ua/?bcdflny <http://bcdflny.ua/?bcdflny>
>> bcdflny https://abqtux.ua/?abqtux abqtux
>> https://bpstw.com/?bpstw bpstw http://cegmoqry.info/?cegmoqry
>> cegmoqry http://aeghjlw.net/?aeghjlw aeghjlw
>> https://egjswz.ru/?egjswz egjswz https://agiluv.info/?agiluv
>> agiluv https://befimsu.biz/?befimsu befimsu
>> https://abcdeiry.info/?abcdeiry abcdeiry
>> http://bcqrxz.info/?bcqrxz bcqrxz
>> https://eilntvxz.net/?eilntvxz eilntvxz
>> https://abcjpt.ua/?abcjpt abcjpt https://adglox.ru/?adglox
>> adglox https://adjnptw.ru/?adjnptw adjnptw
>> http://aglrxz.biz/?aglrxz aglrxz https://abeqru.info/?abeqru
>> abeqru https://cnoprsw.biz/?cnoprsw cnoprsw
>> http://akoqx.com/?akoqx akoqx https://ijlmnptz.net/?ijlmnptz
>> ijlmnptz https://ghimnuyz.com/?ghimnuyz ghimnuyz
>> https://ghprs.ua/?ghprs ghprs https://lmntwxz.biz/?lmntwxz
>> lmntwxz https://blopqxz.ua/?blopqxz blopqxz
>> https://cqrxz.ua/?cqrxz cqrxz http://befmvwz.net/?befmvwz
>> befmvwz https://abjlmnpr.com/?abjlmnpr abjlmnpr
>> https://filotz.net/?filotz filotz http://hinsw.biz/?hinsw
>> hinsw http:/
>> /abfjklsy.net/?abfjklsy <http://abfjklsy.net/?abfjklsy>
>> abfjklsy https://bhimnrwx.biz/?bhimnrwx bhimnrwx
>> http://dejnotz.ru/?dejnotz dejnotz
>> https://bcflsxz.info/?bcflsxz bcflsxz
>> http://hklmsux.net/?hklmsux hklmsux
>> https://ahknouz.ru/?ahknouz ahknouz https://cfknxy.ru/?cfknxy
>> cfknxy http://acfntvx.net/?acfntvx acfntvx
>> https://cdfksuvy.info/?cdfksuvy cdfksuvy
>> https://abjkorx.ru/?abjkorx abjkorx
>> https://afiklqvw.com/?afiklqvw afiklqvw
>> http://adnovx.biz/?adnovx adnovx
>> https://fglstyz.info/?fglstyz fglstyz
>> https://ghikruy.biz/?ghikruy ghikruy
>> http://ghnopsvz.biz/?ghnopsvz ghnopsvz
>> http://abcgjnrw.com/?abcgjnrw abcgjnrw
>> https://bijlnyz.ua/?bijlnyz bijlnyz http://ahiqrv.ru/?ahiqrv
>> ahiqrv https://ajotw.biz/?ajotw ajotw
>> http://bfhipuw.info/?bfhipuw bfhipuw
>> http://acjmqry.ua/?acjmqry acjmqry
>> http://efjnoqrz.info/?efjnoqrz efjnoqrz
>> https://achkqst.info/?achkqst achkqst
>> http://bcfpruyz.ua/?bcfpruyz bcfpruyz http://bcelv.com/?bcelv
>> bcelv https://dfkoqsu.ua/?dfkoqsu dfkoqsu
>> http://ekopq.ru/?ekopq ekopq https://abfkrsz.u
>> a/?abfkrsz abfkrsz https://abenxy.net/?abenxy abenxy
>> http://agiotu.biz/?agiotu agiotu https://bkpqr.info/?bkpqr
>> bkpqr http://ahijq.ua/?ahijq ahijq http://eimps.ru/?eimps
>> eimps https://abdstwz.net/?abdstwz abdstwz
>> https://cdhjlu.biz/?cdhjlu cdhjlu
>> http://gmrstyz.info/?gmrstyz gmrstyz
>> https://djsvwyz.ua/?djsvwyz djsvwyz
>> http://begjmorv.net/?begjmorv begjmorv
>> http://ahlmoptz.biz/?ahlmoptz ahlmoptz
>> http://dekoqx.ru/?dekoqx dekoqx http://fiprs.net/?fiprs fiprs
>> http://cjklmr.biz/?cjklmr cjklmr
>> https://aefgpquv.biz/?aefgpquv aefgpquv
>> https://jlmopswx.net/?jlmopswx jlmopswx
>> https://bfhjlsw.biz/?bfhjlsw bfhjlsw
>> https://iknortux.com/?iknortux iknortux
>> http://abhkoprv.biz/?abhkoprv abhkoprv
>> https://cjnrwyz.ua/?cjnrwyz cjnrwyz
>> http://djmnrvwz.info/?djmnrvwz djmnrvwz
>> http://adgkrtyz.info/?adgkrtyz adgkrtyz
>> https://bdhjsuv.ua/?bdhjsuv bdhjsuv
>> http://acfgjor.biz/?acfgjor acfgjor
>> http://cfilrtw.info/?cfilrtw cfilrtw https://fhijz.com/?fhijz
>> fhijz http://hkmntxy.ru/?hkmntxy hkmntxy http://fh
>> ilsuy.ua/?fhilsuy <http://ilsuy.ua/?fhilsuy> fhilsuy
>> http://jmnpwx.ru/?jmnpwx jmnpwx http://gikltvwy.ru/?gikltvwy
>> gikltvwy http://jopqy.biz/?jopqy jopqy
>> http://bdlqry.info/?bdlqry bdlqry https://ejlvwz.com/?ejlvwz
>> ejlvwz http://ceijvz.net/?ceijvz ceijvz
>> http://cfijntyz.info/?cfijntyz cfijntyz
>> http://efilotuv.com/?efilotuv efilotuv
>> http://cfmpyz.com/?cfmpyz cfmpyz http://dhpqz.com/?dhpqz
>> dhpqz http://dlpxz.com/?dlpxz dlpxz
>> http://aefjlyz.net/?aefjlyz aefjlyz
>> https://ceijorz.info/?ceijorz ceijorz
>> http://dkmnuvx.info/?dkmnuvx dkmnuvx
>> https://kprswx.net/?kprswx kprswx https://dgjpwz.ru/?dgjpwz
>> dgjpwz https://abfjlnt.ru/?abfjlnt abfjlnt
>> http://efgips.com/?efgips efgips http://cehnpu.ru/?cehnpu
>> cehnpu https://fstuw.net/?fstuw fstuw http://dmorz.net/?dmorz
>> dmorz https://celmrwz.info/?celmrwz celmrwz
>> https://jprvx.com/?jprvx jprvx https://cefjkxz.biz/?cefjkxz
>> cefjkxz http://behjlv.biz/?behjlv behjlv
>> http://bdiku.net/?bdiku bdiku https://ghnpxz.ru/?ghnpxz
>> ghnpxz https://bcpqvwz.ua/?bcpqvwz bcpqvwz https://gijl
>> nqrs.biz/?gijlnqrs <http://nqrs.biz/?gijlnqrs> gijlnqrs
>> http://adfjlrsz.info/?adfjlrsz adfjlrsz
>> https://afiptvz.biz/?afiptvz afiptvz
>> http://acikors.com/?acikors acikors https://dfmpq.ru/?dfmpq
>> dfmpq http://abhjmsyz.ru/?abhjmsyz abhjmsyz
>> https://dejkq.com/?dejkq dejkq http://abcltx.com/?abcltx
>> abcltx https://bdfjopu.net/?bdfjopu bdfjopu
>> http://bipvy.com/?bipvy bipvy http://dlqsx.biz/?dlqsx dlqsx
>> http://inqrstv.info/?inqrstv inqrstv https://dknwz.ru/?dknwz
>> dknwz http://cdgimqsu.ru/?cdgimqsu cdgimqsu
>> https://akmotuv.info/?akmotuv akmotuv
>> http://kmntvyz.ru/?kmntvyz kmntvyz https://bimxz.net/?bimxz
>> bimxz http://afjoqyz.ru/?afjoqyz afjoqyz
>> https://eikuwy.ua/?eikuwy eikuwy https://bmptw.biz/?bmptw
>> bmptw http://fgltwx.com/?fgltwx fgltwx
>> http://chlnpqrs.com/?chlnpqrs chlnpqrs
>> https://abhux.net/?abhux abhux http://adfhmw.info/?adfhmw
>> adfhmw http://bgilt.com/?bgilt bgilt
>> https://cefotu.biz/?cefotu cefotu
>> https://adfruvwy.biz/?adfruvwy adfruvwy
>> https://fgoqstu.info/?fgoqstu fgoqstu
>> https://cdilnqvy.info/?cdilnqvy
>> cdilnqvy https://adghruw.ua/?adghruw adghruw
>> https://ehlnrsuy.biz/?ehlnrsuy ehlnrsuy
>> http://abfijlnr.info/?abfijlnr abfijlnr
>> https://jkpty.biz/?jkpty jkpty https://cdlpv.biz/?cdlpv cdlpv
>> https://ginoxy.ua/?ginoxy ginoxy
>> https://ciknpquy.net/?ciknpquy ciknpquy
>> https://egijstw.biz/?egijstw egijstw
>> http://cdikopvz.info/?cdikopvz cdikopvz
>> https://egjklnvy.info/?egjklnvy egjklnvy
>> https://fjkmvw.info/?fjkmvw fjkmvw http://dfkmv.com/?dfkmv
>> dfkmv https://efgloptu.ru/?efgloptu efgloptu
>> https://fgotz.ua/?fgotz fgotz http://efhklv.info/?efhklv
>> efhklv https://befmrwy.info/?befmrwy befmrwy
>> https://bklnsvy.biz/?bklnsvy bklnsvy http://flmoz.ru/?flmoz
>> flmoz http://aiopqrtu.biz/?aiopqrtu aiopqrtu
>> https://fjrsty.info/?fjrsty fjrsty
>> http://behimuwy.ru/?behimuwy behimuwy
>> https://iknqvz.com/?iknqvz iknqvz http://cdemp.ru/?cdemp
>> cdemp http://eglpqsvz.net/?eglpqsvz eglpqsvz
>> https://dluvz.net/?dluvz dluvz http://beghsuy.net/?beghsuy
>> beghsuy http://ekmqsvz.net/?ekmqsvz ekmqsvz
>> http://ehinz.net/?ehin
>> z ehinz http://gipvz.com/?gipvz gipvz
>> http://efhlwxyz.biz/?efhlwxyz efhlwxyz http://blors.ru/?blors
>> blors http://dnqry.info/?dnqry dnqry
>> https://cghnrux.biz/?cghnrux cghnrux
>> http://dfinqtwx.ru/?dfinqtwx dfinqtwx
>> http://efotxz.info/?efotxz efotxz
>> http://aceglpqu.net/?aceglpqu aceglpqu
>> https://abilr.ua/?abilr abilr http://bcgqw.ru/?bcgqw bcgqw
>> http://cdinqv.biz/?cdinqv cdinqv https://cdfkp.com/?cdfkp
>> cdfkp https://aelouvz.ua/?aelouvz aelouvz
>> http://dklstuz.net/?dklstuz dklstuz https://cejqw.ru/?cejqw
>> cejqw https://bdgkuy.com/?bdgkuy bdgkuy
>> https://hkoprvxy.ru/?hkoprvxy hkoprvxy
>> https://filntx.net/?filntx filntx http://cfgsty.ua/?cfgsty
>> cfgsty https://bfgptx.net/?bfgptx bfgptx
>> http://belpsu.biz/?belpsu belpsu http://deilmoy.biz/?deilmoy
>> deilmoy https://kqruv.info/?kqruv kqruv
>> https://acdst.net/?acdst acdst http://glmvy.ru/?glmvy glmvy
>> https://abcmnu.net/?abcmnu abcmnu
>> http://bfil
>> s.ua/?bfils <http://s.ua/?bfils> bfils
>> http://abcmnvw.biz/?abcmnvw abcmnvw
>> fnpqry https://aklstwx.ru/?aklstwx aklstwx http
>> ://bjloq.com/?bjloq <http://bjloq.com/?bjloq> bjloq
>> http://dkmsuv.info/?dkmsuv dkmsuv
>> https://ejkmq.ua/?ejkmq ejkmq https://bgqvx.info/?bgqvx bgqvx
>> https://dqrsuvw.com/?dqrsuvw dqrsuvw http://bcekrsu.net/?bcekr
>> su bcekrsu https://dlmqwy.com/?dlmqwy dlmqwy
>> http://abhnsvz.ru/?abhnsvz abhnsvz
>> https://bfgnprwy.net/?bfgnprwy bfgnprwy
>> http://gilopqwy.ua/?gilopqwy gilopqwy https://fjopry.ru/?fjopry
>> fjopry http://kmrvwy.biz/?kmrvwy kmrvwy
>> https://bflmnoq.info/?bflmnoq bflmnoq
>> com/?ajoruvz ajoruvz http://cotxz.ru/?cotxz cotxz
>> https://deintwx.net/?deintwx deintwx
>> http://aefhty.info/?aefhty aefhty
>> jkpx bdjkpx http://aciknovw.net/?aciknovw aciknovw
>> https://acfhmqtz.info/?acfhmqtz acfhmqtz
>> https://ejmnpt.biz/?ejmnpt ejmnpt http://dfgnrtu.ru/?dfgnrtu
>> dfgnrtu https://diknswx.biz/?diknswx
>> diknswx https://hjnsz.info/?hjnsz hjnsz
>> https://cdjlq.ua/?cdjlq cdjlq https://iowxy.ru/?iowxy iowxy
>> https://fhjltux.net/?fhjltux fhjltux http://ablmv.com/?ablmv
>> ablmv http://bdiorswz.ru/?bdiorswz bdiorswz
>> http://cnopr.ru/?cnopr cnopr http://adgopz.ru/?adgopz adgopz
>> https://bfhsvyz.ru/?bfhsvyz bfhsvyz http://eqsuv.ua/?eqsuv
>> eqsuv http://ghinqsx.biz/?ghinqsx ghinqsx https://acgkmnpu.c
>> om/?acgkmnpu acgkmnpu http://elrty.ru/?elrty elrty
>> https://cdgkoz.net/?cdgkoz cdgkoz
>> ghnuvy http://aeiky.com/?aeiky aeiky
>> https://cjlnpqru.biz/?cjlnpqru cjlnpqru https:
>> //cgjqtv.biz/?cgjqtv <http://cgjqtv.biz/?cgjqtv> cgjqtv
>> http://cfgnsvx.biz/?cfgnsvx cfgnsvx http://abdjsw.ru/?abdjsw
>> abdjsw https://abelrvx.biz/?abelrvx abelrvx
>> y http://hmnqz.net/?hmnqz hmnqz https://dhkntv.ru/?dhkntv
>> dhkntv http://bgqsyz.biz/?bgqsyz bgqsyz
>> ://acfglopu.ru/?acfglopu <http://acfglopu.ru/?acfglopu>
>> http://afglw.info/?afglw afglw https://bcjqrvw.net/?bcjqrvw
>> bcjqrvw https://hiotz.ru/?hiotz hiotz
>> https://abefmswx.biz/?abefmswx abefmswx ht
>> tp://acgkopyz.ua/?acgkopyz <http://acgkopyz.ua/?acgkopyz>
>> acgkopyz https://fijln.com/?fijln fijln
>> http://befmquwz.info/?befmquwz befmquwz
>> https://hijory.ua/?hijory hijory http://cdfhr.info/?cdfhr
>> cdfhr https://ahiksx.ua/?ahiksx ahiksx
>> https://aghmxy.ru/?aghmxy aghmxy https://hnopqt.net/?hnopqt
>> hnopqt https://fiklnrsw.ru/?fiklnrsw fiklnrsw
>> http://hknpv.ru/?hknpv hknpv https://abdfmotw.net/?abdfmotw
>> abdfmotw http://bcfhpvx.biz/?bcfhpvx bcfhpvx
>> http://grtuz.ru/?grtuz grtuz https://cgiqw.info/?cgiqw cgiqw
>> tu deglqtu http://ilpqrtuw.com/?ilpqrtuw ilpqrtuw
>> http://fhjksuvz.com/?fhjksuvz fhjksuvz
>> http://bijmy.com/?bijmy bijmy https://adhjw.com/?adhjw adhjw
>> nprwyz emnprwyz http://dgmnw.ru/?dgmnw dgmnw
>> https://cdgimruv.com/?cdgimruv cdgimruv
>> http://bcdjqst.biz/?bcdjqst bcdjqst https://lmquv.ru/?lmquv
>> lmquv http://degiptv.info/?degiptv degiptv
>> http://hlnvy.ru/?hlnvy hlnvy http://gklmvx.info/?gklmvx
>> gklmvx http://behlpstz.com/?behlpstz behlpstz
>> lnopux https://iknqstux.ua/?iknqstux iknqstux
>> abflsv http://c
>> ghkmtvz.info/?cghkmtvz <http://ghkmtvz.info/?cghkmtvz>
>> cghkmtvz http://flpqrxz.biz/?flpqrxz flpqrxz
>> https://cfgnvz.ua/?cfgnvz cfgnvz https://jtuvx.com/?jtuvx
>> jtuvx https://fgikl.ru/?fgikl fgikl http://ehikrs.ru/?ehikrs
>> ehikrs http://beghqx.ru/?beghqx beghqx
>> http://dhijlrsw.com/?dhijlrsw dhijlrsw http://elqst.ru/?elqst
>> elqst https://abfklmns.biz/?abfklmns abfklmns
>> bcdnqvx http://defjnqvw.com/?defjnqvw defjnqvw
>> http://cijpqsxz.biz/?cijpqsxz cijpqsxz http://dopsty
>> z.ua/?dopstyz <http://z.ua/?dopstyz> dopstyz
>> http://cinow.com/?cinow cinow http://cdejmrs.info/?cdejmrs
>> cdejmrs http://fgknprwz.info/?fgknprwz fgknprwz
>> https://aknqrtuz.ru/?aknqrtuz aknqrtuz
>> https://defikv.info/?defikv defikv http://abcoqtz.c
>> om/?abcoqtz abcoqtz https://dfirxz.net/?dfirxz dfirxz
>> http://efgnrsux.net/?efgnrsux efgnrsux
>> http://adflovz.info/?adflovz adflovz http://acopu.ua/?acopu
>> acopu https://chi
>> lnqrs.ru/?chilnqrs <http://lnqrs.ru/?chilnqrs> chilnqrs
>> https://blosy.net/?blosy blosy https://gijnpuxy.com/?gijnpuxy
>> gijnpuxy https://bcemuvwz.ua/?bcemuvwz bcemuvwz
>> cklsw https://fghkmvy.info/?fghkmvy fghkmvy
>> http://belmpvz.biz/?belmpvz belmpvz http://eimpxz.ru/?eimpxz
>> eimpxz http://cdjstuz.info/?cdjstuz cdjstu
>> z https://adivy.com/?adivy adivy https://alnrty.ru/?alnrty
>> alnrty https://hkmntz.info/?hkmntz hkmntz
>> https://dkpqr.com/?dkpqr dkpqr https://bfntv.ru/?bfntv bfntv
>> https://hmswz.com/?hmswz hmswz http://lnotu.info/?lnotu lnotu
>> http://bdjqu.info/?bdjqu bdjqu http://adejrxy.ua/?adejrxy ade
>> https://cekpst.com/?cekpst cekpst https://ceknpx.ru/?ceknpx
>> ceknpx https://gjpwy.com/?gjpwy gjpwy https://ceouwxyz.ru
>> /?ceouwxyz ceouwxyz https://ijkopstu.ua/?ijkopstu ijkopstu
>> http://bnortwy.com/?bnortwy bnortwy
>> http://cegpsuz.ru/?cegpsuz cegpsuz http://aksyz.ua/?aksyz
>> osux egkmosux https://dimoruy.com/?dimoruy dimoruy
>> http://fkxyz.ua/?fkxyz fkxyz http://adehinxy.ru/?adehinxy
>> adehinxy http://ahmnwy.biz/?ahmnwy ahmnwy
>> http://morst.ru/?morst morst http://bfils.ua/?bfils bfils
>> http://fhikpqvy.net/?fhikpqvy fhikpqvy h
>> ttps://bejkqu.info/?bejkqu <http://bejkqu.info/?bejkqu>
>> bejkqu https://cdehnsxy.ru/?cdehnsxy cdehnsxy
>> abhnsvz https://bdfhjoqr.info/?bdfhjoqr bdfhjoqr http://ceijlp
>> rw.net/?ceijlprw <http://rw.net/?ceijlprw> ceijlprw
>> http://cdhnsvwx.com/?cdhnsvwx cdhnsvwx http://ahmqv.com/?
>> deintwx https://eghijkuy.com/?eghijkuy eghijkuy http://
>> dginwx.ua/?dginwx <http://dginwx.ua/?dginwx> dginwx
>> http://aenoxy.net/?aenoxy aenoxy
>> https://ajnpvxyz.ua/?ajnpvxyz ajnpvxyz http://fijq
>> rv.com/?fijqrv <http://rv.com/?fijqrv> fijqrv
>> dfgnrtu https://diknswx.biz/?diknswx diknswx
>> https://iowxy.ru/?iowxy iowxy https://fhjltux.net/?fhjltux fhjlt
>> cdgkoz http://dimnosw.info/?dimnosw dimnosw http://abegn
>> wx.biz/?abegnwx <http://wx.biz/?abegnwx> abegnwx
>> bcmstuvy https://bhjknsuz.net/?bhjknsuz bhjknsuz
>> ux https://acehlrsv.info/?acehlrsv acehlrsv
>> muw http://abhioqvw.ua/?abhioqvw abhioqvw
>> ijory http://cdfhr.info/?cdfhr cdfhr
>> https://ahiksx.ua/?ahiksx ahiksx https://aghmxy.ru/?aghmxy
>> aghmxy https://hnopqt.net/?hnopqt hnopqt
>> https://hijkmsu.ru/?hijkmsu hijkmsu http://cist
>> xyz.biz/?cistxyz <http://xyz.biz/?cistxyz> cistxyz
>> cdgimruv http://bcdjqst.biz/?bcdjqst bcdjqst https://lmquv
>> .ru/?lmquv lmquv http://degiptv.info/?degiptv degiptv
>> tps://fgikl.ru/?fgikl <http://fgikl.ru/?fgikl> fgikl
>> http://ehikrs.ru/?ehikrs ehikrs http://beghqx.ru/?beghqx
>> beghqx http://dhijlrsw.com/?dhijlrsw dhijlrsw
>> http://elqst.ru/?elqst elqst https://abfklmns.biz/?abfklmns
>> abfklmns https://cilnorw.ua/?cilnorw cilnorw
>> https://anoqu.ua/?anoqu anoqu http://adikquz.com/?adikquz
>> adikquz http://abcpwyz.ua/?abcpwyz abcpwyz
>> https://fiqwxz.ru/?fiqwxz fiqwxz http://bcivw.ru/?bcivw bcivw
>> http://fgknprwz.info/?fgknprwz fgknprwz https
>> ://binpquxy.com/?binpquxy <http://binpquxy.com/?binpquxy>
>> binpquxy https://afhqrtu.biz/?afhqrtu afhqrtu
>> http://cemqtv.ru/?cemqtv cemqtv http://bgnqsz.info/?bgnqsz
>> bgnqsz http://cdfjprsv.ua/?cdfjprsv cdfjprsv
>> hl.ua/?bdfhl <http://hl.ua/?bdfhl> bdfhl
>> acopu https://chilnqrs.ru/?chilnqrs chilnqrs
>> vwz http://bdfqwx.net/?bdfqwx bdfqwx
>> http://dfghilr.net/?dfghilr dfghilr
>> eimpxz http://cdjstuz.info/?cdjstuz cdjstuz
>> tps://bfntv.ru/?bfntv <http://bfntv.ru/?bfntv> bfntv
>> a/?bilnor bilnor https://fnqxz.com/?fnqxz fnqxz
>> ttp://fijkotz.ua/?fijkotz <http://fijkotz.ua/?fijkotz>
>> aksyz http://egkmosux.biz/?egkmosux egkmosux
>> https://ehijptuy.com/?ehijptuy ehijptuy http://jk
>> lmprtv.ua/?jklmprtv <http://lmprtv.ua/?jklmprtv> jklmprtv
>> behknqtz http://efhjquwx.biz/?efhjquwx efhjquwx
>> https://djmnosz.com/?djmnosz djmnosz http://adino.com/?adino
>> adino http://djlmouv.ua/?djlmouv djlmouv
>> http://dehrvy.biz/?dehrvy dehrvy http://cefijlu.com/?cefijlu
>> cefijlu http://bfgitz.ua/?bfgitz bfgitz
>> http://ilmqsz.ua/?ilmqsz ilmqsz h
>> ttp://aejnrwy.ru/?aejnrwy <http://aejnrwy.ru/?aejnrwy>
>> aejnrwy https://lnuwz.ru/?lnuwz lnuwz http://jlnrv.com/?jlnrv
>> jlnrv https://bjstxz.ru/?bjstxz bjstxz
>> https://fhjnw.com/?fhjnw fhjnw https://ajmnuz.com/?ajmnuz
>> ajmnuz https://ghptxy.net/?ghptxy ghptxy
>> https://cehnsy.net/?cehnsy cehnsy https://ipuxyz.info/?ipuxyz
>> ipuxyz https://dfghintv.net/?dfghintv dfghintv
>> fimrstw https://bhkmpvz.ua/?bhkmpvz bhkmpvz h
>> ttp://cefkqrx.info/?cefkqrx <http://cefkqrx.info/?cefkqrx>
>> cefkqrx http://bdjkstvz.biz/?bdjkstvz bdjkstvz
>> https://ajkqrtuw.ru/?ajkqrtuw ajkqrtuw
>> http://diknqtu.biz/?diknqtu diknqtu http://hjnrux.ru/?hjnrux
>> hjnrux https://ilmouxy.info/?ilmouxy ilmouxy
>> http://adfijm.ua/?adfijm adfijm http://efgptx.ru/?efgptx
>> efgptx https://dmprtvwy.com/?dmprtvwy dmprtvwy
>> https://cfhsv.com/?cfhsv cfhsv http://adgoqr.biz/?adgoqr
>> adgoqr http://efilmx.net/?efilmx efilmx
>> http://eglpqrx.ua/?eglpqrx eglpqrx
>> http://acequxz.com/?acequxz acequxz http://lmsvz.ua/?lmsvz
>> lmsvz http://aefhprtw.com/?aefhprtw aefhprtw
>> https://bglnq.info/?bglnq bglnq http://befhirv.ua/?befhirv
>> befhirv https://achkryz.com/?achkryz achkryz
>> http://chjpqvyz.info/?chjpqvyz chjpqvyz
>> //cefkrux.ua/?cefkrux <http://cefkrux.ua/?cefkrux> cefkrux
>> https://bijqsu.ru/?bijqsu bijqsu http://ghoruxyz.ru/?ghoruxyz
>> ghoruxyz http://acejknry.ru/?acejknry acejknry
>> bmoqux https
>> ://aijklm.com/?aijklm <http://aijklm.com/?aijklm> aijklm
>> lmpstv https://ilmory.ua/?ilmory ilmory
>> https://chinpx.info/?chinpx chinpx http
>> s://fkntuvyz.info/?fkntuvyz <http://fkntuvyz.info/?fkntuvyz>
>> fkntuvyz http://cfghimtw.ua/?cfghimtw cfghimtw
>> degitv https://ghjlmr.net/?ghjlmr ghjlmr
>> https://aelmoy.com/?aelmoy aelmoy http:
>> //begilmnx.com/?begilmnx <http://begilmnx.com/?begilmnx>
>> begilmnx http://bcegrtxz.ua/?bcegrtxz bcegrtxz
>> http://cfgkpu.net/?cfgkpu cfgkpu http://efmqrtv.com/?efmqrtv
>> efmqrtv http://cegikmru.info/?cegikmru cegikmru
>> http://lmnopvxy.net/?lmnopvxy lmnopvxy http://abe
>> ptuy.net/?abeptuy <http://ptuy.net/?abeptuy> abeptuy
>> http://fimnoq.ua/?fimnoq fimnoq http://adefky.com/?adefky
>> adefky https://cdfijlrz.ru/?cdfijlrz cdfijlrz
>> gprtvx http://bklptuxz.net/?bklptuxz bklptuxz
>> https://bfknrvz.com/?bfknrvz bfknrvz http://dgkqrv.ua/?dgkqrv
>> dgkqrv https://adkprstv.net/?adkprstv adkprstv
>> bchiknpt http://hjklprx.biz/?hjklprx hjklprx http://bejor
>> uw.net/?bejoruw <http://uw.net/?bejoruw> bejoruw
>> http://otuxz.com/?otuxz otuxz http://fijlmnoq.info/?fijlmnoq
>> fijlmnoq http://cgiouw.ru/?cgiouw cgiouw
>> https://chjmosxy.biz/?chjmosxy chjmosxy
>> agnvwz http://bcfgkrvx.biz/?bcfgkrvx bcfgkrvx
>> https://bcejlsyz.info/?bcejlsyz bcejlsyz
>> https://efinrsy.ua/?efinrsy efinrsy https://kmosw.net/?kmosw
>> https://dijnqrsw.ua/?dijnqrsw dijnqrsw http://ijmnr.biz/?ijmnr
>> ijmnr https://gjouwxy.ru/?gjouwxy gjouwxy
>> https://klpuz.biz/?klpuz klpuz http://hijoux.net/?hijoux
>> hijoux http://bikmn.net/?bikmn bikmn
>> https://bcdflny.ua/?bcdflny bcdflny https://abqtux.ua/?abqtux
>> abqtux https://bpstw.com/?bpstw bpstw
>> http://cegmoqry.info/?cegmoqry cegmoqry
>> http://aeghjlw.net/?aeghjlw aeghjlw https://egjswz.ru/?egjswz
>> egjswz https://agiluv.info/?agiluv agiluv htt
>> ps://befimsu.biz/?befimsu <http://befimsu.biz/?befimsu>
>> befimsu https://abcdeiry.info/?abcdeiry abcdeiry
>> hinsw http://abfjklsy.net/?abfjklsy abfjklsy
>> http://ekopq.ru/?ekopq ekopq https://abfkrsz.ua/?abfkrsz
>> lu http://gmrstyz.info/?gmrstyz gmrstyz
>> http://fhilsuy.ua/?fhilsuy fhilsuy http://jmnpwx.ru/?jmnpwx
>> jmnpwx http://gikltvwy.ru/?gikltvwy gikltvwy
>> http://jopqy.biz/?jopqy jopqy http://bdlqry.info/?bdlqry
>> bdlqry https://ejlvwz.com/?ejlvwz ejlvwz
>> http://ceijvz.net/?ceijvz ceijvz http://cfijntyz.i
>> nfo/?cfijntyz cfijntyz http://efilotuv.com/?efilotuv
>> efilotuv http://cfmpyz.com/?cfmpyz cfmpyz
>> http://dhpqz.com/?dhpqz dhpqz http://dlpxz.com/?dlpxz dlpxz
>> https://gijlnqrs.biz/?gijlnqrs gijlnqrs
>> ://abcltx.com/?abcltx <http://abcltx.com/?abcltx> abcltx
>> https://bdfjopu.net/?bdfjopu bdfjopu http://bipvy.com/?bipvy
>> https://cdilnqvy.info/?cdilnqvy cdilnqvy
>> https://ginoxy.ua/?ginoxy ginoxy https://ciknpquy.net/?ci
>> knpquy ciknpquy https://egijstw.biz/?egijstw egijstw
>> http://ehinz.net/?ehinz ehinz http://gipvz.com/?gipvz gipvz
>> z http://aceglpqu.net/?aceglpqu aceglpqu
>> px https://elpuz.ua/?elpuz elpuz
>> https://bdeftvw.info/?bdeftvw bdeftvw
>> http://dgmnou.ru/?dgmnou dgmnou https://aiklnvx.com/?aiklnvx
>> aiklnvx http://ijoqrsvw.com/?ijoqrsvw ijoqrsvw
>> https://einrvxz.net/?einrvxz einrvxz https://ikmtx
>> z.net/?ikmtxz <http://z.net/?ikmtxz> ikmtxz
>> http://adkmqsz.biz/?adkmqsz adkmqsz http://bchnox.com/?bchnox
>> bchnox https://ckptvw.com/?ckptvw ckptvw
>> http://dgops.com/?dgops dgops https://bfnrtxy.info/?bfnrtxy
>> bfnrtxy http://bdnpstu.info/?bdnpstu bdnpstu
>> abcfouw https://abcekn.ru/?abcekn abcekn
>> http://ijnruvz.com/?ijnruvz ijnruvz http://mqruv.ua/?mqruv
>> mqruv https://afklmu.biz/?afklmu afklmu
>> aenoxy https://dghlpuvx.ru/?dghlpuvx dghlpuvx http://cefor.
>> https://ghklmqvy.com/?ghklmqvy ghklmqvy http://aeh
>> kty.com/?aehkty <http://kty.com/?aehkty> aehkty
>> https://aclpsuz.ru/?aclpsuz aclpsuz
>> cnopr http://adg
>> opz.ru/?adgopz <http://opz.ru/?adgopz> adgopz
>> a/?abfsz abfsz https://imqrvy.net/?imqrvy imqrvy
>> http://aceklno.info/?aceklno aceklno http://diotvyz.ru/?diot
>> vyz diotvyz https://aefkmruw.info/?aefkmruw aefkmruw
>> cefm
>> vx https://fgvwxz.info/?fgvwxz fgvwxz
>> ahiksx https://aghmxy.ru/?aghmxy aghmxy https:/
>> /hnopqt.net/?hnopqt <http://hnopqt.net/?hnopqt> hnopqt
>> /?crsuv crsuv http://abejkmoz.ua/?abejkmoz abejkmoz
>> degiptv http://hlnvy.ru/?hlnvy hlnvy http://gklmvx.info/?gklmvx
>> m/?dhijlrsw dhijlrsw http://elqst.ru/?elqst elqst
>> cemqtv http:/
>> /bgnqsz.info/?bgnqsz <http://bgnqsz.info/?bgnqsz> bgnqsz
>> u/?afhosxz afhosxz https://ehsvx.ru/?ehsvx ehsvx
>> dfghilr http://bdlqstv.com/?bdlqstv bdlqstv h
>> ttp://adhjnrsz.com/?adhjnrsz <http://adhjnrsz.com/?adhjnrsz>
>> adhjnrsz http://adiopqx.com/?adiopqx adiopqx
>> https://jkmrvyz.ua/?jkmrvyz jkmrvyz http://bfi
>> pruw.biz/?bfipruw <http://pruw.biz/?bfipruw> bfipruw
>> http://cjklos.ua/?cjklos cjklos http://afglru.ru/?afglru
>> afglru http://defrt.ua/?defrt defrt
>> https://bijnuwz.com/?bijnuwz bijnuwz http://abcgikwy.ua/?abcgi
>> kwy abcgikwy https://begimrv.ua/?begimrv begimrv
>> https://jlprv.net/?jlprv jlprv http://efhsz.ua/?efhsz efhsz
>> https://dgiqs.ua/?dgiqs dgiqs http://bgiprx.net/?bgiprx
>> bgiprx https://cdklmqv.biz/?cdklmqv cdklmqv
>> s://dpqrsv.biz/?dpqrsv <http://dpqrsv.biz/?dpqrsv> dpqrsv
>> u/?degijyz degijyz https://cikortuy.net/?cikortuy cikortuy
>> Hey handsome. I?ve just, only watched your pictures. You?re
>> sex. I am so, very bored today and I want to offer you
>> talking. My profile is here
>> URL:
>> <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181128/34d6fdf3/attachment.html>
>> Subject: Digest Footer
>> petsc-users mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
>> End of petsc-users Digest, Vol 119, Issue 89
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181129/b6b26d1c/attachment-0001.html>
Build unstructured mesh, done.
vector view - petsc order
Vec Object: 4 MPI processes
type: mpi
Process [0]
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
Process [1]
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
91.
92.
93.
94.
95.
96.
97.
98.
99.
100.
101.
102.
103.
104.
Process [2]
105.
106.
107.
108.
109.
110.
111.
112.
113.
114.
115.
116.
117.
118.
119.
120.
121.
122.
123.
124.
125.
126.
127.
128.
129.
130.
131.
132.
133.
134.
135.
136.
137.
138.
139.
140.
141.
142.
143.
144.
145.
146.
147.
148.
149.
150.
151.
152.
153.
154.
155.
156.
157.
158.
159.
Process [3]
160.
161.
162.
163.
164.
165.
166.
167.
168.
169.
170.
171.
172.
173.
174.
175.
176.
177.
178.
179.
180.
181.
182.
183.
184.
185.
186.
187.
188.
189.
190.
191.
192.
193.
194.
195.
196.
197.
198.
199.
200.
201.
202.
203.
204.
205.
206.
207.
208.
209.
210.
211.
212.
213.
214.
215.
216.
217.
218.
219.
220.
221.
222.
223.
check migration SF
PetscSF Object: 4 MPI processes
type: basic
sort=rank-order
[0] Number of roots=617, leaves=208, remote ranks=1
[0] 0 <- (0,0)
[0] 1 <- (0,4)
[0] 2 <- (0,12)
[0] 3 <- (0,14)
[0] 4 <- (0,18)
[0] 5 <- (0,21)
[0] 6 <- (0,31)
[0] 7 <- (0,33)
[0] 8 <- (0,34)
[0] 9 <- (0,37)
[0] 10 <- (0,39)
[0] 11 <- (0,41)
[0] 12 <- (0,61)
[0] 13 <- (0,74)
[0] 14 <- (0,81)
[0] 15 <- (0,83)
[0] 16 <- (0,85)
[0] 17 <- (0,86)
[0] 18 <- (0,87)
[0] 19 <- (0,93)
[0] 20 <- (0,94)
[0] 21 <- (0,95)
[0] 22 <- (0,96)
[0] 23 <- (0,98)
[0] 24 <- (0,100)
[0] 25 <- (0,103)
[0] 26 <- (0,108)
[0] 27 <- (0,111)
[0] 28 <- (0,113)
[0] 29 <- (0,118)
[0] 30 <- (0,151)
[0] 31 <- (0,152)
[0] 32 <- (0,154)
[0] 33 <- (0,160)
[0] 34 <- (0,161)
[0] 35 <- (0,166)
[0] 36 <- (0,176)
[0] 37 <- (0,178)
[0] 38 <- (0,204)
[0] 39 <- (0,207)
[0] 40 <- (0,213)
[0] 41 <- (0,216)
[0] 42 <- (0,220)
[0] 43 <- (0,223)
[0] 44 <- (0,224)
[0] 45 <- (0,225)
[0] 46 <- (0,227)
[0] 47 <- (0,231)
[0] 48 <- (0,233)
[0] 49 <- (0,240)
[0] 50 <- (0,241)
[0] 51 <- (0,250)
[0] 52 <- (0,267)
[0] 53 <- (0,269)
[0] 54 <- (0,273)
[0] 55 <- (0,275)
[0] 56 <- (0,280)
[0] 57 <- (0,281)
[0] 58 <- (0,291)
[0] 59 <- (0,296)
[0] 60 <- (0,298)
[0] 61 <- (0,303)
[0] 62 <- (0,308)
[0] 63 <- (0,313)
[0] 64 <- (0,318)
[0] 65 <- (0,323)
[0] 66 <- (0,324)
[0] 67 <- (0,338)
[0] 68 <- (0,339)
[0] 69 <- (0,345)
[0] 70 <- (0,346)
[0] 71 <- (0,347)
[0] 72 <- (0,350)
[0] 73 <- (0,351)
[0] 74 <- (0,353)
[0] 75 <- (0,354)
[0] 76 <- (0,355)
[0] 77 <- (0,356)
[0] 78 <- (0,360)
[0] 79 <- (0,362)
[0] 80 <- (0,364)
[0] 81 <- (0,365)
[0] 82 <- (0,366)
[0] 83 <- (0,368)
[0] 84 <- (0,369)
[0] 85 <- (0,370)
[0] 86 <- (0,373)
[0] 87 <- (0,375)
[0] 88 <- (0,377)
[0] 89 <- (0,378)
[0] 90 <- (0,379)
[0] 91 <- (0,380)
[0] 92 <- (0,381)
[0] 93 <- (0,384)
[0] 94 <- (0,385)
[0] 95 <- (0,386)
[0] 96 <- (0,387)
[0] 97 <- (0,388)
[0] 98 <- (0,390)
[0] 99 <- (0,391)
[0] 100 <- (0,11)
[0] 101 <- (0,27)
[0] 102 <- (0,48)
[0] 103 <- (0,56)
[0] 104 <- (0,70)
[0] 105 <- (0,104)
[0] 106 <- (0,124)
[0] 107 <- (0,125)
[0] 108 <- (0,128)
[0] 109 <- (0,130)
[0] 110 <- (0,260)
[0] 111 <- (0,278)
[0] 112 <- (0,292)
[0] 113 <- (0,315)
[0] 114 <- (0,316)
[0] 115 <- (0,321)
[0] 116 <- (0,340)
[0] 117 <- (0,341)
[0] 118 <- (0,17)
[0] 119 <- (0,22)
[0] 120 <- (0,50)
[0] 121 <- (0,66)
[0] 122 <- (0,69)
[0] 123 <- (0,150)
[0] 124 <- (0,157)
[0] 125 <- (0,169)
[0] 126 <- (0,257)
[0] 127 <- (0,270)
[0] 128 <- (0,322)
[0] 129 <- (0,397)
[0] 130 <- (0,405)
[0] 131 <- (0,420)
[0] 132 <- (0,421)
[0] 133 <- (0,422)
[0] 134 <- (0,423)
[0] 135 <- (0,437)
[0] 136 <- (0,438)
[0] 137 <- (0,439)
[0] 138 <- (0,440)
[0] 139 <- (0,441)
[0] 140 <- (0,442)
[0] 141 <- (0,460)
[0] 142 <- (0,461)
[0] 143 <- (0,469)
[0] 144 <- (0,471)
[0] 145 <- (0,477)
[0] 146 <- (0,485)
[0] 147 <- (0,487)
[0] 148 <- (0,492)
[0] 149 <- (0,493)
[0] 150 <- (0,494)
[0] 151 <- (0,498)
[0] 152 <- (0,506)
[0] 153 <- (0,514)
[0] 154 <- (0,522)
[0] 155 <- (0,525)
[0] 156 <- (0,532)
[0] 157 <- (0,533)
[0] 158 <- (0,538)
[0] 159 <- (0,542)
[0] 160 <- (0,545)
[0] 161 <- (0,551)
[0] 162 <- (0,564)
[0] 163 <- (0,571)
[0] 164 <- (0,573)
[0] 165 <- (0,584)
[0] 166 <- (0,585)
[0] 167 <- (0,591)
[0] 168 <- (0,593)
[0] 169 <- (0,594)
[0] 170 <- (0,600)
[0] 171 <- (0,603)
[0] 172 <- (0,605)
[0] 173 <- (0,606)
[0] 174 <- (0,607)
[0] 175 <- (0,613)
[0] 176 <- (0,616)
[0] 177 <- (0,398)
[0] 178 <- (0,399)
[0] 179 <- (0,400)
[0] 180 <- (0,401)
[0] 181 <- (0,404)
[0] 182 <- (0,424)
[0] 183 <- (0,425)
[0] 184 <- (0,455)
[0] 185 <- (0,456)
[0] 186 <- (0,457)
[0] 187 <- (0,501)
[0] 188 <- (0,512)
[0] 189 <- (0,520)
[0] 190 <- (0,544)
[0] 191 <- (0,549)
[0] 192 <- (0,576)
[0] 193 <- (0,596)
[0] 194 <- (0,612)
[0] 195 <- (0,435)
[0] 196 <- (0,436)
[0] 197 <- (0,459)
[0] 198 <- (0,470)
[0] 199 <- (0,473)
[0] 200 <- (0,495)
[0] 201 <- (0,521)
[0] 202 <- (0,531)
[0] 203 <- (0,536)
[0] 204 <- (0,539)
[0] 205 <- (0,550)
[0] 206 <- (0,566)
[0] 207 <- (0,604)
[1] Number of roots=0, leaves=217, remote ranks=1
[1] 0 <- (0,1)
[1] 1 <- (0,5)
[1] 2 <- (0,6)
[1] 3 <- (0,11)
[1] 4 <- (0,19)
[1] 5 <- (0,20)
[1] 6 <- (0,25)
[1] 7 <- (0,26)
[1] 8 <- (0,27)
[1] 9 <- (0,28)
[1] 10 <- (0,29)
[1] 11 <- (0,32)
[1] 12 <- (0,40)
[1] 13 <- (0,42)
[1] 14 <- (0,43)
[1] 15 <- (0,44)
[1] 16 <- (0,47)
[1] 17 <- (0,48)
[1] 18 <- (0,56)
[1] 19 <- (0,57)
[1] 20 <- (0,59)
[1] 21 <- (0,60)
[1] 22 <- (0,62)
[1] 23 <- (0,63)
[1] 24 <- (0,70)
[1] 25 <- (0,71)
[1] 26 <- (0,75)
[1] 27 <- (0,76)
[1] 28 <- (0,78)
[1] 29 <- (0,88)
[1] 30 <- (0,90)
[1] 31 <- (0,104)
[1] 32 <- (0,121)
[1] 33 <- (0,124)
[1] 34 <- (0,125)
[1] 35 <- (0,128)
[1] 36 <- (0,129)
[1] 37 <- (0,130)
[1] 38 <- (0,132)
[1] 39 <- (0,133)
[1] 40 <- (0,136)
[1] 41 <- (0,142)
[1] 42 <- (0,145)
[1] 43 <- (0,147)
[1] 44 <- (0,163)
[1] 45 <- (0,165)
[1] 46 <- (0,180)
[1] 47 <- (0,181)
[1] 48 <- (0,186)
[1] 49 <- (0,187)
[1] 50 <- (0,190)
[1] 51 <- (0,198)
[1] 52 <- (0,208)
[1] 53 <- (0,210)
[1] 54 <- (0,211)
[1] 55 <- (0,212)
[1] 56 <- (0,218)
[1] 57 <- (0,228)
[1] 58 <- (0,243)
[1] 59 <- (0,244)
[1] 60 <- (0,245)
[1] 61 <- (0,248)
[1] 62 <- (0,249)
[1] 63 <- (0,253)
[1] 64 <- (0,256)
[1] 65 <- (0,258)
[1] 66 <- (0,260)
[1] 67 <- (0,261)
[1] 68 <- (0,274)
[1] 69 <- (0,278)
[1] 70 <- (0,282)
[1] 71 <- (0,283)
[1] 72 <- (0,284)
[1] 73 <- (0,285)
[1] 74 <- (0,287)
[1] 75 <- (0,292)
[1] 76 <- (0,295)
[1] 77 <- (0,299)
[1] 78 <- (0,309)
[1] 79 <- (0,315)
[1] 80 <- (0,316)
[1] 81 <- (0,321)
[1] 82 <- (0,327)
[1] 83 <- (0,331)
[1] 84 <- (0,332)
[1] 85 <- (0,335)
[1] 86 <- (0,336)
[1] 87 <- (0,337)
[1] 88 <- (0,340)
[1] 89 <- (0,341)
[1] 90 <- (0,342)
[1] 91 <- (0,343)
[1] 92 <- (0,344)
[1] 93 <- (0,359)
[1] 94 <- (0,361)
[1] 95 <- (0,382)
[1] 96 <- (0,392)
[1] 97 <- (0,93)
[1] 98 <- (0,154)
[1] 99 <- (0,178)
[1] 100 <- (0,204)
[1] 101 <- (0,281)
[1] 102 <- (0,291)
[1] 103 <- (0,296)
[1] 104 <- (0,298)
[1] 105 <- (0,303)
[1] 106 <- (0,308)
[1] 107 <- (0,318)
[1] 108 <- (0,339)
[1] 109 <- (0,350)
[1] 110 <- (0,351)
[1] 111 <- (0,353)
[1] 112 <- (0,355)
[1] 113 <- (0,370)
[1] 114 <- (0,379)
[1] 115 <- (0,380)
[1] 116 <- (0,388)
[1] 117 <- (0,49)
[1] 118 <- (0,50)
[1] 119 <- (0,169)
[1] 120 <- (0,246)
[1] 121 <- (0,247)
[1] 122 <- (0,9)
[1] 123 <- (0,30)
[1] 124 <- (0,135)
[1] 125 <- (0,148)
[1] 126 <- (0,184)
[1] 127 <- (0,189)
[1] 128 <- (0,229)
[1] 129 <- (0,277)
[1] 130 <- (0,320)
[1] 131 <- (0,352)
[1] 132 <- (0,393)
[1] 133 <- (0,394)
[1] 134 <- (0,398)
[1] 135 <- (0,399)
[1] 136 <- (0,400)
[1] 137 <- (0,401)
[1] 138 <- (0,403)
[1] 139 <- (0,404)
[1] 140 <- (0,406)
[1] 141 <- (0,407)
[1] 142 <- (0,408)
[1] 143 <- (0,409)
[1] 144 <- (0,410)
[1] 145 <- (0,411)
[1] 146 <- (0,424)
[1] 147 <- (0,425)
[1] 148 <- (0,426)
[1] 149 <- (0,427)
[1] 150 <- (0,428)
[1] 151 <- (0,455)
[1] 152 <- (0,456)
[1] 153 <- (0,457)
[1] 154 <- (0,464)
[1] 155 <- (0,466)
[1] 156 <- (0,475)
[1] 157 <- (0,484)
[1] 158 <- (0,490)
[1] 159 <- (0,496)
[1] 160 <- (0,497)
[1] 161 <- (0,501)
[1] 162 <- (0,509)
[1] 163 <- (0,510)
[1] 164 <- (0,512)
[1] 165 <- (0,515)
[1] 166 <- (0,520)
[1] 167 <- (0,534)
[1] 168 <- (0,537)
[1] 169 <- (0,544)
[1] 170 <- (0,548)
[1] 171 <- (0,549)
[1] 172 <- (0,555)
[1] 173 <- (0,556)
[1] 174 <- (0,560)
[1] 175 <- (0,562)
[1] 176 <- (0,567)
[1] 177 <- (0,570)
[1] 178 <- (0,576)
[1] 179 <- (0,577)
[1] 180 <- (0,579)
[1] 181 <- (0,586)
[1] 182 <- (0,587)
[1] 183 <- (0,588)
[1] 184 <- (0,590)
[1] 185 <- (0,596)
[1] 186 <- (0,609)
[1] 187 <- (0,612)
[1] 188 <- (0,615)
[1] 189 <- (0,405)
[1] 190 <- (0,423)
[1] 191 <- (0,471)
[1] 192 <- (0,477)
[1] 193 <- (0,522)
[1] 194 <- (0,533)
[1] 195 <- (0,600)
[1] 196 <- (0,603)
[1] 197 <- (0,613)
[1] 198 <- (0,616)
[1] 199 <- (0,470)
[1] 200 <- (0,479)
[1] 201 <- (0,521)
[1] 202 <- (0,531)
[1] 203 <- (0,604)
[1] 204 <- (0,412)
[1] 205 <- (0,413)
[1] 206 <- (0,452)
[1] 207 <- (0,453)
[1] 208 <- (0,478)
[1] 209 <- (0,488)
[1] 210 <- (0,502)
[1] 211 <- (0,517)
[1] 212 <- (0,565)
[1] 213 <- (0,568)
[1] 214 <- (0,574)
[1] 215 <- (0,598)
[1] 216 <- (0,608)
[2] Number of roots=0, leaves=215, remote ranks=1
[2] 0 <- (0,17)
[2] 1 <- (0,22)
[2] 2 <- (0,35)
[2] 3 <- (0,38)
[2] 4 <- (0,49)
[2] 5 <- (0,50)
[2] 6 <- (0,52)
[2] 7 <- (0,54)
[2] 8 <- (0,55)
[2] 9 <- (0,58)
[2] 10 <- (0,64)
[2] 11 <- (0,66)
[2] 12 <- (0,69)
[2] 13 <- (0,80)
[2] 14 <- (0,82)
[2] 15 <- (0,89)
[2] 16 <- (0,92)
[2] 17 <- (0,97)
[2] 18 <- (0,99)
[2] 19 <- (0,105)
[2] 20 <- (0,106)
[2] 21 <- (0,107)
[2] 22 <- (0,109)
[2] 23 <- (0,110)
[2] 24 <- (0,117)
[2] 25 <- (0,119)
[2] 26 <- (0,126)
[2] 27 <- (0,131)
[2] 28 <- (0,139)
[2] 29 <- (0,140)
[2] 30 <- (0,146)
[2] 31 <- (0,149)
[2] 32 <- (0,150)
[2] 33 <- (0,153)
[2] 34 <- (0,155)
[2] 35 <- (0,156)
[2] 36 <- (0,157)
[2] 37 <- (0,162)
[2] 38 <- (0,169)
[2] 39 <- (0,171)
[2] 40 <- (0,177)
[2] 41 <- (0,182)
[2] 42 <- (0,188)
[2] 43 <- (0,193)
[2] 44 <- (0,194)
[2] 45 <- (0,195)
[2] 46 <- (0,196)
[2] 47 <- (0,197)
[2] 48 <- (0,199)
[2] 49 <- (0,200)
[2] 50 <- (0,201)
[2] 51 <- (0,202)
[2] 52 <- (0,205)
[2] 53 <- (0,206)
[2] 54 <- (0,214)
[2] 55 <- (0,215)
[2] 56 <- (0,217)
[2] 57 <- (0,219)
[2] 58 <- (0,230)
[2] 59 <- (0,232)
[2] 60 <- (0,234)
[2] 61 <- (0,237)
[2] 62 <- (0,238)
[2] 63 <- (0,239)
[2] 64 <- (0,242)
[2] 65 <- (0,246)
[2] 66 <- (0,247)
[2] 67 <- (0,255)
[2] 68 <- (0,257)
[2] 69 <- (0,262)
[2] 70 <- (0,263)
[2] 71 <- (0,264)
[2] 72 <- (0,270)
[2] 73 <- (0,279)
[2] 74 <- (0,286)
[2] 75 <- (0,288)
[2] 76 <- (0,289)
[2] 77 <- (0,290)
[2] 78 <- (0,300)
[2] 79 <- (0,304)
[2] 80 <- (0,305)
[2] 81 <- (0,306)
[2] 82 <- (0,307)
[2] 83 <- (0,310)
[2] 84 <- (0,311)
[2] 85 <- (0,312)
[2] 86 <- (0,314)
[2] 87 <- (0,319)
[2] 88 <- (0,322)
[2] 89 <- (0,328)
[2] 90 <- (0,348)
[2] 91 <- (0,349)
[2] 92 <- (0,358)
[2] 93 <- (0,363)
[2] 94 <- (0,367)
[2] 95 <- (0,371)
[2] 96 <- (0,374)
[2] 97 <- (0,376)
[2] 98 <- (0,74)
[2] 99 <- (0,86)
[2] 100 <- (0,95)
[2] 101 <- (0,160)
[2] 102 <- (0,213)
[2] 103 <- (0,225)
[2] 104 <- (0,231)
[2] 105 <- (0,298)
[2] 106 <- (0,345)
[2] 107 <- (0,355)
[2] 108 <- (0,356)
[2] 109 <- (0,386)
[2] 110 <- (0,70)
[2] 111 <- (0,104)
[2] 112 <- (0,136)
[2] 113 <- (0,198)
[2] 114 <- (0,8)
[2] 115 <- (0,13)
[2] 116 <- (0,91)
[2] 117 <- (0,115)
[2] 118 <- (0,122)
[2] 119 <- (0,134)
[2] 120 <- (0,164)
[2] 121 <- (0,172)
[2] 122 <- (0,301)
[2] 123 <- (0,320)
[2] 124 <- (0,325)
[2] 125 <- (0,326)
[2] 126 <- (0,329)
[2] 127 <- (0,330)
[2] 128 <- (0,334)
[2] 129 <- (0,352)
[2] 130 <- (0,357)
[2] 131 <- (0,393)
[2] 132 <- (0,396)
[2] 133 <- (0,429)
[2] 134 <- (0,430)
[2] 135 <- (0,431)
[2] 136 <- (0,432)
[2] 137 <- (0,433)
[2] 138 <- (0,434)
[2] 139 <- (0,435)
[2] 140 <- (0,436)
[2] 141 <- (0,448)
[2] 142 <- (0,449)
[2] 143 <- (0,450)
[2] 144 <- (0,451)
[2] 145 <- (0,458)
[2] 146 <- (0,459)
[2] 147 <- (0,467)
[2] 148 <- (0,468)
[2] 149 <- (0,470)
[2] 150 <- (0,472)
[2] 151 <- (0,473)
[2] 152 <- (0,476)
[2] 153 <- (0,479)
[2] 154 <- (0,481)
[2] 155 <- (0,482)
[2] 156 <- (0,495)
[2] 157 <- (0,503)
[2] 158 <- (0,505)
[2] 159 <- (0,511)
[2] 160 <- (0,516)
[2] 161 <- (0,519)
[2] 162 <- (0,521)
[2] 163 <- (0,523)
[2] 164 <- (0,524)
[2] 165 <- (0,528)
[2] 166 <- (0,530)
[2] 167 <- (0,531)
[2] 168 <- (0,536)
[2] 169 <- (0,539)
[2] 170 <- (0,540)
[2] 171 <- (0,541)
[2] 172 <- (0,546)
[2] 173 <- (0,547)
[2] 174 <- (0,550)
[2] 175 <- (0,554)
[2] 176 <- (0,559)
[2] 177 <- (0,561)
[2] 178 <- (0,566)
[2] 179 <- (0,578)
[2] 180 <- (0,580)
[2] 181 <- (0,582)
[2] 182 <- (0,592)
[2] 183 <- (0,597)
[2] 184 <- (0,601)
[2] 185 <- (0,604)
[2] 186 <- (0,614)
[2] 187 <- (0,437)
[2] 188 <- (0,460)
[2] 189 <- (0,506)
[2] 190 <- (0,514)
[2] 191 <- (0,600)
[2] 192 <- (0,606)
[2] 193 <- (0,401)
[2] 194 <- (0,520)
[2] 195 <- (0,402)
[2] 196 <- (0,446)
[2] 197 <- (0,447)
[2] 198 <- (0,452)
[2] 199 <- (0,453)
[2] 200 <- (0,454)
[2] 201 <- (0,463)
[2] 202 <- (0,483)
[2] 203 <- (0,504)
[2] 204 <- (0,507)
[2] 205 <- (0,526)
[2] 206 <- (0,527)
[2] 207 <- (0,529)
[2] 208 <- (0,552)
[2] 209 <- (0,568)
[2] 210 <- (0,574)
[2] 211 <- (0,599)
[2] 212 <- (0,608)
[2] 213 <- (0,610)
[2] 214 <- (0,611)
[3] Number of roots=0, leaves=206, remote ranks=1
[3] 0 <- (0,2)
[3] 1 <- (0,3)
[3] 2 <- (0,7)
[3] 3 <- (0,8)
[3] 4 <- (0,9)
[3] 5 <- (0,10)
[3] 6 <- (0,13)
[3] 7 <- (0,15)
[3] 8 <- (0,16)
[3] 9 <- (0,23)
[3] 10 <- (0,24)
[3] 11 <- (0,30)
[3] 12 <- (0,36)
[3] 13 <- (0,45)
[3] 14 <- (0,46)
[3] 15 <- (0,51)
[3] 16 <- (0,53)
[3] 17 <- (0,65)
[3] 18 <- (0,67)
[3] 19 <- (0,68)
[3] 20 <- (0,72)
[3] 21 <- (0,73)
[3] 22 <- (0,77)
[3] 23 <- (0,79)
[3] 24 <- (0,84)
[3] 25 <- (0,91)
[3] 26 <- (0,101)
[3] 27 <- (0,102)
[3] 28 <- (0,112)
[3] 29 <- (0,114)
[3] 30 <- (0,115)
[3] 31 <- (0,116)
[3] 32 <- (0,120)
[3] 33 <- (0,122)
[3] 34 <- (0,123)
[3] 35 <- (0,127)
[3] 36 <- (0,134)
[3] 37 <- (0,135)
[3] 38 <- (0,137)
[3] 39 <- (0,138)
[3] 40 <- (0,141)
[3] 41 <- (0,143)
[3] 42 <- (0,144)
[3] 43 <- (0,148)
[3] 44 <- (0,158)
[3] 45 <- (0,159)
[3] 46 <- (0,164)
[3] 47 <- (0,167)
[3] 48 <- (0,168)
[3] 49 <- (0,170)
[3] 50 <- (0,172)
[3] 51 <- (0,173)
[3] 52 <- (0,174)
[3] 53 <- (0,175)
[3] 54 <- (0,179)
[3] 55 <- (0,183)
[3] 56 <- (0,184)
[3] 57 <- (0,185)
[3] 58 <- (0,189)
[3] 59 <- (0,191)
[3] 60 <- (0,192)
[3] 61 <- (0,203)
[3] 62 <- (0,209)
[3] 63 <- (0,221)
[3] 64 <- (0,222)
[3] 65 <- (0,226)
[3] 66 <- (0,229)
[3] 67 <- (0,235)
[3] 68 <- (0,236)
[3] 69 <- (0,251)
[3] 70 <- (0,252)
[3] 71 <- (0,254)
[3] 72 <- (0,259)
[3] 73 <- (0,265)
[3] 74 <- (0,266)
[3] 75 <- (0,268)
[3] 76 <- (0,271)
[3] 77 <- (0,272)
[3] 78 <- (0,276)
[3] 79 <- (0,277)
[3] 80 <- (0,293)
[3] 81 <- (0,294)
[3] 82 <- (0,297)
[3] 83 <- (0,301)
[3] 84 <- (0,302)
[3] 85 <- (0,317)
[3] 86 <- (0,320)
[3] 87 <- (0,325)
[3] 88 <- (0,326)
[3] 89 <- (0,329)
[3] 90 <- (0,330)
[3] 91 <- (0,333)
[3] 92 <- (0,334)
[3] 93 <- (0,352)
[3] 94 <- (0,357)
[3] 95 <- (0,372)
[3] 96 <- (0,383)
[3] 97 <- (0,389)
[3] 98 <- (0,393)
[3] 99 <- (0,59)
[3] 100 <- (0,121)
[3] 101 <- (0,136)
[3] 102 <- (0,163)
[3] 103 <- (0,181)
[3] 104 <- (0,186)
[3] 105 <- (0,187)
[3] 106 <- (0,198)
[3] 107 <- (0,228)
[3] 108 <- (0,299)
[3] 109 <- (0,64)
[3] 110 <- (0,80)
[3] 111 <- (0,82)
[3] 112 <- (0,105)
[3] 113 <- (0,109)
[3] 114 <- (0,110)
[3] 115 <- (0,117)
[3] 116 <- (0,139)
[3] 117 <- (0,153)
[3] 118 <- (0,193)
[3] 119 <- (0,202)
[3] 120 <- (0,206)
[3] 121 <- (0,219)
[3] 122 <- (0,246)
[3] 123 <- (0,247)
[3] 124 <- (0,304)
[3] 125 <- (0,305)
[3] 126 <- (0,367)
[3] 127 <- (0,395)
[3] 128 <- (0,402)
[3] 129 <- (0,412)
[3] 130 <- (0,413)
[3] 131 <- (0,414)
[3] 132 <- (0,415)
[3] 133 <- (0,416)
[3] 134 <- (0,417)
[3] 135 <- (0,418)
[3] 136 <- (0,419)
[3] 137 <- (0,443)
[3] 138 <- (0,444)
[3] 139 <- (0,445)
[3] 140 <- (0,446)
[3] 141 <- (0,447)
[3] 142 <- (0,452)
[3] 143 <- (0,453)
[3] 144 <- (0,454)
[3] 145 <- (0,462)
[3] 146 <- (0,463)
[3] 147 <- (0,465)
[3] 148 <- (0,474)
[3] 149 <- (0,478)
[3] 150 <- (0,480)
[3] 151 <- (0,483)
[3] 152 <- (0,486)
[3] 153 <- (0,488)
[3] 154 <- (0,489)
[3] 155 <- (0,491)
[3] 156 <- (0,499)
[3] 157 <- (0,500)
[3] 158 <- (0,502)
[3] 159 <- (0,504)
[3] 160 <- (0,507)
[3] 161 <- (0,508)
[3] 162 <- (0,513)
[3] 163 <- (0,517)
[3] 164 <- (0,518)
[3] 165 <- (0,526)
[3] 166 <- (0,527)
[3] 167 <- (0,529)
[3] 168 <- (0,535)
[3] 169 <- (0,543)
[3] 170 <- (0,552)
[3] 171 <- (0,553)
[3] 172 <- (0,557)
[3] 173 <- (0,558)
[3] 174 <- (0,563)
[3] 175 <- (0,565)
[3] 176 <- (0,568)
[3] 177 <- (0,569)
[3] 178 <- (0,572)
[3] 179 <- (0,574)
[3] 180 <- (0,575)
[3] 181 <- (0,581)
[3] 182 <- (0,583)
[3] 183 <- (0,589)
[3] 184 <- (0,595)
[3] 185 <- (0,598)
[3] 186 <- (0,599)
[3] 187 <- (0,602)
[3] 188 <- (0,608)
[3] 189 <- (0,610)
[3] 190 <- (0,611)
[3] 191 <- (0,401)
[3] 192 <- (0,411)
[3] 193 <- (0,464)
[3] 194 <- (0,556)
[3] 195 <- (0,567)
[3] 196 <- (0,448)
[3] 197 <- (0,468)
[3] 198 <- (0,476)
[3] 199 <- (0,479)
[3] 200 <- (0,519)
[3] 201 <- (0,521)
[3] 202 <- (0,530)
[3] 203 <- (0,540)
[3] 204 <- (0,561)
[3] 205 <- (0,582)
vector view - natural order
type: mpi
Process [0]
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
Process [1]
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
Process [2]
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
Process [3]
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
0.
Set DMPlex local to global mapping, done
Force to stop
# vtk DataFile Version 2.0
unstructured-mesh, Created by Gmsh
ASCII
DATASET UNSTRUCTURED_GRID
POINTS 223 double
0 0 0
3 0 0
3 0 2
0 0 2
0.2 0 0.8
0.4 0 0.8
0.8 0 0.8
1.4 0 0.8
2.2 0 0.8
0.8 0 0.6
0.8 0 1
0.8 0 1.2
0.1999999999991203 0 0
0.3999999999983593 0 0
0.5999999999974546 0 0
0.799999999996742 0 0
0.9999999999960294 0 0
1.199999999995317 0 0
1.399999999994604 0 0
1.599999999994632 0 0
1.799999999995399 0 0
1.999999999996166 0 0
2.199999999996932 0 0
2.3999999999977 0 0
2.599999999998466 0 0
2.799999999999233 0 0
0 0 1.799999999999167
0 0 1.6
0 0 1.400000000001387
0 0 1.200000000002774
0 0 1.000000000004117
0 0 0.8000000000033287
0 0 0.6000000000024965
0 0 0.4000000000016644
0 0 0.200000000000832
2.800000000002174 0 2
2.600000000002023 0 2
2.400000000003 0 2
2.200000000002438 0 2
2.000000000001934 0 2
1.800000000002824 0 2
1.600000000003743 0 2
1.400000000003922 0 2
1.200000000003361 0 2
1.000000000002801 0 2
0.8000000000022411 0 2
0.600000000001681 0 2
0.4000000000011208 0 2
0.2000000000005602 0 2
3 0 0.1999999999996293
3 0 0.3999999999991157
3 0 0.5999999999985328
3 0 0.7999999999979498
3 0 0.9999999999973885
3 0 1.199999999997894
3 0 1.39999999999842
3 0 1.599999999998947
3 0 1.799999999999474
1.599999999999545 0 0.8
1.799999999998915 0 0.8
1.999999999999414 0 0.8
0.999999999999776 0 0.8
1.199999999999581 0 0.8
0.5999999999994576 0 0.8
2.379214504531294 0 1.405373076248138
1.704991835910612 0 1.402778606292781
1.23408069164269 0 1.458669309885507
0.4685665670601734 0 1.508019509283279
2.497738191218041 0 0.4349897042973965
2.610303185213958 0 0.9878017997043026
1.296692364559492 0 0.3986179228025756
1.909153318464776 0 0.4063140589542637
0.4623896075858526 0 0.3881084953993027
2.05931870173157 0 1.584337375247877
2.038721804512762 0 1.194360902254602
0.837837785556555 0 1.66744985915262
1.397714914184593 0 1.148692746366346
0.3742908223262418 0 1.174082908003071
2.665804146696016 0 1.663931138500056
1.497313596493072 0 1.673656798244939
2.227235772357356 0 0.3329268292685604
0.9938576986066314 0 0.3080338817095
2.697653501978651 0 1.292297570997389
1.096142514170803 0 1.1
1.605753072669749 0 0.491762523868872
1.69999999999923 0 1.091666666666887
2.71251200913381 0 0.7161239977234372
2.351344489130117 0 1.699121968393499
1.782173742909407 0 1.712990171238928
2.280062762525843 0 1.050264328024126
0.705769497964517 0 0.2623692964269909
0.2854025199473142 0 1.729673118535918
2.715992888350279 0 0.259203247264699
1.065208746302501 0 1.729902382621085
1.691666666666294 0 0.2437499999987736
2.440212763582161 0 0.7106750276238525
1.100121885885791 0 0.5682290676564412
2.10438472624376 0 0.5771286151995686
0.9442269078216747 0 1.355912991197506
0.6163286784502398 0 1.742953710918845
0.2780048027011408 0 1.402161836324629
1.478220357618803 0 1.470719894825082
0.2471457398099939 0 0.2524810787590218
0.2487655548760474 0 0.5238310750572215
0.6264666351387723 0 1.347553521562679
2.490235690235405 0 0.2265993265990937
2.803830918769202 0 0.526638964852175
0.5594040508164777 0 1.036741482837054
1.457982520923784 0 0.2269956302319235
1.937737252573877 0 1.391730183630887
2.796228535856523 0 1.102723737365208
2.159147416270142 0 1.403608979873389
1.281872426241454 0 1.800902035832503
1.8837415199635 0 1.003577707586214
2.03680937116415 0 0.2433849188490117
0.5795454545454293 0 0.5795454545453738
1.170008074655726 0 0.2233372172980658
2.801404909550425 0 1.492049198199022
0.2177437641725037 0 1.017743764172138
2.323894267418511 0 0.5113033981177416
1.172046878761573 0 1.270534731754538
0.5485564404307722 0 0.1918013452245567
2.083695878040242 0 1.807197232140322
1.416074624101432 0 0.5774396173238155
1.785479734433667 0 0.5752957350000555
2.501649089227999 0 1.271931709598009
1.284479965824385 0 0.9903690252861073
1.523327777985623 0 1.000647820252583
0.5364474308195638 0 1.217014743936919
2.789881440617124 0 1.789881440617261
2.507494844449481 0 1.809810027645477
0.9231700938715783 0 1.851873008429856
2.111938913072513 0 0.9830530884882849
2.793154307858761 0 0.8768075521287002
2.587000975789033 0 1.453818519623165
2.394803322025814 0 0.8926720437521438
1.834919049360319 0 1.223481514480617
1.573104508099891 0 1.238404636402246
0.4475743170520548 0 1.838276232017855
0.1815881432411806 0 1.217598300523445
0.8672650147563506 0 0.1762453176299749
2.306587108970027 0 0.1705150816205509
1.625410855356525 0 1.780289239734096
0.8233833894553626 0 0.3832672040340161
0.1696953830832089 0 1.570979889137452
1.65389327768683 0 1.587851501742204
2.261020253229125 0 1.250190685669392
1.892425939574817 0 1.84614964303553
1.024101021611565 0 1.523932646626128
1.865603535956367 0 0.205257814827333
0.3933113884489506 0 0.9690646432006123
0.4507987812721571 0 1.338822405420034
2.274894458806367 0 1.544832506227184
1.838053030422587 0 1.554838056794376
0.3686859183416712 0 0.61430085724029
0.9738015786914841 0 0.9738015786915135
1.332511029850933 0 1.615932245360217
0.9894053075619311 0 1.229077937292363
2.577637560506477 0 0.8159297007077034
2.375571518833167 0 0.3445824808775385
2.476279702749816 0 1.597328424196379
0.1460062754235328 0 0.3970029733771729
1.265344920154252 0 0.6329578502716723
1.935835647926898 0 0.6344934670553749
2.069281594968028 0 0.3940954484269742
2.29506823171605 0 1.851926700449395
0.6361007615483169 0 0.4081024174896069
2.863891877583948 0 1.299999999998157
1.121879385586257 0 0.3968719495845081
2.866792480267094 0 0.6999999999982413
0.640716822374706 0 1.564448591963968
1.465065170338345 0 0.3920979873954564
1.461565556697408 0 1.846878377665404
1.313202543621524 0 0.1520409031873539
1.700610872801345 0 0.9324817812131065
1.771531265638171 0 0.3844760265298595
0.9316739727448209 0 0.6501584876562788
0.1553841991341328 0 1.844615800865806
2.83194205855847 0 0.1548176119178121
0.7554673115764591 0 1.852455315700264
1.543297705630606 0 0.6692863615262314
2.573954635025233 0 0.5925173061601432
1.116582444085043 0 0.9359264074853757
1.025953898186142 0 0.1576523269573968
2.847994284561111 0 1.642990843504484
0.9600149914842826 0 0.4894980205592772
2.205556830158146 0 1.69321441508239
2.627328673572279 0 0.1531224420159892
2.642687904572294 0 1.141659092120952
2.834577319798835 0 0.3225122389814655
0.2983336950301236 0 1.882071991275122
0.8122248620838787 0 1.44321626841715
0.6996996928159201 0 0.1181368787597825
0.1444936133652446 0 0.1476295673217159
0.1529060387700887 0 0.638313084543821
2.293874040543968 0 0.6803984596738974
0.3457826007705083 0 0.1617330481724948
0.1220964204329312 0 1.709053761707669
2.657398203846927 0 1.861014030866323
0.3295446886489339 0 1.593181052285239
1.098772336102051 0 1.885940614691867
2.652721607232833 0 0.3937434646924954
0.6818782899869689 0 0.9475655802543401
1.931167058145805 0 1.69635186532083
1.581219843306312 0 0.1461740902663257
2.447705348719867 0 1.095025095160731
1.257592110345052 0 1.147316202898446
1.757518958348691 0 1.860358589513101
2.155116155877665 0 0.1392252118453306
0.6673660677936304 0 1.124812554765165
1.35385707705373 0 1.313046155723573
0.4646889322555703 0 1.662758702500851
1.187554783129829 0 1.625867724065088
1.077557767903738 0 1.371623591692298
1.680167363715666 0 0.6787096877578693
0.6812821612349281 0 0.6812821612351486
2.246701249406042 0 0.9314973650661384
2.169432754969319 0 1.119127586148288
0.1164067881991524 0 0.916406788200873
0.1014459250697099 0 1.100000000003446
2.890346327029697 0 1.890346327028477
0.3102787716159667 0 0.3755545051061105
0.9318698800848435 0 1.100575903196775
CELLS 469 1789
1 0
1 1
1 2
1 3
1 4
1 5
1 6
1 7
1 8
1 9
1 10
1 11
2 0 12
2 12 13
2 13 14
2 14 15
2 15 16
2 16 17
2 17 18
2 18 19
2 19 20
2 20 21
2 21 22
2 22 23
2 23 24
2 24 25
2 25 1
2 3 26
2 26 27
2 27 28
2 28 29
2 29 30
2 30 31
2 31 32
2 32 33
2 33 34
2 34 0
2 2 35
2 35 36
2 36 37
2 37 38
2 38 39
2 39 40
2 40 41
2 41 42
2 42 43
2 43 44
2 44 45
2 45 46
2 46 47
2 47 48
2 48 3
2 1 49
2 49 50
2 50 51
2 51 52
2 52 53
2 53 54
2 54 55
2 55 56
2 56 57
2 57 2
2 7 58
2 58 59
2 59 60
2 60 8
2 6 61
2 61 62
2 62 7
2 5 63
2 63 6
2 4 5
2 6 9
2 10 6
2 11 10
3 209 104 128
3 103 154 194
3 164 80 119
3 97 164 119
3 11 104 209
3 194 154 4
3 61 96 62
3 8 60 97
3 69 158 133
3 84 171 94
3 187 23 24
3 63 107 150
3 28 139 100
3 69 133 110
3 67 151 104
3 20 94 204
3 105 23 187
3 79 101 145
3 11 98 191
3 103 194 161
3 102 161 193
3 75 93 131
3 65 145 101
3 95 119 181
3 181 119 68
3 194 32 161
3 193 161 34
3 5 63 150
3 4 154 5
3 121 72 196
3 94 171 108
3 75 148 93
3 72 221 196
3 11 191 104
3 46 138 99
3 65 137 136
3 84 94 175
3 75 179 99
3 74 111 109
3 28 100 144
3 61 176 96
3 104 151 128
3 103 221 154
3 70 162 96
3 62 96 162
3 20 149 94
3 71 97 163
3 221 72 154
3 4 150 118
3 85 137 127
3 76 127 137
3 60 163 97
3 85 136 137
3 19 20 204
3 64 125 134
3 82 134 125
3 4 5 150
3 70 96 168
3 73 109 111
3 70 173 108
3 63 154 115
3 28 29 139
3 32 33 161
3 33 34 161
3 125 146 205
3 71 175 149
3 65 101 137
3 71 164 97
3 50 51 106
3 79 156 101
3 7 127 126
3 9 115 166
3 92 201 105
3 68 105 201
3 66 101 156
3 70 116 173
3 9 166 143
3 94 149 175
3 5 154 63
3 8 97 195
3 53 54 110
3 75 99 170
3 89 205 146
3 11 157 98
3 86 133 158
3 46 99 179
3 66 210 101
3 75 131 179
3 90 166 121
3 73 111 152
3 72 121 166
3 59 60 113
3 74 146 111
3 77 107 128
3 77 100 139
3 42 43 112
3 77 151 100
3 65 136 109
3 67 199 100
3 64 146 125
3 67 100 151
3 8 195 135
3 86 181 106
3 83 120 157
3 76 126 127
3 74 113 132
3 78 134 117
3 82 117 134
3 27 28 144
3 85 113 136
3 74 136 113
3 46 47 138
3 92 105 187
3 67 104 170
3 23 105 141
3 53 110 133
3 106 181 201
3 54 167 110
3 120 213 157
3 55 56 117
3 71 163 124
3 70 123 162
3 60 132 113
3 95 135 195
3 6 61 155
3 6 155 10
3 73 153 109
3 71 149 114
3 7 126 62
3 102 196 221
3 63 202 107
3 73 152 186
3 90 140 143
3 81 143 140
3 59 113 174
3 18 204 108
3 7 58 127
3 51 169 106
3 86 106 169
3 82 110 167
3 36 37 130
3 21 114 149
3 72 115 154
3 50 106 189
3 68 159 105
3 17 116 183
3 74 109 136
3 13 14 121
3 94 108 204
3 38 39 122
3 101 210 137
3 43 200 112
3 75 170 191
3 85 174 113
3 77 150 107
3 37 165 130
3 88 142 145
3 79 145 142
3 25 178 187
3 106 201 189
3 66 120 210
3 93 112 200
3 64 160 152
3 7 162 123
3 8 132 60
3 16 17 183
3 44 45 131
3 59 124 163
3 92 189 201
3 76 137 210
3 84 124 214
3 65 109 153
3 52 53 133
3 68 201 181
3 8 135 216
3 105 159 141
3 104 191 170
3 64 134 160
3 77 139 118
3 97 119 195
3 15 16 140
3 7 123 180
3 87 130 165
3 20 21 149
3 18 19 204
3 24 25 187
3 18 108 173
3 70 108 171
3 64 111 146
3 84 214 180
3 7 62 162
3 80 141 159
3 59 163 60
3 69 110 188
3 87 160 130
3 78 130 160
3 64 152 111
3 57 129 184
3 7 180 58
3 82 167 117
3 55 117 167
3 38 122 165
3 82 188 110
3 21 208 114
3 77 118 150
3 78 129 198
3 74 217 146
3 75 191 148
3 90 121 192
3 80 114 208
3 12 196 193
3 6 176 61
3 6 9 176
3 79 112 156
3 78 117 184
3 78 198 130
3 44 131 200
3 122 186 165
3 14 192 121
3 74 132 217
3 3 26 177
3 1 49 178
3 1 178 25
3 3 177 48
3 93 212 112
3 79 172 112
3 68 119 159
3 93 200 131
3 70 171 123
3 84 123 171
3 56 57 184
3 42 112 172
3 73 122 203
3 77 128 151
3 73 203 153
3 71 114 164
3 80 164 114
3 39 147 122
3 39 40 147
3 56 184 117
3 98 148 191
3 91 211 138
3 78 184 129
3 70 168 116
3 81 116 168
3 17 173 116
3 85 127 174
3 58 174 127
3 63 115 215
3 9 215 115
3 91 199 211
3 84 175 124
3 71 124 175
3 72 166 115
3 80 159 119
3 40 41 207
3 81 183 116
3 41 42 172
3 12 13 196
3 22 23 141
3 4 118 218
3 16 183 140
3 35 198 129
3 87 165 186
3 41 142 207
3 52 133 169
3 86 169 133
3 45 46 179
3 21 22 208
3 98 157 213
3 41 172 142
3 95 195 119
3 92 187 178
3 66 213 120
3 102 193 196
3 100 199 144
3 59 214 124
3 84 180 123
3 61 62 182
3 82 125 188
3 83 206 120
3 10 209 202
3 31 32 194
3 4 31 194
3 0 193 34
3 0 12 193
3 35 36 198
3 13 121 196
3 73 186 122
3 122 147 203
3 87 152 160
3 83 182 126
3 62 126 182
3 86 158 181
3 95 181 158
3 90 143 166
3 83 126 206
3 80 208 141
3 76 206 126
3 17 18 173
3 65 153 145
3 69 135 158
3 95 158 135
3 107 209 128
3 69 188 205
3 125 205 188
3 35 129 220
3 57 220 129
3 10 11 209
3 9 143 185
3 37 38 165
3 78 160 134
3 54 55 167
3 45 179 131
3 36 130 198
3 6 202 63
3 6 10 202
3 51 52 169
3 107 202 209
3 88 145 153
3 58 59 174
3 61 182 155
3 79 142 172
3 66 148 213
3 98 213 148
3 89 132 216
3 8 216 132
3 9 185 176
3 40 207 147
3 69 205 135
3 89 135 205
3 6 63 215
3 6 215 9
3 49 50 189
3 89 217 132
3 81 140 183
3 81 168 185
3 96 185 168
3 47 48 190
3 118 139 219
3 30 31 218
3 4 218 31
3 14 15 192
3 15 140 192
3 90 192 140
3 112 212 156
3 26 27 197
3 43 44 200
3 2 220 57
3 2 35 220
3 83 222 155
3 10 222 11
3 58 214 59
3 29 30 219
3 83 157 222
3 76 210 206
3 120 206 210
3 89 216 135
3 87 186 152
3 103 161 221
3 91 138 190
3 81 185 143
3 47 190 138
3 88 153 203
3 66 212 148
3 93 148 212
3 91 197 144
3 89 146 217
3 99 138 211
3 29 219 139
3 83 155 182
3 88 207 142
3 22 141 208
3 27 144 197
3 88 147 207
3 91 144 199
3 88 203 147
3 67 170 211
3 99 211 170
3 30 218 219
3 118 219 218
3 67 211 199
3 96 176 185
3 49 189 178
3 91 177 197
3 48 177 190
3 66 156 212
3 91 190 177
3 10 155 222
3 92 178 189
3 11 222 157
3 26 197 177
3 102 221 161
3 58 180 214
CELL_TYPES 469
1
1
1
1
1
1
1
1
1
1
1
1
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
