[petsc-users] Error: DM global to natural SF was not created when DMSetUseNatural has already been called
Danyang Su danyang.su at gmail.com
Wed Nov 28 19:56:56 CST 2018
Dear All,
I got the following error when using DMPlexGlobalToNatural function
using 1 processor.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: DM global to natural SF was not created.
You must call DMSetUseNatural() before DMPlexDistribute().
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.10.2, Oct, 09, 2018
The same code does not return error when using more than 2 processors,
however, the vec_natural is always zero after calling
DMPlexGlobalToNaturalEnd.
DMSetUseNatural() has already been used before calling DMPlexDistribute.
The code section looks like below
      if (rank == 0) then
         call DMPlexCreateFromCellList(Petsc_Comm_World,ndim,0,0,       &
num_nodes_per_cell,                                        &
Petsc_False,dmplex_cells,ndim,                        &  !use Petsc_True
to create intermediate mesh entities (faces, edges),
dmplex_verts,dmda_flow%da,ierr)
         CHKERRQ(ierr)
      end if
       !c Set the flag for creating a mapping to the natural order on
distribution
       call DMSetUseNatural(dmda_flow%da,PETSC_TRUE,ierr)
       CHKERRQ(ierr)
       !c distribute mesh over processes
       call DMPlexDistribute(dmda_flow%da,stencil_width,                &
                             PETSC_NULL_SF, distributedMesh,ierr)
       CHKERRQ(ierr)
       !c destroy original global mesh after distribution
       if (distributedMesh /= PETSC_NULL_DM) then
         call DMDestroy(dmda_flow%da,ierr)
         CHKERRQ(ierr)
         !c set the global mesh as distributed mesh
         dmda_flow%da = distributedMesh
       end if
         call DMPlexCreateSection(dmda_flow%da,dmda_flow%dim,           &
numFields,pNumComp,pNumDof,           &
numBC,pBcField,                       &
pBcCompIS,pBcPointIS,                 &
PETSC_NULL_IS,                        &
                                  section,ierr)
         CHKERRQ(ierr)
         call PetscSectionSetFieldName(section,0,'flow',ierr)
         CHKERRQ(ierr)
         call DMSetSection(dmda_flow%da,section,ierr)
         CHKERRQ(ierr)
         call PetscSectionDestroy(section,ierr)
         CHKERRQ(ierr)
         call DMSetUp(dmda_flow%da,ierr)
         CHKERRQ(ierr)
       !c global - natural order
       call DMCreateLocalVector(dmda_flow%da,vec_loc,ierr)
       CHKERRQ(ierr)
       call DMCreateGlobalVector(dmda_flow%da,vec_global,ierr)
       CHKERRQ(ierr)
       call DMCreateGlobalVector(dmda_flow%da,vec_natural,ierr)
       CHKERRQ(ierr)
       !c zero entries
       call VecZeroEntries(vec_loc,ierr)
       CHKERRQ(ierr)
       !Get a pointer to vector data when you need access to the array
       call VecGetArrayF90(vec_loc,vecpointer,ierr)
       CHKERRQ(ierr)
       do inode = 1, num_nodes
         vecpointer(inode) = node_idx_lg2pg(inode) !vector value using
PETSc global order, negative ghost index has been reversed
       end do
       !Restore the vector when you no longer need access to the array
       call VecRestoreArrayF90(vec_loc,vecpointer,ierr)
       CHKERRQ(ierr)
       !Insert values into global vector
       call DMLocalToGlobalBegin(dmda_flow%da,vec_loc,INSERT_VALUES,    &
                                 vec_global,ierr)
       CHKERRQ(ierr)
       call DMLocalToGlobalEnd(dmda_flow%da,vec_loc,INSERT_VALUES,      &
                                 vec_global,ierr)
       CHKERRQ(ierr)
       !c global to natural ordering
       call DMPlexGlobalToNaturalBegin(dmda_flow%da,vec_global,         &
                                       vec_natural,ierr)
       CHKERRQ(ierr)
       call DMPlexGlobalToNaturalEnd(dmda_flow%da,vec_global,           &
                                     vec_natural,ierr)
       CHKERRQ(ierr)
Is there anything missing in the code that DMPlexGlobalToNatural... does
not work properly?
Danyang
